ATN
Just curious, what is the ATN on the BS2 mean, the pin that connects to pin 4 of
the serial port? What type of protocol does the BS2 use?
- Chris
- Chris
apparatus@m... writes:
> 4 of
The ATN line is used to reset the Stamp from the programming software. This
is why it's a good idea to put caps on the ATN line when using the
programming port as a general-purpose comm port.
The Stamp is programmed and DEBUG works at 9600-N81.
-- Jon Williams
-- Parallax
