simple question
I apoligize for a very basic question. I tryed searching for an
answer but nothing relevent came up. All I want to do is connect a
12V DC motor to my BS2P. I assume I need a relay but when I look for
one I find few different types and very varying specs.
Will
Will
Wow, I kind have the same question. I got some 3-6 volt 312ohm reed relays
from All Electronics and need to know if they are safe for using directly
off a stamp pin. I am a beginner, so forgive my ignorance. Can someone tell
me if I am using ohm's law properly if "I" is current, "V" is voltage and
"R" is resistance then I=V/R or in my case using the example above,
5/312= 0.016 amps. Is this formula correct? If it is then I am right in
assuming I can drive it right off a stamp pin, as it is under 20mAh right???
Thanks Richard
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, December 13, 2001 5:13 AM
Subject: [noparse][[/noparse]basicstamps] simple question
> Thanks,
> Will
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
http://www.al-williams.com/wd5gnr/stampfaq.htm
See article 2.5
Now, my US$0.02. There are really two questions here: How do I drive a
motor, and how do I drive a relay.
You can use a relay to drive a motor. Depending on the motor's size, you
may be happier using a MOSFET. Radio Shack, for example, has an IRF510
(I think that's right) that will handle small motors. The MOSFET is
quiet and relatively fool proof. You'd connect the source to ground, the
drain to the motor (the motor also connects to 12V) and the gate to a
Stamp pin. When the Stamp is not running, the FET's gate is very
sensitive to static charge, so I'd put a 100K to 1M resistor from the
gate to ground to bleed off anything. There is a FET article in the FAQ
too.
Now, if you want to use a relay, here's the deal on that. First, there
are two things to consider when using relays. The obvious one is the
coil. Even if you have a 5V low current coil, you should not drive it
directly from the Stamp. Coils are inductors. When a voltage changes
quickly through an inductor you get a reverse voltage that is
proportional to the rate of change. That means when you switch the
voltage from 5V to 0V almost instantly you will get a very large spike.
The answer is to put a diode "backwards" across the relay coil. The
Stamp has beefy I/O pins, so sometimes this will work without the diode,
but it isn't worth trying it to find out. Even if it works for awhile,
it may be a reliability problem for the future. So the banded end points
to 12V and the other end points to the Stamp. However, I still would not
drive a relay coil directly. Instead, I'd use a 2N2222 or 2N3904. Ground
the emitter, and connect the collector to the cold end of the relay coil
(the other end goes to 12V or 5V depending on the relay). You take the
base of the transistor to the Stamp pin through a small resistor (1K
should be plenty). This should handle coils that require up to, say,
100mA. This is in the FAQ too.
Sometimes relay coils are rated in ohms. So at 5V a 50 ohm coil will
require 5/50 = 100mA. Of course, if the coil is rated in mA, then that's
the right value and you could compute the resistance just as easily.
The other thing to look at with a relay (and that most hobby electronics
projects ignore) are the contacts. Contacts have a voltage and current
rating too. Some contacts are rated "dry" which means you switch them
with no current flowing. Different contact materials have different
properties. At low power, you want contacts that stay clean. If they
corrode, the relay will become resistive. At high power, you want a
contact material that won't pit from the arcing that occurs when the
contacts are close together. Corrosion is OK because the arcing will
clean the material. Putting the wrong kind of contact in will cause
early failure and is a big reasons relays have a reputation as
unreliable. Switching dry contacts with power applied can cause problems
too.
If you can't tell, I've used relays in a government project about 20
years ago where we had to make them last.
I did a quick Web search, here's an interesting failure story that
illustrates some of my points:
http://www.leachintl2.com/english/english2/vol6/properties/how4.htm It
also mentions a "multi load" contact which I'd never heard of. However,
it is kind of weird since once you put high currents through it it won't
handle low currents any more. Pretty good pages:
http://www.leachintl2.com/english/english2/vol6/properties/00047.html
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
Original Message
> From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dD7qeuhIsUCakEYjDEsJat2MpO9RAWnyj36yjqT4L6KoxMAg33JC7hGAlKAv8G9qNo020JCmtUji6uk]wc31415@y...[/url
> Sent: Thursday, December 13, 2001 4:13 AM
> To: basicstamps@yahoogroups.com
> Thanks,
> Will
> Subject and Body of the message will be ignored.
current is within the capability of the port.
