laser diode
I have a laser diode that I want to use. It is a Hitachi laser diode
class IIIb laser type: HL8314E. It was made in 1986 and its peak power
is 30mW. I want to know what voltage it uses and can I hook it up to a
basic stamp 2. thanks
lasers here:
http://www.repairfaq.org/sam/laserfaq.htm
It shows you how to build power supplies for a laser -- you can't run it
directly from the stamp -- the supply needs to be current limiting and
current regulated otherwise you will have a stamp attatched to a broken
laser diode. You could of course turn the supply on or off with the
Stamp. The site also has useful info on what peak power means and whether
you should expect to get that rating from your laser. I was up until late
the night I ran across this page.
Hope that helps,
Nick
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
regulation systems built into them that you can drive in the range of 3-6
volts. My 3mw ones draw about 50mw, which is the output of the BS2. I
would use a transistor or some such to control the output of the BS2
otherwise you're going to pull too much current.
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
http://www.repairfaq.org/sam/laserdps.htm#dpstoc
And it worked!!!
In +
+ Out R1 .25 ohms
Vin o----| LM338 |
o 0 to 5 A current source
| Adj. +----+
| cw | |
| 1K ^ / _|_,
>\ '/_\ LM385-1.2
| I = 0.5 to 1.5 mA sink |
_|_
Jay
http://www.mi-lasers.com/laser_diodes.html its the 60 dollar one.
COMMON
_|_ ______ |
PD /_\ \ \_/ LD
| <_____\ |
This is as close as I can get it if you want to see the gif go to the
web page. It shows that it has 3 leads. I want to know what PD and LD
means and what voltage it runs at and since I wont be able to get to
radio shack every time I need something I need to know what I need
before hand
Jay Hanson wrote:
>I built the following laser power supply from
>And it worked!!!
> In +
+ Out R1 .25 ohms
> Vin o----| LM338 |
> | Adj. +----+
> | cw | |
> | 1K ^ / _|_,
>\ '/_\ LM385-1.2
> _|_
>Jay
tad@h... wrote:
>I found my laser on the internet here:
> COMMON
> _|_ ______ |
> PD /_\ \ \_/ LD
> | <_____\ |
>before hand
>Thanks
>>And it worked!!!
>> In +
+ Out R1 .25 ohms
>> Vin o----| LM338 |
>> | Adj. +----+
>> | cw | |
>> | 1K ^ / _|_,
>\ '/_\ LM385-1.2
>> _|_
>>Jay
The circuit I use doesn't need it. Read all the material at the Sam's FAQ
before you go any further...
Jay
Original Message
From: tad@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kpGNMr0-Yk-IhzcMRBah_HT4b_Bb3ehTLDt10G5jQYQ2lbDre7ypzeNQgeVJxcl4xR99J0VZaQ]tad@h...[/url
Sent: Friday, October 19, 2001 5:13 AM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] laser diode
COMMON
_|_ ______ |
PD /_\ \ \_/ LD
| <_____\ |
before hand
>And it worked!!!
> In +
+ Out R1 .25 ohms
> Vin o----| LM338 |
> | Adj. +----+
> | cw | |
> | 1K ^ / _|_,
>\ '/_\ LM385-1.2
> _|_
>Jay
Jay
Original Message
From: Jay Hanson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6mk4rRkDwjuG5RF1G7rDmBLOBM5M6RE74GvEvFJN4A1RJVM8u7HHihepxIir66WdpHcxmAOr]j@q...[/url
Sent: Friday, October 19, 2001 3:13 PM
Subject: RE: [noparse][[/noparse]basicstamps] laser diode
PD is "photo diode" and can be used as part of a current limiting circuit.
Jay
Original Message
From: tad@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OKTV5vepyKD9wmI0WMI54rDZTolxpUAalSXZWD_2bFhapr-nFlVflIPrCrbAqHCFHyet_vI9pXQ]tad@h...[/url
COMMON
_|_ ______ |
PD /_\ \ \_/ LD
| <_____\ |
before hand
>And it worked!!!
> In +
+ Out R1 .25 ohms
> Vin o----| LM338 |
> | Adj. +----+
> | cw | |
> | 1K ^ / _|_,
>\ '/_\ LM385-1.2
> _|_
>Jay
Any suggestions on using them?
>Jay
Original Message
>From: tad@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=q7d2H2c__RH3_O1LaNSh_5dBZRnbZiYuWWDzwe_TgT2F9o7gW-iD1bVeneABG4Nh-l8CZj3G]tad@h...[/url
> COMMON
> _|_ ______ |
> PD /_\ \ \_/ LD
> | <_____\ |
>before hand
>Thanks
>>And it worked!!!
>> In +
+ Out R1 .25 ohms
>> Vin o----| LM338 |
>> | Adj. +----+
>> | cw | |
>> | 1K ^ / _|_,
>\ '/_\ LM385-1.2
>> _|_
>>Jay
