2 questions regarding pak8
I'm controlling four servos with the pak8.
Since two are always working in tandem anyway, it would be
best if i could wire two servos to one output pin of the pak8. That
would allow for smoother operation...and i could ramp two servos up
to speed at the same time in whatever direction. Would this be safe
for the chip ..current sink wise?
Also, should the servos be isolated from the pak8/stamp???
My other big question:
I'm pulsing IR transmitters at 40Khz, I'm wondering if the pak8 can
do this for me instead of the stamp. I figured at a 75% on time with
default prescale of 10us i'd have to send it a value of 2 for the on
time, and something like 0.6 off time in order to achieve a frequency
of 38500hz. so..is this possible? I can't actually send it a 0.6
though can I...has to be integer
Some help would be appreciated, thanks
PS: they are standard 4.8 volt servo's from acroname
are good for 25-30mA if I recall (not in the office this morning) and
the servos should draw way less than that. I've never isolated servos,
but others may have some experience with that. The servos I've used have
logic-level inputs that seem to be pretty easy to drive. However, it is
useful to have one battery supply for the servos and another for the
Stamp (with grounds connected).
With the default prescale of 10uS, you will not be able to get exactly
40kHz. However, most IR detectors have some bandwidth so you may be able
to get close to 40kHz and still be OK. The total period for a 40kHz wave
would be 25uS. You can't add up 10uS periods to get 25 (if you drop the
prescaler to 5uS then you can do it easy, but you can't run 8 channels
at 5uS).
The fastest you can get with the default prescaler is 10uS on and 10uS
off which is 50kHz. You might try that but I don't know if the detector
you are using is that wide (some remotes use 48kHz which would likely
detect 50kHz OK). The next step would be 2+1 which is 33.333kHz That's
closer to 40kHz but may or may not be close enough -- you'll have to
experiment.
At 5uS you could do 2+3 to get 40kHz exactly (your choice of 10uS on
15uS off, or the other way around for a duty cycle of 40% or 60%).
Again, the PAK-VIII can't do 8 channels at 5uS though so you limit your
channels to 4 if you go to the 5uS steps.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
Original Message
> From: cbielek [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VZcYvUPrfTsi2UJx-b9U5dU4jRXPGX3j3oQ3asnJrqEvUzx2YX0_GexNZWOCF5OYZxHZ05YVYi1rdQM]cbielek@y...[/url
> Sent: Sunday, December 16, 2001 11:47 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] 2 questions regarding pak8
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Thank you very much for this info! It cleared up alot.
I will now be using two servo's for one port..so that
will use two ports. I'll set prescale to 5us shouldn't
be a problem there..just means i'll have to be sending
300on/400off for a center pulse ect that's easily
done!
Something I hadn't concidered was the current of the
IR transmitters..ideal operation at 100mA...can handle
10A. I've tested them at 20mA and that's fine for my
purposes, but if I even wire two in parallel..I'll get
a blown port. So those will have to be isolated
somehow. I did some research into optoisolators but
didnt' find one that could switch the current required
in the nano seconds ..so I was thinking some sort of
emitter follower buffer.
Thanks again
--- Al Williams <alw@a...> wrote:
> You should be able to drive multiple servos with no
> trouble. The outputs
> this morning) and
> another for the
> able to get exactly
> 25 (if you drop the
> at 5uS).
> is 10uS on and 10uS
> which would likely
> is 33.333kHz That's
> -- you'll have to
> experiment.
> choice of 10uS on
> of 40% or 60%).
> Al Williams
> AWC
Original Message
> > From: cbielek [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h07joiXrVPEWDFY8oALJ3Y-xzywwJdjaJtmPUehhuAkipJsfD73yM2nU_RYRfCI1zBJsVqy7Nmg]cbielek@y...[/url
> would be
> of the pak8. That
> ramp two servos up
> Would this be safe
> pak8/stamp???
> a 75% on time with
> achieve a frequency
> send it a 0.6
> acroname
> Text in the
> Text in the Subject and Body of the message will be
> ignored.
______________________________________________________
Send your holiday cheer with http://greetings.yahoo.ca
know the list has had that discussion within the last two weeks). Use a
2N2222 on each LED between it and ground (connect to the collector).
Connect the + side of the LED right to the power. Then ground the
emitter and drive the base from the Stamp through a 1K resistor. This
will take just a few mA from the Stamp or PAK and let the LED draw up to
100mA or so (more with a bigger transistor). After all, you only need to
turn the thing on and off, right?
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
Original Message
> From: c bielek [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JPvV5bVOOCp1_18-0kLpVYUpa_kXI9czBC3Ne4J1z0xG7vfoT6yEtmIA4DjJ-sfyMxDKOFK-LQ]cbielek@y...[/url
> Sent: Wednesday, December 19, 2001 9:28 AM
> Subject: RE: [noparse][[/noparse]basicstamps] 2 questions regarding pak8
> Hi Al,
> done!
> Thanks again
> > this morning) and
> > another for the
> > able to get exactly
> > 25 (if you drop the
> > at 5uS).
> > is 10uS on and 10uS
> > which would likely
> > is 33.333kHz That's
> > -- you'll have to
> > experiment.
> > choice of 10uS on
> > of 40% or 60%).
> > Al Williams
> > AWC
> > * Easy RS-232 Prototyping http://www.al-williams.com/awce/rs1.htm
Original Message
> > > From: cbielek [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JPvV5bVOOCp1_18-0kLpVYUpa_kXI9czBC3Ne4J1z0xG7vfoT6yEtmIA4DjJ-sfyMxDKOFK-LQ]cbielek@y...[/url
> > would be
> > of the pak8. That
> > ramp two servos up
> > Would this be safe
> > pak8/stamp???
> > a 75% on time with
> > achieve a frequency
> > send it a 0.6
> > acroname
> > Text in the
> > ignored.
