BS2 / BSX-Question
Hi Folks,
got a question: wrote a programm for BS2, works fine but I need more
programming space because I have to store a lot of Text to be displayed on a
LCD-screen. Therefore I changed the programm for the SX (changed baud-rates
and all and it works. BUT: when I look at the program-map it shows me the
space is as full as with the BS2.
1) is it really as full or is the map wrong?
2) isn't the BSX supposed to have eight times as much space?
3) Is it dangerous to try and stuff the programming-space till it spills?
4) By the way, is there another intelligent way of storinmg my sentences
instead of making a whole serout-command for each? can a sentence be a
constant?
Thanx a lot for help,
Uli
constant?
Uli
have 8x the space, but its not all one chunk. You can write your code to hop
from one slot to another, but you can't pass too many variables from slot to
slot.
Original Message
a
baud-rates
> constant?
Each of the 8 banks has its own map. You should read the manual,
BASIC Stamp Manual 2v0 , available online in the downloads section at
http://www.parallaxinc.com.
No, it will warn you. You can safely have a program that uses every
single byte of program space.
>constant?
The whole serout command is very inefficient at storing your data.
Store it as DATA, each string terminated with a null. Also a little
routine to read it out. (Each char in the whole serout command uses
14 bits of memory, while each char in DATA uses 8).
hi DATA "Hello there",0
bye DATA "goodbye now",0
printstring: ' enter with string number to print 1,2,...
lookup id,[noparse][[/noparse]hi,bye,...],adrs
printloop:
read adrs,char
if char=0 then exitprintloop
serout ... [noparse][[/noparse]char]
adrs=adrs+1
goto printloop
exitprintloop:
return
>Uli
I hope that helps,
-- Tracy
There was a fantastic exchange of messages starting around 8th May this year
that discussed (in some detail) hosting a program across multiple memory
slots. The subject started out as "[noparse][[/noparse]basicstamps] Multiple programs on the
BS2E" and turned into "[noparse][[/noparse]basicstamps] RE: program calling with BS2" (I think
Have a look back over these messages and see if that helps you.
Justin.
Original Message
From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=M9pK2KscbueRnUvALWm1nmmh--kmL-TwKSoPMJdF_QhX8RLs-gspnT7RHirn16NEUG-YZKxDSRvwkI_8tthArP1S1FyaJ_S5]ulibasic@r...[/url
Sent: 30 July 2001 19:26
To: basicstamps@yahoogroups.com
Subject: AW: [noparse][[/noparse]basicstamps] BS2 / BSX-Question
Hi all,
Tracy, thanx very much, using DATA has got me out of trouble but still I
would like to know about slots, couldnot find it in the Manual...could
anyone tell me on which pages I find it?
Thanx, Uli
Urspr
Original Message
I believe the SX has 8 program slots the size of the BS2 -- you technically
slot.
Thanks, Rodent,
but does anyone know how I adress these slots or where I can find a
description?
I think you'll find lots of informations about the BS2SX on Al Williams's
FAQ at http://www.al-williams.com/wd5gnr/stampfaq.htm
Have a look at http://www.emesystems.com/ too. That's where I learned many
tricks about the SX memory banks, cross-bank calls, global and local
variables...
Of course, the manual is also a good think to start with. I think there was
an addendum about the SX, but this should be included into the last version
of the manual. If you're using version 1.9, you need this addendum (i can
send it to you); or you should download the version 2.0 from Parallax.
When you look at the memory usage, you see only the space of one bank (2K).
So it looks the same as as BS2. But there is a drop down list, where you may
choose the bank you want to see. That's the point.
Hope this helps...
Best regards,
Phil.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, July 30, 2001 8:26 PM
> Hi all,
> Thanx, Uli