The motor starts in what is called STALLED condition, that is the
inductance is almost zero and only the ohmic resistance of the
winding limits the current
Albert Catano.
--- In basicstamps@y..., "Richard R." <rryerson@o...> wrote:
> Hello,
relays
directly
someone tell
voltage and
above,
right in
right???
> Thanks Richard
Original Message
> From: "wc31415" <wc31415@y...>
> To: <basicstamps@y...>
for
> > Thanks,
> > Will
> > basicstamps-unsubscribe@y...
Subject and
the sudden interruption of the current thru the relay and due to the
equation:
Vl=L*dI/dT, where Vl is the voltage acroos the relay, L is the
inductance of the coil, dI is the current thru the coil at the time
of the interruption, and dT is the time it takes for the magnetic
field of the coil to collapse.
That why is required a clamping diode either across the coil or
across the semiconductor driving the coil.
> Hello,
relays
directly
someone tell
voltage and
above,
right in
right???
> Thanks Richard
Original Message
for
> > Thanks,
> > Will
Subject and
as inrush current. When the filament is cold it has a lot less
resistance than when it is hot. So the bulb draws a lot more current
when you first turn it on. This high current (and heating and cooling)
ages the filament. In hi rel applications (like traffic lights) they
keep a little current through the filament all the time to keep it warm
and reduce inrush.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: acatano2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TR8seYXDge-eHTFbjiSA_IXzc6XdrCFBxRDn9Ryvm486lE0nJLh1z8yrSQ8elCCKDRRyzQaLiGsTxpeE6j8]acatano2002@y...[/url
> Sent: Thursday, December 13, 2001 8:03 AM
> Subject: [noparse][[/noparse]basicstamps] Re: simple question
> Be careful when using ports to drive motors even if the running
> Albert Catano.
> > Hello,
> relays
> directly
> someone tell
> voltage and
> above,
> right in
> right???
> > Thanks Richard
Original Message
> connect a
> for
> > > Thanks,
> > > Will
> Subject and
feel a little foolish. What I intended to do is use a RF transmitter, a BS2
(with it's own power supply) to power up and power down a robot. The robot
has it's own BS2 processor, 12V motor, & motor controller board. I was
intending to use the first BS2 as a co-processor to control the robots
system, 12v power supply... hence the relay (to turn this on and off). I
also want to control other systems I might add on in the future, like
turning on/off video camera, etc. So, basically I want to have control over
power usage... having the ability to turn systems on and off at will. Again,
I was planning on using relays to do this. Would a 2N2222 transistor do
this? Is it a better option? Can it drive 12V?
Sorry, as I said, a beginner (but, I am going to check out the FAQ)
Richard
Original Message
Sent: Thursday, December 13, 2001 8:56 AM
Subject: RE: [noparse][[/noparse]basicstamps] simple question
> There is a relay article in the Stamp FAQ at
> See article 2.5
> too.
> too.
> Regards,
> Al Williams
> AWC
Original Message
> > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3MIYhOnQDFzaQdvG7vTIAYHjlw1_OkLWFMhcn11gdyrC30yEAq9gEDH3b-5_MNYjmPhIXgaOyqTi]wc31415@y...[/url
> > Thanks,
> > Will
(you'd have to look at the spec sheet to see exactly how hard you could
push, but experience says 100mA is no big deal). For bigger loads, look
at the FET.
Relays are OK, but they are noisy, slow, and not as reliable as solid
state (although not as unreliable as people think if they are used
properly). Relays are useful for AC (where solid state switching is
available, but not nearly as simple), or very high current/voltage where
a solid state solution might be expensive. But relays usually require a
drive circuit anyway, so you get a 2N2222 and a relay when the
transistor drives the relay. There are "solid state relays" by the way
that are not really relays and you can drive them directly, but they are
not cheap.
