Frqout problems
Hi Folks,
i tried to generate a frquence from the Stamp using the freqout command.
But whatever frequence I trie to get out it will always put out about 50
khz.
What am I doing wrong? Do I have to filter the output? How?
I would need to give out 0 to 10 khz.
Thanks for your help,
Uli
khz.
Uli
>khz.
>Uli
Hi Uli,
The freqout command generates sound by using PWM. The raw frequency
measured by a counter is very high, with fundamental components up to
110 khz. Yes, you need a filter, which might be as simple as a
10kohm resistor and a 0.01 uF capacitor. The filter also changes the
amplitude, decreasing the output at the 10khz end, so you may need to
compensate for that.
-- Tracy
