how do i connect the 4 conductor cable to breadboard
i know what pins to connect...i have the 4 conductor cable which i
conntected to DB9 connector but how do i connect the other side of
that cable to my breadboard
--- In basicstamps@y..., "H Schwenk GMX" <hschwenk@g...> wrote:
> Hi Sam,
> I cut the cable of an old destroyed mouse.
> it is thin, flexible and already with an plug
> how to connect it to the stamp it's to see in the manual
> regards Heinz
Original Message
> From: "sam_26880" <sam_26880@y...>
> To: <basicstamps@y...>
> Sent: Saturday, February 23, 2002 8:08 PM
> Subject: [noparse][[/noparse]basicstamps] making my own cable - what kind of connector
do i
> need
> > hi...i recently ordered bs2 chip (not the whole kit) and now i'm
> > trying to build my own cable but can't get it to work. I have
found
> > some websites that has all the instruction to build serial cable
but
> > either they don't have part numbers listed or they don't have
> > pictures to show exactly what needs to be connected to what and
how.
> > I have db9 female connector and i got the 4 conductor cable but
then
> > I've been reading about some connector that i need but can't find
it
> > anywhere. The one i found does not fit on my breadboard.
> > Can anyone of you redirect me or tell me what exactly i need and
how
> > do i make it happen?
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@y...
> > from the same email address that you subscribed. Text in the
Subject and
> Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> Hi Sam,
> regards Heinz
Original Message
do i
> need
found
but
how.
then
it
how
Subject and
Read page 27 of the Basic Stamp Programming Manual, version 2.0c, available for
download from Parallax. It shows quite clearly what connections you need to
make. If you can't figure it out from there, I suggest you either buy the $20
carrier board, or you choose a new hobby/interest. Not trying to be rude, but
this is about as basic as it's going to get. Best of luck.
Clark
http://www.qsl.net/kf4haz/cables/stamps/
KF4HAZ - Lonnie
> > Hi Sam,
> > regards Heinz
Original Message
> do i
> > need
> found
> but
> how.
> then
> it
> how
