quick question about the or function
I would like to know what is the correct way to use the "or " function on the
basic stamp... what i trying to do is OR three inputs it must link to
another part of the program if only an only if the three inputs ored
togeether is equal to 1.... Is the code list on the bottom correct....
Check_SW
If input1= 0 then time_20
if input2= 0 then time_45
if input3= 0 then time_60
if input1|input2|input3= 1 then un_lock
Thank you wendell
Check_SW
Thank you wendell
What you need here is the "AND" function.
Carl
>Carl
No, OR is what he wants...
OR AND
000 skip to next Line skip to next Line
001 goto un_lock skip to next Line
010 goto un_lock skip to next Line
011 goto un_lock skip to next Line
100 goto un_lock skip to next Line
101 goto un_lock skip to next Line
110 goto un_lock skip to next Line
111 goto un_lock goto un_lock
"OR" he could simply use addition...
if input1+input2+input3 > 0 then un_lock
Beau Schwabe IC Mask Designer
National Semiconductor Wired Communications Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
>>Carl
> OR AND
Original post:
:another part of the program if only an only if the three inputs ored
:togeether is equal to 1.... Is the code list on the bottom correct....
:Check_SW
: If input1= 0 then time_20 ; 0 1 1
: if input2= 0 then time_45 ; 1 0 1
: if input3= 0 then time_60 ; 1 1 0
: if input1|input2|input3= 1 then un_lock ; 1 1 1
With "OR", any 1 input is 1. Since he specified that he needed all
three = 1, that's and "AND". Actually, since he is testing for four
conditions out of a possible 16, he needs to specify the state of
each input for each of his conditional lines. What if the switches
read "0 0 1"?
> >>Carl
> > OR AND
>Original post:
>:Check_SW
>read "0 0 1"?
"ored", that would be 1
"AND" would result in a 0
I just don't see where you are reading that "he specified that he needed
all three = 1" (<--Quote from you), instead what I see in his original
post is...
"if only an only if the three inputs ored togeether is equal to 1"
...the key word being "ored"
This has caused much confusion. However, let's look at your code with
some comments added:
Check_SW
If input1= 0 then time_20 ' if we pass here, input1 == 1
if input2= 0 then time_45 ' if we pass here, input2 == 1
if input3= 0 then time_60 ' if we pass here, input3 == 1, so...
if input1|input2|input3= 1 then un_lock ' the only time we can
' be here is if all 3
' inputs are at 1.
What we are describing in the fourth "if" statement would call for an
AND, e.g. "if input1 = 1 AND input2 = 1 AND input3 = 1 THEN un_lock".
However, if we get to this point, we already know that the three-
input AND statement in my last sentence is true. So you could replace
the foursth "if" statement with "goto unlock". Standing by itself, it
would go true if at least one of the inputs equal 1, but since we
have already tested all 3 for 0 equality and found it false, we know
all 3 are 1, so we do not need a fourth "if" test. Otherwise we could
have fun with truth tables.
Bob Pence
function on the
link to
ored
correct....
> Check_SW
> Thank you wendell
wasn't working correctly to begin with... hence why he asked a
question. I was responding more to what he was saying, rather
than the code snip that he provided.
>Wendell -
>Check_SW
> ' inputs are at 1.
>Bob Pence
>function on the
>link to
>ored
>correct....
> > Check_SW
> > Thank you wendell
>post is...
*My* keyword is "three". Perhaps ARTICALEX@A... could refine
his specs a bit.
