One Shot Circuit Done With Software
Hi Gang:
Got an application going that is 96% complete. The subject is the missing
4%. What I am doing in a subroutine is looking at the status of a
pushbutton. On a 0 - 1 transition, I have the subroutine branch to another
subroutine, otherwise it goes back to the main program and life goes on.
What is presently happening is that when I keep the button pressed, the
program cycles and treats the continuously pressed condition as a 0-1
transition. I have used the PULSIN and BUTTON commands in the subroutine to
try and eliminate the continuously pressed condition without any success.
What I really want the program to do is only execute this part of the
program on a 0-1 transition. The continuosly on condition and the 1-0
transitions would be ignored. I know that I can solve the problem by
inputting the switch into a 555 timer which would output a 10 - 100 msec
pulse to a stamp input (the timer is set up as a one-shot circuit). I could
then use that input pulse in the program but the software approach would be
more practical. I also suspect that someone has already gone through this
headache and solved it; this is also probably a problem that is so simple
that it has me stumped. The other parts of the program were a real bear to
get going but I was able to solve those problems. Thank goodness for the
DEBUG command!
Any help would be appreciated. Thanks and regards,
Gerry Shand
gwshand@c...
(780) 471-0470
DEBUG command!
Gerry Shand
gwshand@c...
(780) 471-0470
you don't care about switch bounce, try something like this:
btndown var bit
btndown=0
<blah>
main:
' main loop
if button=1 then btnup ' assume button is input bit 1=up
' button is down
if btndown then btnnotdown
btndown=1
gosub mybuttonroutine
if button=1 then btnup ' in case button already released
goto btnnotdown
btnup:
btndown=0
btnnotdown:
<< whatever is in main loop >>
goto main
I think that would do it.
Al Williams
AWC
* Find out how to get NetPorter software FREE (for a limited time)
http://www.al-williams.com/awce/netporter.htm
Original Message
> From: Shand, Gerry W., Celanese/CA [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cSBQmY5fLMs5vE4Ww5C8uTrzcyS68gIN6BxLnZHCdpGag1oG86qVfJQjMwkz5O-_PIxKK8OTgmoH-g]gwshand@c...[/url
> Sent: Tuesday, May 22, 2001 8:47 AM
> To: 'basicstamps@yahoogroups.com'
> Subject: [noparse][[/noparse]basicstamps] One Shot Circuit Done With Software
> Hi Gang:
> subroutine to
> circuit). I could
> approach would be
> DEBUG command!
> Gerry Shand
> gwshand@c...
> (780) 471-0470
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Hi Gary,
Another way to do it, as a state machine, focuses the logic at one
point in the program:
bold var bit
bnew var bit
bx01 var bit
main:
bnew=in0 ' get state of button on P0
bx01=bnew ^ bold & bnew ' detect 01 xtion
bold=bnew ' update state variable
if bx01 then dobuttondownstuff
' do other main stuff
goto main
dobuttondownstuff:
' whatever
goto main
BUTTON command should also work for you (although I think most of us
don't use BUTTON unless we want the autorepeat capability.) Maybe
there was some error in your use of the syntax of the command.
BUTTON 0,1,255,0,X,1,dobuttondownstuff ' do it on 01 edge
Be sure the variable X is a byte and that the delay variable is set
at 255 (debounce enabled). I'm not sure how you would use pulsin
here.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
This is literally my first day noodling with a stamp and so far it is
a gas.
I'm replying to this message because I'm trying to do something
similar in a subroutine that takes the pin # as an argument. The idea
is I can call it like this:
Loop:
...do stuff...
' Check first button
BtnPin = 15
GOSUB PollButton
IF BtnPressed THEN DoSomething
' Check next button
BtnPin = 13
GOSUB PollButton
IF BtnPressed THEN DoSomethingElse
...do more stuff...
GOTO Loop
I want the subroutine to set BtnPressed to 0 or 1 if the button was
pressed. If it was pressed, I want it to wait until the button is
released before returning (the 0-1 thing).