As for switching, keep in mind that breaking the ground leg is as good
as breaking the hot leg of the circuit. When you use a 2N2222 as
described, the saturated transistor "makes" the ground leg. Turning it
off turns off the connected device. If all the voltage is DC, you really
don't need anything other than the 2N2222 and the IRF FET unless you
will go to very high currents (the IRF 510 will handle up to 4 - 5 A
(depends on temp -- see the charts at
http://www.frn.net/tech/xmitters/anarchy/IRF-510_Data.pdf). Radio Shack
carries these (or they used to), they are cheap, and dead simple to use.
You can get other parts that will go over 4A, even. But at some point,
the relays will be cheaper.
Both devices will handle 12V (or more). When the transistor is "off" the
Vce will be about 12V (which is OK). When the transistor is "on" the Vce
will be just .2 or .3V.
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
Original Message
> From: Richard R. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KJMR4V1JLYQ7NaGVq_KWKyW2eHTHZcBhuIVD_U2M_QTAsjdyXFkbWrvd5lUvrNdUWlUFDLBeGOqskCpJhYsH]rryerson@o...[/url
> Sent: Thursday, December 13, 2001 8:33 AM
> Subject: Re: [noparse][[/noparse]basicstamps] simple question
> Thank you Al (I have your book, maybe I should read it
> again), but now I feel a little foolish. What I intended to
> do is use a RF transmitter, a BS2 (with it's own power
> supply) to power up and power down a robot. The robot has
> I was intending to use the first BS2 as a co-processor to
> control the robots system, 12v power supply... hence the
> relay (to turn this on and off). I also want to control other
> systems I might add on in the future, like turning on/off
> at will. Again, I was planning on using relays to do this.
> Would a 2N2222 transistor do this? Is it a better option?
> Can it drive 12V?
> Thanks
> Richard
Original Message
> From: "Al Williams" <alw@a...>
> > See article 2.5
> do I drive a
> motor's size,
> > you may be happier using a MOSFET. Radio Shack, for example, has an
> > IRF510 (I think that's right) that will handle small motors. The
> > MOSFET is quiet and relatively fool proof. You'd connect
> the source to
> > ground, the drain to the motor (the motor also connects to 12V) and
> > the gate to a Stamp pin. When the Stamp is not running, the
> FET's gate
> > is very sensitive to static charge, so I'd put a 100K to 1M
> resistor
> > from the gate to ground to bleed off anything. There is a
> FET article
> > in the FAQ too.
> First, there
> one is the
> not drive it
> voltage changes
> > spike.
> > diode, but it isn't worth trying it to find out. Even if it
> works for
> > awhile, it may be a reliability problem for the future. So
> the banded
> > end points to 12V and the other end points to the Stamp. However, I
> > still would not drive a relay coil directly. Instead, I'd
> use a 2N2222
> > or 2N3904. Ground the emitter, and connect the collector to
> the cold
> > end of the relay coil (the other end goes to 12V or 5V depending on
> > the relay). You take the base of the transistor to the Stamp pin
> > through a small resistor (1K should be plenty). This should handle
> > coils that require up to, say, 100mA. This is in the FAQ too.
> coil will
> > that's the right value and you could compute the resistance just as
> > easily.
> > electronics projects ignore) are the contacts. Contacts
> have a voltage
> > and current rating too. Some contacts are rated "dry" which
> means you
> > switch them with no current flowing. Different contact
> materials have
> > different properties. At low power, you want contacts that
> stay clean.
> > If they corrode, the relay will become resistive. At high
> power, you
> > want a contact material that won't pit from the arcing that occurs
> > when the contacts are close together. Corrosion is OK because the
> > arcing will clean the material. Putting the wrong kind of
> contact in
> > will cause early failure and is a big reasons relays have a
> reputation
> > as unreliable. Switching dry contacts with power applied can cause
> > problems too.
> about 20
> 4.htm It
> > However, it is kind of weird since once you put high
> currents through
> > it it won't handle low currents any more. Pretty good pages:
> > Regards,
> > Al Williams
> > AWC
Original Message
> > > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NQVUyYWWt78YIHURlyRUhHLYMPjG_UVZhnUFSeyinBfeeDR0W2fp2o6XmvoRs-7joGsbYxN0mg]wc31415@y...[/url
> connect a
> I look for
> > > Thanks,
> > > Will
> the Subject
> > and
correct me if I am wrong. I do something like this... The stamp pin will be
connected to the gate (do I use a resister to drop the voltage to around 1
volt, or can 5 volts be applied to the gate?). Common ground (stamp & other
power supply). Source & drain to higher power source & circuit, like 12V and
1amp? This will isolate the stamp from the higher power circuit I want to
control?
