Counter with serial output?
Can anyone recommend a 12-bit (or higher) ripple counter IC which has
serial output? Thanks!
steve
Steve Roberts: sroberts@s...
steve
>serial output?
Steve,
Nothing comes to mind. Like a lot of other requirements mentioned here from
time to time, it may not exist as a pre-packaged logic component. You could
certainly make one with a CPLD, however, and bundle the rest of your logic
with it! I see that Electronix Express is offering CPLD prototyping systems
at extremely reasonable prices. If you want to learn the technology,
there's no better time to do it.
Here's the link: http://www.elexp.com/tst_pldt.htm
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
How fast does it need to count? Input duty cycle?
I could see an 8 pin 12c508 or 12c671 do this quite easily for slow speeds
(less than 1 MHz). Faster than that - I'd look at doing it in a CPLD - my
current favourite is the EPM7032SLC44 from Altera. Cheap, easy to code,
easy to program, fits in a 44 pin PLCC socket. You can clock those quite
fast - 50 or 60 MHz.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 17 years of Engineering Innovation (1984 - 2001)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
I'm not sure if this may help, but take a look at the following link
http://www.phanderson.com/counter.html
Also, philips makes a serial real time clock PCF8593 (I2C) which has an
event counter mode. I've been wanting to try one of these for some time.
Steve
>>serial output?
>Steve,
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>dwayne
Needs to count at about 5 MHz, at a 50% duty cycle.
Ubicom's SX series can handle it, and they can be programmed with simple
tools from Parallax.
My personal preference would be an Altera EPM7032S, as mentioned by another
contributor. This logic chip could, ferinstance, support a 16-bit counter
and a 16-bit parallel-in serial-out shift register. A multiplexer could
replace the shift register, allowing the counter chain to get even longer,
but then your count could change during readout. Either way, using Altera's
(free) MaxPlusII tools, the design job is trivial. You just need a device
programming adapter cable, and that should be fairly simple to fabricate.
Altera was charging $150 for it (ByteBlaster) last I knew...
