potentiometer based mouse
I am working on a somewhat similar problem. I have a potentiometer circuit (0
to 5 volts) that I want to translate into x and y co-ordinates that wil be
used to position a cursor on a computer screen. (ie. potentiometer based
mouse). The pot I am using is "special "and will allow 0 to 340 degrees of
rotation. Any thoughts on how best to translate this 0 to 5 volts (0 to 340
degrees rotation) into X and Y values that could be read by the standard
Mouse drivers on a computer??? Thanks!
George (azeasi)
George (azeasi)
rotation and pot resistance at any degree of rotation is also linear. If it
is not linear then go get a pot with a linear taper.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, November 10, 2001 3:44 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: potentiometer based mouse
(0
340
> George (azeasi)
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
