Outs, ins, dirs
On 25 May 01 at 17:14, tim@t... wrote:
> ...I used DIRS = 1 to set all the ports to output and assumed they all
> go low.
DIRS = 1 sets only I/O 0 to output and all other I/O pins to input.
To set all I/O pins to output: DIRS = $FFFF, or DIRS =
%1111111111111111.
> Using the TOGGLE command, everything works per design.
> My resulting code took up 19% of the memory (I'm using a BS2e and
> assume that is 19% of a 2k slot)
> If, however, I use the OUTS command with a binary list on 1's and
> 0's (a 1 lights the segment), it won't work unless I toggle a few
> ports first.
The TOGGLE command not only toggles the OUT value for the I/O pin,
it also sets the pin's DIR value to 1. So you are making the pin an
output because the TOGGLE command was used.
> I would have expected that use of OUTS = 1 would
> initially turn on all segments and the OUTS = 0 would turn them all
> off.
Note that the OUT value has no practical effect if the DIR value is
zero. Note further that OUTS = 1 sets I/O pin 0's output latch to 1
and all other output latches to 0.
Steve
> go low.
%1111111111111111.
> ports first.
> off.
Steve
I hooked up an 8 segment LED. I turn on the segments one by one,
then turn them back off in reverse order. I then turn them all on
and toggle them on/off for several iterations, then proceed to count
from 0 - 9. I'm using a common cathode (Radio Shack) LED.
I first coded this by using the TOGGLE command.
go low.
If, however, I use the OUTS command with a binary list on 1's and 0's
(a 1 lights the segment), it won't work unless I toggle a few ports
first. I would have expected that use of OUTS = 1 would initially
turn on all segments and the OUTS = 0 would turn them all off.
However, these statements appear to be ignored and the first
statements that have any effect are the TOGGLE. Once I have used
TOGGLE on the ports, then using DIRS works okay.
IE DIRS = %1100000000000000 will turn on two segments.
Obviously, I'm not understanding what is going on. Can someone
explain it? If I can use the DIRS statements, my memory requirement
drops to less than 9%. I'm trying to learn how to write good,
concise code.
Thanks!
Tim
The TOGGLE command just inverts the current state of the PIN -- if it was
high, it goes low and vice versa. Good for flashing an LED, etc..., but you
don't really know what state it is in -- not a good choice for some things.
Try using HIGH x or LOW x to turn on or off the pins as needed, where x is
the number of the PIN you are messing with.
Original Message
> go low.
and not as an input (high impiedance) you need ALSO to command DIR to be
an output. Remember also that DIRS=1 will only put in output mode just
the P0. To put ALL pins as outputs and in high state you will need these
2 commands:
DIRS= 65535 (16 bit decimal value to set ALL pins as outputs)
OUTS= 65535 (16 bit decimal value to set high ALL pins)
The toggle command when used will set the correspondent DIRx to be an
output (1) and this still setted after the command.
ACJacques
tim@t... wrote:
> I'm still new at this.
> go low.
> concise code.
> Thanks!
> Tim
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
count
Thanks for the inputs! Steve helped me grasp reality and understand
the errors of my ways.
Now things work as they should and I now understand why they do and
why they didn't before. Operator error was a major factor!
Thanks!
Tim
