Keyboard Simulation
Hello,
Does anyone know of a way that you can connect a basic stamp to a
standard keyboard port on a computer and simulate pressing a specific
key. If this is not possible, does anyone know how to make a visual
basic program repond to a key press on the keyboard? I want to use
the basic stamp to control the keyboard so that I can make a remote
for my computer.
Thanks advance!
for my computer.
Thanks advance!
to the PC to control your program. It will be cleaner, perhaps easier and
won't interfere with other programs. You can find a couple of Stamp/VB
programs in the "Nuts & Volts of BASIC Stamps" books. Another good reference
to have is Jan Axelson's "Serial Port Complete." Jan's book covers serial
stuff in VB and for the Stamp as well.
-- Jon Williams
-- Parallax
In a message dated 2/21/02 11:06:39 PM Central Standard Time,
travis_gm@y... writes:
> for my computer.
I would suggest you use the RS232 to AT keyboard protocol converter method.
By this I mean that you send RS232 commands to a converter that converts the
commands to AT keyboard commands.
It's a lot easier to debug things if you have problems.
The trick would be to study how the RS232 to AT keyboard protocol conversion
units work. You can keep it simple and use one stamp to serve as the RS232
to keyboard converter and use another stamp to send the converter the
keyboard commands. If that works well you can then combine the two as one
unit if you like.
Has info on how the PC AT keyboard interface works.
They also have a nice article on using a MC68HC05 MCU as a RS-232 to AT
Keyboard
converter too. You could easily swap out MCU's for whatever you'd like to
use.
http://www.beyondlogic.org/keyboard/keybrd.htm
Has a lot of nice info about what to send, receive and to do with the serial
data.
http://www.repairfaq.org/filipg/LINK/PORTS/F_Keyboard_FAQ.html
Of course if you don't want to bother with the whole thing you can buy
a RS232 to keyboard protocol converter from this company. Then you can use
the Stamp's serial port
to send ccommands to the converter.
http://www.vetra.com/Convert2.htm
Earl
Original Message
From: travis_gm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z_bGz2T7b9FOsitkWK-h7X2muKBPn10gyFph8G0eRyIwC07XE33jU6y-sJnm8rz0kH4R1zSTGaEcGvik]travis_gm@y...[/url
Sent: Thursday, February 21, 2002 11:05 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Keyboard Simulation
Hello,
for my computer.
Thanks advance!
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
didn't write, have a look at my remote control clicker at
http://www.al-williams.com/wd5gnr/rfrem.htm -- this is just a Radio
Shack doorbell that I modified. The C program runs on the PC and turns
the doorbell press into any keystroke you want. No reason you couldn't
read a character from the serial port and then convert that into a
virtual keystroke using the same method (you do have to worry about
VK_SHIFT and all but the code shows that).
This is the same doorbell project that I use to make two Stamps talk to
each other wirelessly in this month's project of the month.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Uon-BBkAAsl-JaUS6mogtCFEa5jCy-cUxHJTwKZEBrvc8m_yRVsClHDw43qY1p8SX6dPg1Q]jonwms@a...[/url
> Sent: Thursday, February 21, 2002 11:42 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Keyboard Simulation
> Here's another idea: Have your Stamp send serial strings
> (codes / commands)
> perhaps easier and
> of Stamp/VB
> covers serial
> -- Jon Williams
> -- Parallax
> stamp to a
> a specific
> > for my computer.
> Subject and Body of the message will be ignored.
Tut mir leid--I apologize for delay in responding--have been fighting
some winsock gremlins.
Did you add the disconnect switch as I suggested earlier? It's
possible/likely that the keyboard is interpreting the Stamp's pulses
as commands from the PC (such as "Repeat Last Transmission").
I'll dig into this some more as time permits. I hope we can get it
working...seems like a good Stamp application if possible.
Steve
also expects data in a pretty rigid format. So if you don't respond to a
reset, for example, or if you don't send the right make/break codes (for
example, a break without a make) the BIOS is probably deciding you are
defective.
I haven't tried going in that direction, but that's my guess.
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
Original Message
> From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L4Aehd7oasITCkFopACDSmUYWttqRo6q-0EqbkNaLln7rfe5xwDCv2X0Agu10l3Vwp0V6gIhz8Uo-03rs-fHyazgKB2knGBs2Dl9Hg]ulibasic@r...[/url
> Sent: Friday, March 01, 2002 8:45 AM
> Subject: AW: [noparse][[/noparse]basicstamps] Keyboard Simulation
> hey stampers,
> is there anybody who can contribute anything to the keyboard
> protocol topic? I got so far and only the last step seems to
> be missing... for those who missed the beginning: I am trying
> to build a Stamp device that can send characters through ps2
> to a computer instead of a keyboard. I wired it parallel to a
> keyboard to avoid haveing to do the booting stuff and that
> works fine. I am sending characters according to the prozocol
> but all i get is a system BEEP from the pc... What did I do wrong?
> Thanx, Uli
Urspr
PAK-VI). However, I am under the impression that the PC will accept a
slow clock -- maybe not, though?
Al Williams
AWC
Original Message
> From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fYtXzF0TFrldew8F_5-atVG17V1tqJSPVVhaM9CMVhb-XeuCojEfjhfhpFZaXJnWXD7-phG1bWpgnLjFZ6fEhSc9oZPSNUwIHg]ulibasic@r...[/url
> Sent: Saturday, March 02, 2002 5:34 AM
> Hi Steve,
> yes I did put in the switches, but still no sucess, I also
> tried to track what the keyboard really sends by make the
> stamp 'listen', but the stamp seems to be too slow to read
> the keyboard. Maybe taht is the whole problem, it is too
> slow.. What do you think?
