serout debugging
Hi Brian,
For the SEROUT command to function, the SERIN line must be connected also.
The SEROUT uses the rest voltage of the SERIN line to function.
See stamp manual keyword SERIN and SEROUT.
Greetings peter.
Greetings peter.
I'm not sure how much control I have over the pin connections when using the
DB-9 on the BOE? Plus, it _does_ work talking to the PC. I'll read about
those commands more carefully...
Thanks!
-Brian
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, May 28, 2001 05:51 PM
Subject: [noparse][[/noparse]basicstamps] RE: serout debugging
> Hi Brian,
> Greetings peter.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
It works with both cables on the PC because the PC's TX and RX pins provides
the negative rest voltage
to the Stamp's RX pin and characters are echoed by Stamp on RX pin.
To be able to send commands to your switch device you need the following
connections:
Stamp's TX pin to switch device RX pin
Stamp's RX pin to switch device TX pin (for the required negative voltage)
Stamp's GND pin to switch device GND pin
Check cable for correct connections.
If your switch device has no TX pin you need to generate a negative voltage
otherwise.
(Try connecting Stamp RX to GND, this way Stamp TX swings between GND and
5V, may work.)
Greetings peter.
Forgive my density, but I still don't get it. [noparse]:([/noparse]
I'm using the stamp's built-in serial capability (Board of Education's DB-9)
so there is no wiring for me to do. I eventually want to use a different
pin, but I just want to get the comms working.
The switch device has TX, RX, and Gnd and works fine connected to the PC via
a NULL MODEM cable. What do I need to do to the built-in DB-9 to make the
wiring changes you mention?
-Brian
Original Message
Sent: Monday, May 28, 2001 07:26 PM
> Hi Brian,
provides
> connections:
voltage
> otherwise.
> 5V, may work.)
> Greetings peter.
If your switch device has a TX, the problem may be your cabling.
Assuming you have a null modem cable with 2 DB9 female connectors:
PC DB9 male switch device DB9 male
2 (RX)
(RX) 2
X null modem cable
3 (TX)
(TX) 3
5 (GND)
(GND) 5
PC DB9 male Stamp DB9 female
2 (RX)
(TX) 2
3 (TX)
(RX) 3
program cable
4 (DTR)
(ATN) 4 only required for
programming
5 (GND)
(GND) 5
As the null modem cable works between swich device and PC, the switch device
has a simular pinout as the PC. So to connect the Stamp to the switch device
you must use the same cable as between stamp and PC, i.e the program cable.
Switch device DB9 male Stamp DB9 female
2 (RX)
(TX) 2
3 (TX)
(RX) 3
program cable
4 (DTR)
(ATN) 4 must be disconnected or
held low
5 (GND)
(GND) 5
Be sure to disconnect the ATN line, keep the switch device DTR low, or place
a
capacitor in the ATN line. This prevents the stamp resetting. Best to make a
3-wire
cable for connection to switch device to avoid any problems.
Hope this clearifies the cabling.
Greetings peter.
Here's the testing I did.
I have two cables - the black one that came with the BOE and a grey one I
know is a NULL modem cable. I also have a NULL modem adapter for testing.
Connecting the BS2 to the PC, I tried 4 ways:
'Black' cable direct = comms ok
'Black' cable w/NULL MODEM = comms ok!
'grey' cable direct = comms ok
'grey' cable w/NULL MODEM (makes it a straight-thru) = comms ok!
That tells me that the DB-9 on the DOE sends on _both_ the TX & RX pins!?
Perhaps my switch doesn't like that.
Then I tried another test. I wired up a DB-9 connector with only 2 pins
connected = pin 5 to Vss (ground) and pin 3 to BS2-pin 15.
I then connected that DB-9 to the PC:
'Black' cable direct = No comms.
'Black' cable w/NULL MODEM = Comms ok!
'Grey' cable direct = Comms ok!
'Grey' cable w/NULL MODEM = No comms!
This is as I would expect and it also tells me that the black cable that
came with the BOE is a straight-thru.
Now, on to the switch. Connecting the BS2 to the switch in any of the four
combinations did not work. From this I have two guesses:
1. The switch does not like both TX/RX driven at the same time
and/or...
2. The switch (make in Europe) does not tolerate the 'non-standard' RS-232
(0-5V instead of -10 - 10V).
What do you think? Thanks so much for your patience...
-Brian
Original Message
Sent: Monday, May 28, 2001 08:24 PM
> Hi Brian,
> 2 (RX)
(RX) 2
> X null modem cable
> 3 (TX)
(TX) 3
> 5 (GND)
(GND) 5
> 2 (RX)
(TX) 2
> 3 (TX)
(RX) 3
> program cable
> 4 (DTR)
> programming
> 5 (GND)
(GND) 5
device
device
cable.
> 2 (RX)
(TX) 2
> 3 (TX)
(RX) 3
> program cable
> 4 (DTR)
> held low
> 5 (GND)
(GND) 5
place
> a
a
> 3-wire
> Greetings peter.
Cabling RS232 can be a real nag..
Anything send to the stamp is echoed directly back on the RX. This is how
the Stamp operates, sadly enough.
Does your switch send out data through its TX pin?
This data is echoed onto the RX and thus received by the switch.
Ok, pin5=GND and pin3=TX as seen from the stamp
>'Black' cable direct = No comms. --> obviously, stamp TX to switch TX
>'Black' cable w/NULL MODEM = Comms ok! --> TX/RX crossed, stamp TX to
switch RX
>'Grey' cable direct = Comms ok! --> TX/RX crossed, same as above
>'Grey' cable w/NULL MODEM = No comms! --> TX/RX crossed twice, stamp TX to
switch TX
It all makes perfectly sense!
Yes, the program cable is a 1 to 1 cable.
>and/or...
Both guesses may be true.
True RS232 requires voltages +3/+10 for a logic 0, and -3/-10V for a logic
1.
Therefore you should try the 3-wire connection I advised. It may be
necessary
though to add local RTS/CTS and DTR/DSR/DCD connections if your switch
requires
handshaking (check docu). So a complete cable should look like:
1 (DCD) ---+
2 (RX)
(TX) 2
3 (TX)
(RX) 3 must be disconnected if
switch sends data
4 (DTR) ---+
5 (GND)
(GND) 5
6 (DSR) ---+
7 (RTS)----+
8 (CTS) ---+
9 (RI)
However, if the switch sends data out through its TX pin, then you must
disconnect
this pin, which then leaves you with the negative voltage problem.
In that case a 9V battery with + to ground and - to Stamp RX might help.
(I would add a 1k series resistor to RX for safety).
Greetings peter.