Richard
Original Message
Sent: Thursday, December 13, 2001 9:45 AM
> A 2N2222 will switch the ground leg of circuits up to around 100mA or so
> at the FET.
> not cheap.
> Al Williams
> AWC
Original Message
> > From: Richard R. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=U6lzZvUNVZphGYh1IPFTaBgt1rngs2VtJDgrts2G0iBQ2xsck_yDG9_9ZzrjcuI0aoiE5NLPfJQmL70oEeQ]rryerson@o...[/url
> > Can it drive 12V?
> > Thanks
> > Richard
Original Message
> > > See article 2.5
> > do I drive a
> > motor's size,
> > the source to
> > FET's gate
> > resistor
> > FET article
> > > in the FAQ too.
> > First, there
> > one is the
> > not drive it
> > voltage changes
> > > spike.
> > works for
> > the banded
> > use a 2N2222
> > the cold
> > coil will
> > > easily.
> > have a voltage
> > means you
> > materials have
> > stay clean.
> > power, you
> > contact in
> > reputation
> > > problems too.
> > about 20
> > 4.htm It
> > currents through
> > > Regards,
> > > Al Williams
> > > AWC
Original Message
> > > > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SNQ9yHTE4OrfUT5bHiJcGClrDN4DbSuIDOe7LVhUaVPQ75-lz9GF-W0snlbQde3NG-LJNtJyxQ]wc31415@y...[/url
> > connect a
> > I look for
> > > > Thanks,
> > > > Will
> > the Subject
> > > and
I mentioned before I'd put a 1M resistor between the gate and ground to
protect the FET when the power is off.
The source goes to ground. Then the drain goes to the "ground leg" of
your load. So if you want to switch a lamp, for example, connect one
side to +12 and the other side to the drain. If you use a relay, you
probably still want a snubbing diode as described earlier. You are
correct that all the grounds need to be in common.
Spend $2 on a FET and do the experiment in article 2.5 of the FAQ. It
should clear things up for you.
Al Williams
AWC
Original Message
> From: Richard R. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9ZPlSJqio6QzHW10sYs2sV9aV01Sa54iH3IITAp8rRtQF2gL8BbRuahCDls3Uw2-Bt3QaD5-bYvunTWY89Zt]rryerson@o...[/url
> Sent: Thursday, December 13, 2001 9:02 AM
> Ok, I think I am starting to clue in here. If I use a Mosfet
> and please correct me if I am wrong. I do something like
> this... The stamp pin will be connected to the gate (do I use
> a resister to drop the voltage to around 1 volt, or can 5
> circuit, like 12V and 1amp? This will isolate the stamp from
> the higher power circuit I want to control?
> Richard
Original Message
> around 100mA or
> > so (you'd have to look at the spec sheet to see exactly how
> hard you
> > could push, but experience says 100mA is no big deal). For bigger
> > loads, look at the FET.
> reliable as solid
> > where a solid state solution might be expensive. But relays usually
> > require a drive circuit anyway, so you get a 2N2222 and a
> relay when
> > the transistor drives the relay. There are "solid state
> relays" by the
> > way that are not really relays and you can drive them directly, but
> > they are not cheap.
> is as good
> Turning it
> > really don't need anything other than the 2N2222 and the IRF FET
> > unless you will go to very high currents (the IRF 510 will
> handle up
> > to 4 - 5 A (depends on temp -- see the charts at
> > Shack carries these (or they used to), they are cheap, and
> dead simple
> > to use. You can get other parts that will go over 4A, even. But at
> > some point, the relays will be cheaper.
> is "off"
> > the Vce will be about 12V (which is OK). When the
> transistor is "on"
> > the Vce will be just .2 or .3V.