I figured I wanted to use BUTTON for the debounce capability. Here's
what I have:
PollButton
' See if a button was pressed, and if so, loop until it is
' released so that it is 'one event'. Note that this will
' consume as much time as it takes for the user to release
' the button, once pressed.
' NOTE: This works for 'pull-down' button - 'ON' = 0
' IN parameters:
' BtnPin = Pin# to poll
' OUT parameters:
' BtnPressed = 1 if pressed, 0 otherwise
' USES Variables:
' BtnWork
BtnPressed = 0
BtnWork = 0
' 'Down' state is 0 (pull-up), debounce but no autorepeat
BUTTON BtnPin, 0, 255, 0, BtnWork, 1, ButtonPressed
' Button not pressed
RETURN
ButtonPressed:
' Button was pressed - loop until it is released
BtnPressed = 1
BtnWork = 0
StillPressed:
BUTTON BtnPin, 0, 255, 0, BtnWork, 1, StillPressed
' Button released
RETURN
But this returns right away and subsequent calls for the same pin#
see the closed switch as another press.
What am I doing wrong?
Thanks!
-Brian Smithson
I figured it out. Here's what I ended up with:
CheckButton:
' Because that sort of circuit is recommended in Edwards'
book.
' IN parameters:
' OUT parameters:
' USES Variables:
' BtnWork
BtnWork = 0
BUTTON BtnPin, 0, 255, 0, BtnWork, 1, CheckButton_Pressed
BtnPressed = 0
RETURN
CheckButton_Pressed:
' Button WAS pressed - loop until it is released
IF INS.LOWBIT(BtnPin) = 0 THEN CheckButton_Pressed
' Button has been released
BtnPressed = 1
RETURN
My problem was in trying to use BUTTON a 2nd time. The funky
INS.LOWBIT(#) syntax lets me get at a port with a variable. Cool!
-Brian
--- In basicstamps@y..., bsmithson@a... wrote:
> Hello everyone!
is
> a gas.
idea
> Loop:
> ...do stuff...
> BtnPin = 15
> GOSUB PollButton
> ' Check next button
> BtnPin = 13
> GOSUB PollButton
> ...do more stuff...
> GOTO Loop
> what I have:
> PollButton
> ' IN parameters:
> ' OUT parameters:
> ' USES Variables:
> ' BtnWork
> BtnPressed = 0
> BtnWork = 0
> RETURN
> ButtonPressed:
> BtnPressed = 1
> BtnWork = 0
> StillPressed:
> ' Button released
> RETURN
> Thanks!
> -Brian Smithson
I finally got the code to work. It took some doing and a combination of two
suggestions but I finally got it!
For anyone who is interested, this is what I came up with (keeping in mind
that there is always more than one way to make things work).
dirs=%0000000000000001 'sets P0 as an output
outs=%0000000000000000 'everything at zero to begin
with
set1 var bit 'variable declarations
ready var bit
n var word
main:
line1: if in1=0 then m1 'sets the circuit ready
line2: if (in1=1 and ready=1) then m2 'starts the program running when the
button is pressed
line3: if set1=1 then m3 'starts timing
line4: if n=20 then m4 'sets timing pulse range
line5: out0=set1 'sets output high
goto main
m1: ready=1
goto line2
m2: set1=1
ready=0
goto line3
m3: n=n=1
pause 1
goto line4
m4: n=0 'stops the timing
once n=setpoint (20 in this example)
set1=0
goto line5
Notes:
a. n = the amount of time in msec for the output pulse. In one of my
programs, I was able to get the circuit to work down to n=2 and it would be
tough to get this kind of precision in a 555 (from a repeatability
viewpoint, especially with thermal drift and component aging).
b. I tend to write my code like a PLC program because I do work with both
components for a living and I usually end up converting PLC code to use in a
stamp environment for dedicated embedded industrial controls. I make a nice
living doing that.
c. Murphy's law of programming: in solving the remaining 4% of the program,
you usually have to go back and change about 40% of the original program (an
iterative process).
d. This program works with gosub commands as well (that was a real skull
bender at first) if that's your preference.
Have fun. Cheers and regards,
Gerry Shand
gwshand@c...
res@c...
