LCD compatibility for BASIC STAMP 1.....
Hello,
I have been building several of the example circuits for the
STAMP 1 and ran into some trouble with the SERVO tester when
used with certain LCD displays. The circuit works with a
16x2 LCD I had from another project but I would like to use
some extra sharp LM16158 displays. I can't get the sharp
displays to do anything. They are based on the HC44780 chip.
I also had some other generic 44780 based displays that
would not respond either.
Is there that many differences between the displays? If so
can the code be tweaked to use these other LCD's?
Any pointers would be appreciated. Thanks!
Robert
Robert
contrast bias -- that is most likely the problem.
-- Jon Williams
-- Parallax
In a message dated 10/22/01 9:20:39 AM Central Daylight Time,
rdoerr@b... writes:
I think you may be correct. I found the datasheet for the display:
http://fina.lly.org/electronics/LCDs/LM16158.PDF
After looking at the sheet it looks like the LCD module itself
runs at 5v but the contrast adjustment may accept up to 12v like
the backlight. For contrast I am using a 10K pot across the 5v
supply. The specs on the data sheet are not very clear. If
possible I would like to get this to work since this backlit
display did look very nice.
If you get a chance to look at the datasheet what do you think
it is expecting for the contrast connection?
Robert
--- In basicstamps@y..., jonwms@a... wrote:
> Check the contrast input pin requirements. Some displays require a
negative
> -- Jon Williams
> -- Parallax
> rdoerr@b... writes:
On the Parallax site you will find a couple of tutorials
(pdf files) on how to connect and program the // LCD's.
The schematics are OK and the code works, at least with a
BS2sx.
Regards
ECO
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, October 22, 2001 4:19 PM
Subject: [noparse][[/noparse]basicstamps] LCD compatibility for BASIC STAMP 1.....
> Hello,
> Robert
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
the contrast bias and the display came on. After some more
digging I noticed that many of the LCD's I have are supposed
to work on 0 to 5v and for extended range use 0 to -7v. Is
that common? I guess it will be trial and error to see what
displays I can use with only a 5v supply and which ones will
require both the 5v supply and a negative bias.
Thanks for the hint.
Robert
negative
> -- Jon Williams
> -- Parallax
> rdoerr@b... writes:
>Problem solved! You were correct. I used a -5v supply for
I've seen this suggestion before, about the negative supply voltage on
LCD's. I'm sorry, but I have to ask: How the heck does one supply
-5v? Sorry for the stupid question, but I don't know!
John
contrast. It worked!
John Leung
Original Message
Sent: Tuesday, October 23, 2001 5:46 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: LCD compatibility for BASIC STAMP 1.....
> http://www.epanorama.net/psu.html#lowvoltage
supply, I'm just interested in knowing basically how it is done? Is it
directly from a power supply or from other components in a given circuit you
are building? Anyone else?
(The list has been awfully quiet today, so I don't mind a fairly worthless
post [noparse]:)[/noparse]
TIA,
John Walton
Original Message
From: Kevin Olalde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bwLlRqlil4dCRDfAVx4p0udtKN3b6hYEsBsYXG-uVbTVuVfRzaInBUU-eymcczckYX-IDhwOb45-Fg]kolalde@h...[/url
Sent: Tuesday, October 23, 2001 4:47 AM
To: basicstamps@yahoogroups.com
very little current on the contrast pin so it does not load down the
inverter in the MAX. The MAX IC's create a negative voltage using a R/C
flyback circuit.
James R. Parish
J-Tech Internet Services
J-Com Enterprises, Inc.
Original Message
From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7zFBxTjq_zMoDMJwDeTfZi6lfpaeY7Dgk2s8fcQkmcIpp8vuBoOgiVzJaQEYRTDjTSZgXTWhfrGU]john@l...[/url
Sent: Tuesday, October 23, 2001 4:30 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: LCD compatibility for BASIC STAMP
1.....
This is a great link, but I have to be honest, I've never built a power
TIA,
John Walton
Original Message
From: Kevin Olalde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=i_uGA8fn1xIXNXiKetZrjhSnOJW17T-zEHm5Vj6tF6ScQUD9qhtUuXaJwV2NZg259KO5WIAelEk]kolalde@h...[/url
straight forward. Here's a simplified description (which is about all I can
muster).
Here's how I usually do it. Grab a wall wart. Those ugly square black plastic
things that plug into the wall and connect to a huge amount of comsumer
electronics. Look at the label (or raised lettering label), it'll say something
like:
Output: 8V - 800mA (or some such) Look for one that can generate enough
current for your needs, and is a few volts greater than the voltage regulator
you're using (7805, 7905, ...)
Chop the plug off it (save it for later projects), and determine the polarity of
the wires, use a DMM that's rated for the job. Or don't chop the plug if you
have a matching connector. The label on the wall wart may also have the
polarity of the existing plug.
Use the wires from the wall wart to power a circuit like this:
http://www.hut.fi/Misc/Electronics/circuits/psu_5v.gif (create another copy of
this ciruit but use a 7905 for the -5 volts).
Watch your current needs so that you don't exceed the capacity of the wall wart
or the voltage regulator.
That's about it.
Hopefully someone will correct my gross errors in this description. And maybe
add some omitted details, like the difference between switching and
non-switching and regulated and non-regulated wall warts (and how one can tell
the difference).
Kevin
most audio high fi.
To make a +/- output, an ac transformer, 78M15 and 79M15 ICs are commonly
used. I have a diagram showing the circuit. If you are interested, I can
scan it and email to you.
For the LCD, a ground to pin3 worked fine in my case. I don't know if all
alpha-based LCD are the same. (probably not)
John Leung
Original Message
Sent: Wednesday, October 24, 2001 4:29 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: LCD compatibility for BASIC STAMP 1.....
you
> TIA,
> John Walton
Original Message
> From: Kevin Olalde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=11I5cf3nqlxrwtxrF5G2KTMnV1xpMaXLRzg_K1q7OhlkEK76riIYUiGnXgrpZOPwayj7Jww7o--6YQ]kolalde@h...[/url
If you just want to test it out, you can use a battery. The
following circuit adjusts the contrast voltage from -V, the battery
voltage, up to +5 volts:
~50kohm -v
+5 Vdd
| | -v to +5
contrast
com Vss
battery
v ~3 volts | |
In application, you substitute a voltage inverter like the '7660 or
'7662, to derive the - voltage from a charge pump. The 766x is made
by several companies, a jellybean part.
http://www.national.com/pf/LM/LMC7660.html
http://www.njr.co.jp/pdf/ae/ae06046.pdf
Or as others have suggested, there may be some other way to derive
the - voltage in your system.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