> > Al Williams
> > AWC
> > * Control 8 servos at once http://www.al-williams.com/awce/pak8.htm
Original Message
> > > Can it drive 12V?
> out the FAQ)
> > > Thanks
> > > Richard
Original Message
> > > > See article 2.5
> > > do I drive a
> > > motor's size,
> example, has an
> > > the source to
> to 12V) and
> > > FET's gate
> > > resistor
> > > FET article
> > > > in the FAQ too.
> > > First, there
> > > one is the
> > > not drive it
> > > voltage changes
> switch the
> > > > spike.
> relay coil. The
> without the
> > > works for
> > > the banded
> Stamp. However, I
> > > use a 2N2222
> > > the cold
> depending on
> should handle
> > > coil will
> in mA, then
> resistance just as
> > > > easily.
> > > have a voltage
> > > means you
> > > materials have
> > > stay clean.
> > > power, you
> that occurs
> because the
> > > contact in
> > > reputation
> applied can cause
> > > > problems too.
> > > about 20
> story that
> > > 4.htm It
> > > currents through
> > > > Regards,
> > > > Al Williams
> > > > AWC
Original Message
> > > > > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KUuB1VSYo-nZ3woQTMow9zCeQ9Eu7i49gVcGOYr9ssRgPFSYkNsi-7793cZ9eXtdFrxdUUiTPHieTOJX]wc31415@y...[/url
> searching for an
> > > connect a
> > > I look for
> > > > > Thanks,
> > > > > Will
> > > the Subject
> > > > and
> the Subject and
> send mail to:
IFR510. I need to update the FAQ to reflect this.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
Original Message
> From: Richard R. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NLWF5uX67QmyjhbEjfLrwXxEfLwkvfJC86n7YSnRbeLsxd3oUcaMVa-BAITf-aPCHrOlJz1Sa86PfJfOxfLW]rryerson@o...[/url
> Richard
Original Message
> around 100mA or
> hard you
> reliable as solid
> relay when
> relays" by the
> > they are not cheap.
> is as good
> Turning it
> handle up
> dead simple
> is "off"
> transistor is "on"
> > Al Williams
> > AWC
Original Message
> > > Can it drive 12V?
> out the FAQ)
> > > Thanks
> > > Richard
Original Message
> > > > See article 2.5
> > > do I drive a
> > > motor's size,
> example, has an
> > > the source to
> to 12V) and
> > > FET's gate
> > > resistor
> > > FET article
> > > > in the FAQ too.
> > > First, there
> > > one is the
> > > not drive it
> > > voltage changes
> switch the
> > > > spike.
> relay coil. The
> without the
> > > works for
> > > the banded
> Stamp. However, I
> > > use a 2N2222
> > > the cold
> depending on
> should handle
> > > coil will
> in mA, then
> resistance just as
> > > > easily.
> > > have a voltage
> > > means you
> > > materials have
> > > stay clean.
> > > power, you
> that occurs
> because the
> > > contact in
> > > reputation
> applied can cause
> > > > problems too.
> > > about 20
> story that
> > > 4.htm It
> > > currents through
> > > > Regards,
> > > > Al Williams
> > > > AWC
Original Message
> > > > > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oJ5F2eX-A4h9KPBf6Z8g4_Xc8DM1x0pTxbyjqvnRn66fABvxOwYDXYJI6KkG7o94kztTgmvL6fb_qWuH]wc31415@y...[/url
> searching for an
> > > connect a
> > > I look for
> > > > > Thanks,
> > > > > Will
> > > the Subject
> > > > and
> the Subject and
> send mail to:
>Thank you Al (I have your book, maybe I should read it again), but now I
>Thanks
>Richard
Hi Richard -
You might want to take a look at the Reynolds Electronics web site for how
to implement an RF Link relay setup. Here is the web page of interest:
http://www.rentron.com/rf_remote_control.htm
Hope that gets you started.
Bruce Bates
is 5 vdc
one exception is the 2n7000 mosfet, it is designed for ttl logic level
switching.
Personally I use a 2n3904 or 2n2222 with a pull-up resistor from 12v to the
collector-gate connection
and 2 snubbers one reverse biased drain to source, the other reverse biased
drain to 12V to prevent high spikes from exceeding the mosfets max voltage
when the load is switched off..
