Multiple programs on the BS2E
>Can someone shed some light on this for me. I have a bs2e running
>about 5 programs in different slots. Is there a way to be in say
>slot2 or program two, which ever is correct, and with a line of code
>tell it to go to say program4 but start at a certain line of code,
>like in the middle of the program, and not the first line?
Bank 4 has to be prepared with a BRANCH command that uses a variable
as a pointer to the target routines:
' in bank 4
BRANCH BSxto,[noparse][[/noparse]routine0,routine1]
routine0:
' stuff
routine1:
' stuff
The program in slot 2 has to that variable before it switches banks:
' in bank 2
BSxto = 1 ' will cause branch to routine1 in bank 4
RUN 4
The variable BSxto has to be in the same position in both banks 2 and
bank 4. More info on one approach to all this at:
http://www.emesystems.com/BS2SX.htm
-- Tracy Allen
' in bank 4
routine0:
' stuff
routine1:
' stuff
' in bank 2
RUN 4
-- Tracy Allen
