AW: [basicstamps] One Shot Circuit Done With Software
Hi Garry,
I solved a similar problem by simply doing the routine once and then wait
for the button to go 0 again. only when it has turned 0 the next 1 can rerun
the loop again.
start:
if button = 1 then loop
loop:
'here comes the loop
hold_on:
if button =1 then hold_on
goto start
Does that match your purposes?
greetings, Uli
www.raumschiff-interactive.de
Urspr
the loop again.
start:
loop:
hold_on:
goto start
greetings, Uli
Urspr
the loop again.
start:
loop:
hold_on:
goto start
greetings, Uli
Urspr
Hi Garry,
the loop again.
start:
GOTO START 'this line was missing
loop:
hold_on:
goto start
greetings, Uli
Urspr