Original Message
> Not exactly. The gate can directly connect to the Stamp pin, although as
> Al Williams
> AWC
Original Message
> > From: Richard R. > > Ok, I think I am starting to clue in here. If I use
a Mosfet
> > Richard
Original Message
> > From: "Al Williams"
> > around 100mA or
> > hard you
> > reliable as solid
> > relay when
> > relays" by the
> > > they are not cheap.
> > is as good
> > Turning it
> > handle up
> > dead simple
> > is "off"
> > transistor is "on"
> > > Al Williams
> > > AWC
Original Message
> > > > From: Richard R. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2zR-39Og3Iq47BaQCtaliOy2exLVt1Kfvqbz6MAlfQkCLkTY1zsm_TDXW__WH5U_n_3OZTyV4Qgc1g]rryerson@o...[/url
> > > > Can it drive 12V?
> > out the FAQ)
> > > > Thanks
> > > > Richard
Original Message
> > > > > See article 2.5
> > > > do I drive a
> > > > motor's size,
> > example, has an
> > > > the source to
> > to 12V) and
> > > > FET's gate
> > > > resistor
> > > > FET article
> > > > > in the FAQ too.
> > > > First, there
> > > > one is the
> > > > not drive it
> > > > voltage changes
> > switch the
> > > > > spike.
> > relay coil. The
> > without the
> > > > works for
> > > > the banded
> > Stamp. However, I
> > > > use a 2N2222
> > > > the cold
> > depending on
> > should handle
> > > > coil will
> > in mA, then
> > resistance just as
> > > > > easily.
> > > > have a voltage
> > > > means you
> > > > materials have
> > > > stay clean.
> > > > power, you
> > that occurs
> > because the
> > > > contact in
> > > > reputation
> > applied can cause
> > > > > problems too.
> > > > about 20
> > story that
> > > > 4.htm It
> > > > currents through
> > > > > Regards,
> > > > > Al Williams
> > > > > AWC
Original Message
> > > > > > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Lqv4tosvmZObUjBQiuAcw5hJ1xr35tpSbPj_KNJWVMsyGJkF_xdgIuuB7D37l1cgvAnR5wZTeg]wc31415@y...[/url
> > searching for an
> > > > connect a
> > > > I look for
> > > > > > Thanks,
> > > > > > Will
have a full output swing. TTL might be a problem since the Vgs is right
around the 1 threshold. Of course, with a low Vgs you probably won't get
the full Id rating, but I've used 5V drive for up to about 1.5A with no
trouble.
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
Original Message
> From: FalconWireless Tech Support - KF4HAZ
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GHUSO7Uu6kNaV0zkM-oaZh5RmVMCmVaZjy_SlbFS9t_meGWBCw0tbXTqBNq5A0lzwuEhG3TZdJXkkw1as6CUJuKxnkt4]techsupport@f...[/url
> Sent: Thursday, December 13, 2001 9:25 AM
> Most mosfets (IRF510 IRF511 IRF541 et.al.) are a bit marginal
> when the gate is 5 vdc one exception is the 2n7000 mosfet, it
> is designed for ttl logic level switching. Personally I use a
> collector-gate connection and 2 snubbers one reverse biased
> drain to source, the other reverse biased drain to 12V to
Original Message
> From: "Al Williams"
> pin, although
> > as I mentioned before I'd put a 1M resistor between the gate and
> > ground to protect the FET when the power is off.
> "ground leg" of
> connect one
> relay, you
> the FAQ. It
> > Al Williams
> > AWC
Original Message
> here. If I
> > > use
> a Mosfet
> this... The
> > > stamp pin will be connected to the gate (do I use a
> resister to drop
> > > the voltage to around 1 volt, or can 5 volts be applied to the
> > > gate?). Common ground (stamp & other power supply).
> Source & drain
> > > to higher power source & circuit, like 12V and 1amp? This will
> > > isolate the stamp from the higher power circuit I want to control?
> > > Richard
Original Message
> > > From: "Al Williams"
> > > around 100mA or
> > > hard you
> For bigger
> > > reliable as solid
> they are used
> switching
> > > > is available, but not nearly as simple), or very high
> > > > current/voltage where a solid state solution might be
> expensive.
