BASIC Stamp RS232 serial notes questions
Hi,
I had some questions about networking two of the basic stamps.
1.) On the webpage www.emesystems.com/BS2rs232.htm on Master/slave
scenario #2, how come the serin command is 14\15? I thought pin 14 is
for flow control and and 15 is for data. Is that wrong or is there
some special purpose in doing that? are there any advantages?
serout 15\14,..........
serin 14\15,...........
2.)Also, on that webpage there were no suggestions as far as the
circuitry setup in networking the 2 stamps. I know the BS manual has
3 circuit diagrams: one with flow control, one for open-source, and
one for open-drain. Which circuitry is the best if I want to use flow
control?
3.)If I want to network a BS2 and a BS2SX, are there any extra things
that need to be taken into account such as baud rate and timeouts?.
For instance, can I set both stamps at 9600 baud if I want to?
Any help would be appreciated.
RP
control?
RP
I'm not sure I'll be much help but.....
Original Message
From: rpsu279@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cL-r6e8m34IKYHv0nUGU_XJJXaEyFgN-XbI5nYusUtLtiJtBnLS5ITpgxzpXDBmxIAfSr-tpYLYz]rpsu279@y...[/url
Sent: Saturday, November 17, 2001 1:09 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] BASIC Stamp RS232 serial notes questions
Hi,
On a BS2SX the a\b part of the serin or serout command represent the same
thing, that is "a" is the pin number for which you will transmit data and
"b" is the pin you will use for flow control. If you are serouting from one
chip with 14\15 then you would most likely serin with 14\15 on the other
chip. The program you are talking about executes a serout first from the
master with 15\14, at that same moment the slave is waiting at its serin
with 15/14. Once this transaction is completed the master changes to serin
and also changes the pins in which it will use to 14\15 the slave also makes
these changes and begins its transmission.
control?
I'm not sure I know what your asking.
I've never done this, but they appear to use the same code. I don't think
there will be any problems.
Hope I helped you!
Kevin
RP
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Hi RP.
On of the beauties of the Stamp is that any pin can be used for any
purpose. That particular master-slave scenario was set up like this:
serout 15\14,$54,60,bailout,[noparse][[/noparse]"A"] ' *** first BS2, sends data
| | signal directions
v |
serin 15\14,$54,2,nodata,[noparse][[/noparse]zork] ' *** second BS2, receives data
The corresponding pins are connected together by number. But it
could be done with them cross-connected just as easily.
Kevin explained the operation well, but here it goes again. When the
master wants to send a command, it executes the serout command. It
listens on p14, and if that pin is high, meaning "not ready", it just
sits there, waiting. It can sit there waiting for up to 60
milliseconds (a long time in this context). But if p14 goes low, then
the master sends the command, ascii letter "A" out on p15.
The slave normally holds p14 at a high level, meaning "I'm not
ready". Every so often (less than every 60 milliseconds) its main
loop executes the serin command. When it does so the BS2
automatically sets p14 low, and that stimulates the master to send
the "A" command. They then both go about their business, and the
slave will probably do something with the command. If it happens
that the slave hits the serin command, and the master is not there,
the slave quickly (1 millisecond) gives up and goes on with other
tasks. It come sback within 60 milliseconds to try again.
In one scenario, the slave can receive a command from the master and
then send a response. Maybe that is what caused the confusion for
you? The flow control logic is the same, but the roles are reversed
for flow control between the master and the slave. Here is the code
on the master:
serout 15\14,$54,6000,noslave,[noparse][[/noparse]commands]
serin 14\15,$54,6000,noslave,[noparse][[/noparse]datas]
After waiting and sending serout'ing a command, the master turns
around and inputs the response from the slave. The direction of
signal flow is the same for both of those commands. p15 is an output
from the master for both the serout and the serin command. In the
serout it is the RS232 data output, and in the serin is is the
handshaking "I am ready" output. On the other hand, p14 is an input
in both cases: input RS232 data for the serin command, and input
"are you ready" handshaking for the serout command.
Because of the versatility of the BS2 pins, there are other ways you
could do it. I don't recall any advantage to doing it this way.
>control?
You can connect p15 to p15 and p14 to p14 directly on the two stamps,
but I recommend putting a resistor between them, say 470 to 1000
ohms. That protects them if by mistake, a programming error
(inevitable!), they are both made outputs and opposite polarity.
The parameters are different for both the baud rates and the
timesouts. Basically, the BS2sx is 2.5 times faster. The numbers
are described in the manual. Or ask here if you have specific
questions.
Good luck, and I'm glad you found the web page helpful, and I hope I
did not add to the confusion!
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
>Thanks,
>RP
Thanks for all your replies. However, I have a question about the
How would I put a resistor between them? Do I pullup or pulldown? a
schematic would help.
RP
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> >Hi,
is
> Hi RP.
this:
> | | signal directions
> v |
data
the
just
then
and
reversed
code
> on the master:
output
input
you
has
flow
> >control?
stamps,
things
> questions.
I
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> >Thanks,
> >RP
RP
> >Hi,
is
> Hi RP.
this:
> | | signal directions
> v |
data
the
just
then
and
reversed
code
> on the master:
output
input
you
has
flow
> >control?
stamps,
things
> questions.
I
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> >Thanks,
> >RP
RP
> >Hi,
is
> Hi RP.
this:
> | | signal directions
> v |
data
the
just
then
and
reversed
code
> on the master:
output
input
you
has
flow
> >control?
stamps,
things
> questions.
I
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> >Thanks,
> >RP
>Thanks,
>RP
>> | | signal directions
>> v |
Sure:
BS2 master BS2 slave
_____, ,_______
| 1k |
p15|---/\/\----|p15
p14|---/\/\----|p14
| 1k |
p15 is physical pin 20, and p14 is physical pin 19 on the BS2-IC. It
is neither pullup nor pulldown--it is just straight across.
-- Tracy
