Switch Matrix on BS2
Hello,
I'm trying to read an 8x8 switch matrix by scanning (pulling cols low
one at a time and reading the rows). The problem is, the switch is
hit for such a short period of time, that by the time I scan the last
two cols, the rows are already reading low because the switch no
longer has contact.
Is there any way to extend the length of time on the contact, just
long enough to be able to scan the entire 8x8.
Thanks is advance, Dean
longer has contact.
www.nutsvolts.com/stmpindx.htm
Marylou
_________________________________
--- In basicstamps@y..., dean1888@y... wrote:
> Hello,
low
last
> longer has contact.
>longer has contact.
It should be possible to scan the 8x8 in less 10 milliseconds. Maybe
your scanning code could be optimized? Are you scanning the keyboard
using all 16 stamp pins for the 8x8?
If your program has to go off and do a lot of other tasks between
each scan, that is another matter. It is possible to set up a matrix
keyboard with capacitors in parallel with the switches to "hold" the
state like a dynamic memory.
Another alternative would be an external keyboard scanning chip, such
as the PAK?? that Al offers for sale.
-- Tracy
> >Hello,
low
last
> >longer has contact.
Maybe
keyboard
matrix
the
such
> -- Tracy
Tracy,
I'm scanning a dartboard switch matrix which does not allow much
time. I have to scan while the dart is hitting the board. My code is
a simple for loop:
For pin = 8 to 15
low pin
if (pins 0-7) are low goto disp
next
I don't have the code with me but that is about the same (minus
correct variables). I had tried switching from a BS2 to a BS2sx which
helped a little, but not enough. Also, when the dartboard is on the
floor, it works fine, once hanging on the wall, it seems the dart
hits for less time causing bad scans.
Any ideas?
Thanks, Dean
> -- Tracy
Hi all,
The 74C922 and 74C923 (Fairchild Semiconductors) are 16-key and 20-key
encoders. The 74C922 is expendable to 32 keys. This chip has a built-in
debounce circuit, a latch for the last key code, plus a rollover logic on 2
keys (that means, when you hit a key when the last one is not yet released).
May be is it a solution... and a cheap one (the price in Belgium is 1 or 2
Phil.
buffering. With a wireless keyboard it is really fun to type and control a
robot with no wires. You can order them direct or from Parallax.
Al Williams
AWC
* Connect a PS/2 keyboard to your next Stamp project
http://www.al-williams.com/awce/pak6.htm
Original Message
> From: Philippe Derenne [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CuEnTlMoyxueVETmULYR9M7fvOj0av_HS_5fjbYCkl0VE2tYulTcukefvyKMKJhqoleMj9AgGg]derennep@s...[/url
> Sent: Tuesday, September 04, 2001 5:25 PM
> To: basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Switch Matrix on BS2
> > -- Tracy
> Hi all,
> logic on 2
> released).
> Phil.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>Tracy,
>a simple for loop:
>For pin = 8 to 15
> low pin
>next
>Any ideas?
>Thanks, Dean
Hi Dean,
Back in late June/early July there was another thread about a dart
board started by Wayne Fulcher. It turned out I think that the dart
board had a capture circuit attached to it, that he was able to read
hits out successfully (?) using a SHIFTIN command. Maybe you have
the same dart board??
No? Oh well. One millisecond is too short a window for the Stamp,
even with the fast logic you suggested.
* One alternative would be to design a circuit with discrete latches,
shift registers etc. It could get ugly.
* Another alternative would be to implement the scan in a PIC or SX
chip with the same logic you are using in the Stamp. No big deal, but
you have to work in assembler to make it fast.
* A third alternative would be, make it happen with the BASIC Stamp.
Put a capacitor across each of the 64 switch contacts in the matrix.
The .301*RC time with your pullup resistors should be about 300
microseconds, say 0.1uf with 10kohm. The Stamp starts by charging up
all the caps to 5 volts, by bringing all the column lines low. Then
all the column lines (as well as the row lines with the pullups to +5
volts) are made inputs. Each capacitor remains charged to +5
volts--that is, unless a dart comes along and discharges it by
hitting its parallel switch. Later, one by one the column lines are
brought low by the program and immediately the entire row is read
into a variable, before any discharged capacitors have time to charge
back up. The time from a "OUTL=$ff" to an "X=INH" is about 140
microseconds. A discharged capacitor will read low on its
corresponding input, while a charged capacitor will read high. Leave
the column line low for a few milliseconds to recharge all the
capacitors on that row back to +5 volts. Then, turn that column back
to an input, and on to test the next column. With this scheme you
should not scan too often, because there is a danger that the dart
will come along right at the instant you are recharging the
capacitors, and you will miss a hit that happens to come along at
that very instant. 0.1uf monolythic ceramic capacitors can hold
their charge for a minute or more at room temperature, if there are
not other leakage paths. Maybe it would work.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
disagreement is on the chip type. I personally use the Atmel AVR
because of their speed and low cost (in both hardware and
software). For the price of a PICBasic Pro compiler, you can get an
AVR development board, an AVR basic compiler (NOT PBASIC rip, uses
QBASIC syntax) and loads of chips to start you off. Better yet the
chips always use flash, so you can program them over and over again.
They are also faster than PIC because they can perform almost all
instructions in one clock cycle, rather than the 4 needed for all
PIC instructions. I wouldn't reccomend them as a replacement for the
stamp, but they are definitely great support chips. You can see
more info at www.avrfreaks.com which is an AVR website.
