H-bridges in my tank
I've got a medium size tracked vehicle (18", 10 lb), driven with 2 DC
motors, controlled with 2 H-bridges via a BS2 talking to an R/C
receiver (instead of L/R sticks, I use the BS2 to mix a single speed
input with a steering wheel input).
The vehicle goes fwd/rev just fine, can even spin in place (opposite
track directions). But make a gentle turn? No way. With tracks off
the ground, I can vary left/right track speeds independently, as
required for turning. But on the ground, it just goes straight.
Apparently, any juice to the "slow" side allows that side to be
dragged along at the fast side's speed... appears to "over run" the
slow motor. This may happen because it's mechanically easier than
actually making the turn, which involves all kinds of forces on the
tracks.
Question: Might the slow motor run closer to it's intended speed if I
apply PWM to the direction pin of the H-bridge, instead of the enable
pin?
Enable PWM is obvious- select direction, then PWM the enable pin to
control speed. But I wonder if I enable, then PWM the direction pin,
the motor might resist being over-run?
50% pwm on direction should cause the motor to stand still (0 avg
current), while 60/40 should make it crawl in one direction. But does
this have draw backs? More power usage? Over heat the motor?
Any h-bridge experts out there?
patmat
tracks.
pin?
patmat
properly.
Original Message
> tracks.
> pin?
another option, though not available on my current H-bridge (Allegro
2998). But for smooth gradual turns, I'd have to figure out variable
pwm on the brake pin as well as the enable... more than I wanted to
do.
I hope pwm'ing the direction pin may effectively reverse the inside
track at PWM frequency, as opposed to a non-smooth stop-brake-turn-
release-go maneuver.
patmat
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> You may need to brake or reverse the track on the inside to make it
turn
> properly.
just invert the enable signal and feed to the brake pin...so bridge
is either enabled or braked.
Maybe less harsh than reversing the motor at PWM frequency?
patmat
> do.
phase pin is held high or low for whatever direction you want. Looks like
the 2998 would work the same way, although you don't have a brake pin.
Once you calculate your PWM values for various turns, you can put them in a
lookup table and use an index value for the direction you want to turn.
Original Message
> Actually, braking (electrically, not mechanical, that's cruel!) is
> do.
between the treads make turns easier?
Or maybe shortening the length? Is it too late for that kind of stuff? This
seems more of a mehanical problem
than a software problem. Putting 50% pwm on the direction pin would keep the
motor at stall current consumption
and that's no good!
good luck!
raphael
> I'm not an expert on tank style movement, but wouldn't widening the
distance between the treads make turns easier?
stuff?
****It's a scale model, changes verboten! (The original had lots of
driveline problems too)
This seems more of a mehanical problem
keep the motor at stall current consumption
> and that's no good!
**** That was my fear, sounds like getting an H-bridge with braking
might be better.
patmat
> good luck!
> raphael
> between the treads make turns easier? Or maybe shortening the length? Is it
too
> late for that kind of stuff? This seems more of a mehanical problem than a
> software problem. Putting 50% pwm on the direction pin would keep the motor at
> stall current consumption and that's no good!
Actually, it tends to be opposite; a narrower tread spacing reduces the
friction.
In general, you should avoid using tank treads at all costs as the system
require far more torque (and consumes far more current) than you would
need for a wheeled solution.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
See our NEW BASIC Stamp Prototyping tools !
http://www.hvwtech.com/stampstack.htm
> Hey! Maybe not so tough! If I get a brake-capable H-bridge, then I
> patmat
to
> > do.
According to my step-father, a former T.C. Tank Commander before
tanks had steering wheels. Full scale tanks act the same way.
Whenever turning there is a noticable reduction in speed as power is
removed from the 'inside' track and braking is applied. The amount
required is also dependent on the surface conditions.
So, if you are driving your tank on asphalt, you will probably need
to brake, or reverse the inside track quite a bit to the turn. In
sand, the drag is greater and just removing power should show some
turning.
Using an H-bridge with braking capability and PWMing the brake on the
inside track will save you some battery power. Your other option is
of course to slowly increase power in the reverse direction, but uses
battery power. Either way, the motor has current in the coils and
will generate heat.
But anyway you look at it, there isn't any smooth transition from
forward. You need to at least brake or reverse the one track to make
any significant turn. Suggest you make a dead-band in the center of
your steering stick where the edge of the dead-band is no power
forward. Slowly increase brake with transition to reverse power.
Good luck.
Check the manual for your H-bridge chip. You may burn it up by braking
unnecessarily. Look for a duty cycle, or maximum amount of time that the
brake can be safly applied.
Joshua