> Thanks and regards, uli
Urspr
The following BS2 program works with my PC. In fact, it works as a
complete replacement for the keyboard--handles system initialization
as well as virtual keystrokes.
This program is tuned for the 4-command initialization sequence on my
PC--I'm sure it will differ from one system to another. Thirty
seconds after the final initialization command is handled, the Stamp
issues a "dir" command. As written, the program doesn't do much
useful, but serves as a foundation for further development.
Steve
' __________
' SER TX <-| 1 24 |-- PWR
' SER RX ->| 2 23 |-- PWR GND
' SER ATN ->| 3 22 |-- RESET
' SER GND --| 4 21 |-- +5V
' I/O 0 --| 5 20 |-- I/O F
' I/O 1 --| 6 19 |-- I/O E
' I/O 2 --| 7 18 |-- I/O D
' I/O 3 --| 8 17 |-- I/O C
' I/O 4 --| 9 16 |-- I/O B Data
' I/O 5 --| 10 15 |-- I/O A |
' I/O 6 --| 11 14 |<> I/O 9
|----\/\/\--+5
' I/O 7 --| 12 13 |<> I/O 8---|
' |__________| |----\/\/\--+5
' BS2-IC Clock
clock_pin CON 8
data_pin CON 9
from_pc VAR BYTE ' byte from PC meant for keyboard
to_pc VAR BYTE ' "keyboard input" to PC
i VAR BYTE ' utility variable
key VAR BYTE ' keyboard scan code
j VAR NIB ' utility variable
parity_bit VAR BIT ' parity bit in PC<--> keyboard traffic
stop_bit VAR BIT ' stop bit in PC-->keyboard traffic
OUTC = %0000
DIRC = %1100
FOR j = 1 TO 4 ' handle four commmands from PC
GOSUB getPC
DEBUG CR,HEX2 from_pc
LOOKDOWN from_pc,[noparse][[/noparse] $ED, $F2, $FF ],i
BRANCH i,[noparse][[/noparse] setLEDs, idKeyboard, reset ]
reset:
to_pc = $FA ' send ack
GOSUB putPC
to_pc = $AA ' send self-test successful
GOSUB putPC
GOTO commandComplete
idKeyboard:
GOSUB putPC
to_pc = $AB ' send ID info
GOSUB putPC
to_pc = $83
GOSUB putPC
setLEDs:
GOSUB putPC
GOSUB getPC ' get LED parameter
GOSUB putPC
commandComplete:
NEXT
PAUSE 30000 ' wait 30 seconds
key = $23: GOSUB sendKey ' "d"
key = $43: GOSUB sendKey ' "i"
key = $2D: GOSUB sendKey ' "r"
key = $5A: GOSUB sendKey ' CR
here:
GOTO here
sendKey:
to_pc = key: GOSUB putPC ' send closure scan code
to_pc = $F0: GOSUB putPC ' send release scan code
RETURN
putPC:
parity_bit = to_pc.BIT7 ^ to_pc.BIT6 ^ to_pc.BIT5 ^ to_pc.BIT4 ^ to_pc.BIT3 ^
to_pc.BIT2 ^ to_pc.BIT1 ^ to_pc.BIT0
awaitIdle:
FOR i = 1 TO 10
BRANCH INC,[noparse][[/noparse]awaitIdle, awaitIdle, awaitIdle] 'await idle clock & data
NEXT
DIRC = %1110 ' lower data line for start bit
DIRC = %1111 ' clock start bit out
DIRC = %1110
DIRC = %1100 ' release data line
FOR i = 1 TO 8
DIR9 = ~to_pc.BIT0 ' set up data line
to_pc = to_pc >> 1 ' rotate to_pc for next time
DIR8 = 1 ' clock data bit out
DIR8 = 0
DIR9 = 0 ' release data line
NEXT
DIR9 = parity_bit ' set up data line
DIR8 = 1 ' clock parity bit out
DIR8 = 0
DIR8 = 1 ' clock out (high) stop bit
DIR8 = 0
RETURN
getPC:
BRANCH INC,[noparse][[/noparse]getPC,gotStart,getPC,getPC] ' wait for data = 0, clock = 1
gotStart:
FOR i = 1 TO 8
DIRC = %1101 ' lower clock line
from_pc = from_pc >> 1 ' rotate from_pc
from_pc.BIT7 = IN9 ' set from_pc bit to match data line
DIRC = %1100 ' release clock line
NEXT
DIRC = %1101 ' clock in parity bit
parity_bit = IN9
DIRC = %1100
DIRC = %1101 ' clock in stop bit
stop_bit = IN9
DIRC = %1100
DIRC = %1110 ' lower data line for ack
DIRC = %1111 ' clock out ack bit
DIRC = %1110
RETURN
ulibasic wrote:
> ...I solved the problem. Simple reason why it didn't work: Bs2 is
> too slow! Now I am using SX and it works!! Maybe a Bs2 would be
> fast enough...maybe someone has an Idea how to speed it up...
after I struggeled with the Keyboard simulator for weeks I found that they
sell them at Milford Industries for about $80...
They also have the other way round (keyboard to RS232)
But: My Stamp can run up to eight PCs at a time! So all the effort (yours
and mine) was not in vain...
Have a nice day and happy easter,
Uli
