Connector hole pattern
Howdy Stampers,
I am looking for a male db9 connector or a
rj-14 connector or such that I can mount to
a PCB with straight connections without the
staggered hole pattern. Unless the board is
geared for it, the staggered hole pattern
does not work with the standard .100 (100 mil)
matrix hole spacing of the boards I have.
Does anyone know of a manufacturer that
accomodates a connector that will plug
directly into a solderless breadboard?
Bandit
If you understand, things are just as they are.
If you do not understand, things are just as they are.
Bandit
Our ASP-II brings the pins that are important for the Stamp into a straight
format for a breadboard. In particular, it connects 2, 3, 4, 5, and shorts 6
& 7.
http://www.al-williams.com/awce/asp2.htm
Meant for Stamp prototyping, but I use it to connect all sorts of serial
stuff to a breadboard.
Al Williams
AWC
Expand your Stamp I/O!
http://www.al-williams.com/awce/pak3.htm
Original Message
> From: Sample Bandit [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=D0tOGP5xSDFOD2HkbslvnDjbQRzN7sCJPeAH-bZU6tS3onjAF6iLZQjiQUqTEFdiccwwXuXZheA]tesla@i...[/url
> Sent: Friday, May 04, 2001 10:31 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Connector hole pattern
> Howdy Stampers,
> Thanks,
> Bandit
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks for the quick reply and that looks like the
puppy I had in mind but ouch! $15?
I could buy 4 AVR's for that!
Looks like I may be breaking out some pliers and bending
the pins of a regular db9 to fit.
Bandit
At 10:40 AM 5/4/01 -0500, you wrote:
>Bandit,
>& 7.
>Regards,
>Al Williams
>AWC
Original Message
>> From: Sample Bandit [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JddonlNUJV4BcCmntTAedw4_JQgdrHg1Jd4CJ1iaLfaTcysVwfgkUyfJfVCpm53KFGlBiPQ]tesla@i...[/url
>> Howdy Stampers,
>> Thanks,
>> Bandit
nice support :-)
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: Sample Bandit [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hPL8aiqjih6HrMwGgApsRwmDAXQE8EwD8sL-c_jotG-gUMGkaE4MeVCDavVYTLgYJla4b08]tesla@i...[/url
> Sent: Friday, May 04, 2001 10:54 AM
> Subject: RE: [noparse][[/noparse]basicstamps] Connector hole pattern
> Al,
> Bandit
> >Bandit,
> a straight
> and shorts 6
> >& 7.
> >Regards,
> >Al Williams
> >AWC
Original Message
> >> Howdy Stampers,
> >> Thanks,
> >> Bandit
works like a charm. The other end of the ribbon cable has a DB9 connector.
See a photo of my processor board at:
http://robostuff.com/dprg/bill_boyer/cpu-1.htm
Original Message
········Would youtell us where you got the connectors that you used on your processorboard for the motor, I/R and ultrasonic hook-ups?· Did they come asmatched sets - male and female?
Tim
At 12:10 PM 5/4/2001 -0500, you wrote:
works like a charm. The other end of the ribbon cable has a DB9connector.
·http://robostuff.com/dprg/bill_boyer/cpu-1.htm
Original Message
Your use of Yahoo! Groups is subject tohttp://docs.yahoo.com/info/terms/
Timothy Medema
CrystaLite, Inc.
3307 Cedar St.··················(425) 745-6000·· 800-666-6065
Everett, WA 98201···············Fax: (425) 257-0232
www.crystaliteinc.com···········timm@crystaliteinc.com
The information transmitted is intended only for the person or entity to whom it is addressed and may contain confidential and/or privileged material.· Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited.· If you received this in error, please contact the sender and delete the material from any computer.
separate. I ordered 10 of each header and shell, and 150 of the contacts I
think it works out to about 50 cents per connector.
Headers (the part with the pins that goes on the board)
4-pin header 538-22-23-2041
3-pin header 583-22-23-2031
Connector Housing (the part that plugs into the header)
4-pin 538-22-01-3047
3-pin 538-22-01-3037
Contacts (the part the wire is soldered to that fits in the shell)
538-08-50-0114
Original Message
> Would you tell us where you got the connectors that you used on
> your processor board for the motor, I/R and ultrasonic hook-ups? Did they
> come as matched sets - male and female?
Thank you much,
Tim
At 01:44 PM 5/4/2001 -0500, you wrote:
separate. I ordered 10 of each header and shell, and 150 of the contactsI
·538-08-50-0114
Original Message
>········· Would you tellus where you got the connectors that you used on
> your processor board for the motor, I/R and ultrasonichook-ups?· Did they
Timothy Medema
CrystaLite, Inc.
