Specs for R/C Servo HS-300B
Recently I bought a R/C Servo HS-300B but I could not obtain
electrical specs for it.
I would appreciate if anybody could help me in this.
:http://www.hitecrcd.com/Catalog/Servos/Servo_Index.html
> not obtain
> this.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
__________________________________________________
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Length- 41mm (1.6")
Weight- 44.5g (1.75 oz.)
Width - 20mm (0.8")
Torque- 3.0kg/cm (42 oz/in)
Height- 36mm (1.4")
Speed - 0.19 sec/60 deg.
I found them at
http://www.hitecrcd.com/Catalog/Surface/Servos/sprtdervo.htm
I really need more generic information such as:
1.- Max degrees of rotation from center
2.- The optimum pulse width and period to center
I have tried several values suggested but none seems to center
poperly.
3.- any programming hints to rotate CW, Center, & CCW