> > > > But relays usually require a drive circuit anyway, so you get a
> > > > 2N2222 and a
> > > relay when
> > > relays" by the
> > > > but they are not cheap.
> > > is as good
> 2N2222 as
> > > Turning it
> is DC, you
> the IRF FET
> > > handle up
> > > dead simple
> even. But at
> > > is "off"
> > > transistor is "on"
> > > > Al Williams
> > > > AWC
Original Message
> > > > > From: Richard R. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9rqcYt1BOTmrHUqjGAsAEODZY60I_dKRzJcGnpprjIFKfvvY7W3aAgVM9Yflwzv_GWyIs1LkBRjYYII]rryerson@o...[/url
> it again),
> do is use a
> has it's
> control the
> > > > > robots system, 12v power supply... hence the relay
> (to turn this
> > > > > on and off). I also want to control other systems I
> might add on
> > > > > in the future, like turning on/off video camera, etc. So,
> > > > > basically I want to have control over power usage...
> having the
> > > > > ability to turn systems on and off at will. Again, I was
> transistor
> > > > > do this? Is it a better option? Can it drive 12V?
> > > out the FAQ)
> > > > > Thanks
> > > > > Richard
Original Message
> > > > > > See article 2.5
> > > > > do I drive a
> > > > > motor's size,
> > > example, has an
> small motors.
> > > > > > The MOSFET is quiet and relatively fool proof. You'd connect
> > > > > the source to
> > > to 12V) and
> > > > > FET's gate
> > > > > resistor
> > > > > FET article
> > > > > > in the FAQ too.
> > > > > First, there
> > > > > one is the
> > > > > not drive it
> > > > > voltage changes
> voltage that is
> > > switch the
> > > > > > large spike.
> > > relay coil. The
> > > without the
> > > > > works for
> > > > > the banded
> > > Stamp. However, I
> > > > > use a 2N2222
> > > > > the cold
> > > depending on
> the Stamp
> > > > > > pin through a small resistor (1K should be plenty). This
> > > should handle
> the FAQ too.
> > > > > coil will
> > > in mA, then
> > > resistance just as
> > > > > > easily.
> most hobby
> > > > > have a voltage
> > > > > means you
> > > > > materials have
> > > > > stay clean.
> > > > > power, you
> > > that occurs
> > > because the
> > > > > contact in
> > > > > reputation
> > > applied can cause
> > > > > > problems too.
> > > > > about 20
> > > story that
> > > > > 4.htm It
> never heard of.
> > > > > currents through
47.htm
> > l
> > > > > Regards,
> > > > > Al Williams
> > > > > AWC
> > > > > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
Original Message
> > > > > > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=S_7KqNbGuZ4_HeFURZdFWyC87CdDo8eMZdmJBKrnXyfGy_1IWkaD4Lzicv54sqeZNel_Vy5xGvDImw]wc31415@y...[/url
> > searching for an
> > > > connect a
> > > > I look for
> > > > > > Thanks,
> > > > > > Will
diodes in there to protect the stamp from the voltages that are created from
the collapsing magnetic field of the relay.One in series and one across the
terminals of the relay. The second one should be reverse biased.
Original Message
Sent: Thursday, December 13, 2001 4:43 AM
> Hello,
tell
right???
> Thanks Richard
Original Message
> > Thanks,
> > Will
and
your motor draw?
Original Message
Sent: Thursday, December 13, 2001 2:13 AM
> Thanks,
> Will
and interface this part directly to the stamp. The Melexis part
(www.melexis.com) has buildin diodes and can be PWM via of the stamp to
control speed and direction. This a great project for the dc electric trains.
Chuck
and with that much inductance you tend to choose to err to the side of
safety and overkill to the max.
Original Message
> I've never had any trouble driving IRF FETs from CMOS outputs where you
> trouble.
> Regards,
> Al Williams
> AWC
> * 8 channels of PWM
Original Message
wc31415@y... writes:
Depends on the current requirement of the motor. If it's not horrible, you
might be able to use a ULN2003 and then get some level of speed control over
the motor. I've done this with small DC motors.
