CRC and Basic Language
Function CRC(message$) as long
Dear all;
I have found a basic program that calculates crc checksum.
I would like to use this program on a BS2.
I would be grateful for any tips, or a converted program listing.
many thanks
A.J.Neal
'' CRC runs cyclic Redundancy Check Algorithm on input message$
'' Returns value of 16 bit CRC after completion and
'' always adds 2 crc bytes to message
'' returns 0 if incoming message has correct CRC
'' Must use double word for CRC and decimal constants
crc16& = 65535
FOR c% = 1 to LEN(message$)
crc16& = crc16& XOR ASC(MID$(message$, c%, 1))
FOR bit% = 1 to 8
IF crc16& MOD 2 THEN
crc16& = (crc16& \ 2) XOR 40961
ELSE
crc16& = crc16& \ 2
END IF
NEXT BIT%
NEXT c%
crch% = CRC16& \ 256: crcl% = CRC16& MOD 256
message$ = message$ + CHR$(crcl%) + CHR$(crch%)
CRC = CRC16&
END FUNCTION CRC
Dear all;
many thanks
A.J.Neal
crc16& = 65535
FOR bit% = 1 to 8
ELSE
crc16& = crc16& \ 2
END IF
NEXT BIT%
NEXT c%
CRC = CRC16&
END FUNCTION CRC
the CRC over a large number of bytes (message$ in this algorithm). Where
would those come from in the Stamp? You don't have 256 bytes of storage (or
whatever).
The algorithm specifies double words for several variables, but that's not
insurmountable. I'm not sure it really needs it anyway. (Regular basic
doesn't like unsigned so you need a bigger word.) If you are getting your
data from a stream, you'd "unwrap" the for loop. So this is an attempt at a
rewrite.
crc16 var word ' running crc
crc_char var byte ' incoming character
crcbit var byte ' bit counter
crc_init:
crc16=$FFFF
return
crc_next:
crc16=crc16 ^ crc_char
for crcbit=1 to 8
crc16=crc16>>1
if crc16.bit0 = 0 then crcskip
crc16=crc16 ^ 40961
next
return
So to use this, you'd call crc_init. Then as each character arrives, you'd
put it in crc_char and call crc_next. At the end of the data stream, your
CRC is in crc16.
A few notes:
1) This is my interpretation of the code you sent. I didn't bother to verify
that it really computers a CRC.
2) I didn't test the code.
3) ^ = XOR, >>1 is the same as \2, crc16.bit0 will be 0 if MOD 2 would be 0.
You can use // to get MOD on the Stamp, but MOD 2 is a special case where
you are really looking at the last bit so I rewrote it to be faster.
4) Your original code has this in it:
> CRC = CRC16&
This splits the CRC into bytes (crch = crc16.highbyte, crcl = crc16.lowbyte)
and then adds it to the message (you'd have to do something else here). The
last line causes a return from the function which the BS doesn't need.
Let me know how that works for you.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: a.neal@u... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dUfqAIxJSaEPomr9TscIOpy7xHBcFoDe4Jrbfo9cN6zls90HFm1FTTk4UghMHbO448HMhWfpUFxnrqnnsBvD]a.neal@u...[/url
> Sent: Friday, October 26, 2001 3:54 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] CRC and Basic Language
> Dear all;
> many thanks
> A.J.Neal
> crc16& = 65535
> FOR bit% = 1 to 8
> ELSE
> crc16& = crc16& \ 2
> END IF
> NEXT BIT%
> NEXT c%
> CRC = CRC16&
> END FUNCTION CRC
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
validate if the data in a transmisi