-- Jon Williams
-- Parallax
1N4001 Diode to drive a small relay? What's the difference? I am only asking
because I have some 2N3906's
Thanks Richard
Original Message
> See article 2.5
> too.
> too.
> Regards,
> Al Williams
> AWC
Original Message
> > From: wc31415 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jLRAhajJkhwgDGoiQIVGMPWZjYs43i7QYrHzC6QKdRwQU_bPe6NJZ9M6ZMwAisyi8yvRaTHGNN9Edg]wc31415@y...[/url
> > Thanks,
> > Will
1] What is the surge current in amperes of the motors you want to control?.
2] Take this current and multiply by 2.
3] Look for a 12 volt DC Relay with contact ratings at least equal to the
current calculated in 2].
4] What is the coil resistance of the relay you selected?
5] Calculate the coil current at 12 volts. eg:A 200 ohm relay coil current
is .06 amperes with 12 volts applied to it.
6] .06 amperes is beyond the current capacity of the stamp output ckt.
7] Lets assume that you want the stamp output to provide .002 amps of
current to a transistor that would then operate the relay and turn on the
motor.
8] You want a transistor that has a minimum Beta of {.06/.002} 30 and Ic min
of 100 ma.. This would be a very low cost transistor.
hope this helps, Steve
Original Message
> Thanks,
> Will
Original Message
> Hello,
tell
right???
> Thanks Richard
Original Message
> > Thanks,
> > Will
and
electronics course in high school and it was pretty useless. If
someone knows of a book I could buy that will show me step by step
(from a new user standpoint). Most books I see gloss over the
fundamentals that I lack.
Thanks again,
Will
--- In basicstamps@y..., "Stephen H Chapman" <chapman@t...> wrote:
> There are some requirements that you need to define.
control?.
to the
current
ckt.
of
on the
> motor.
and Ic min
Original Message
for
> > Thanks,
> > Will
Subject and
not exist. Suggest you go to the Local library, Ask for the ARRL Handbook
and look in the section on D C Theory, Real World Component Characteristics
and DC Power Supplies as a starter. The information learned will be
beneficial in getting you from lets try this and see the fireworks to
knowledge about DC circuits and you can do this and why and here also are
the things you should not do.
Good Luck on your project. Steve
Original Message
Sent: Thursday, December 13, 2001 9:56 PM
> Sorry again I really am clueless as to how to do this. I took a basic
> Thanks again,
> Will
> control?.
> to the
> current
> ckt.
> of
> on the
> > motor.
> and Ic min
Original Message
> for
> > > Thanks,
> > > Will
> Subject and
http://www.capable.on.ca/rcstuff/esc.htm
regards,
Leroy
I am new to the group and to the basic stamp - This
may be a little off topic...
I had tried to bid on a II stater kit for me & my
son(13yrs old). We lost by $1 (price $81). Both of us
want to get into this but money is tight. Anyone got
an old one they want to sell (cheap)???? We don't need
the book (we printed it).
Kevin
psycho_dad123@y...
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
http://www.phanderson.com/stamp/starter.html
BTW, your welcome
Brian G.
Be sure to read:
http://www.wd5gnr.com/faqs/index.php?qframe=1&faq=1&article=9
You can buy just a Stamp and make your own cables using the instructions
in the manual.
If you want something a little more robust, we make an adapter that
connects an RS232 cable to a breadboard (and a 9V battery). Not too
expensive and it lets you use any breadboard you happen to have, a large
breadboard, or switch between breadboards -- all very handy. You can
check it out at http://www.al-williams.com/awce/app2.htm.
Good luck!
Al Williams
AWC
Original Message
> From: Kevin Zee [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=c1FBoGkxAwJnVsE5yam9XOEDiUWmuOhr4szpH97y5z-YQX0P7j5Qgh8gTMdMJKnrbL3_8HBf14THb3ufv3chcQ]psycho_dad123@y...[/url
> Sent: Tuesday, May 28, 2002 11:28 PM
> Subject: [noparse][[/noparse]basicstamps] Simple question
> Hi all,
> Thanks,
> Kevin
> psycho_dad123@y...
> Do You Yahoo!?
