Checking time
I think this will do what you're after:
task_done VAR BIT
task_time VAR BYTE
task_interval CON 30 ' or whatever
[noparse][[/noparse] get min ]
IF min >= task_time THEN checkTask
task_done = 0
GOTO continue
checkTask:
IF task_done = 1 THEN continue
[noparse][[/noparse] do task ]
task_done = 1
task_time = task_time + task_interval // 60
continue:
Steve
task_done VAR BIT
task_time VAR BYTE
task_done = 0
GOTO continue
checkTask:
task_done = 1
continue:
Steve
one function that I need to do on an interval of 30 min or greater. In
writing code to check the clock I find that I have a page of if then
statements.
I will need to check the minutes if the minutes are less than the last
saved minutes,
I will need to check the hours, if the hours are less than the last saved
hours then
I will need to check the days if the days are less than the saved day then
I will need to check the months if the month is less than the last saved
month
I will need to check the year
Does anyone have a quick and dirty way of doing this without using so many
if then statements is there a way of adding all the values up
and subtracting one time ?? something like below and also in a smaller
size to fit the stamps 65535 limit
old value
min = 12
hour = 24
day = 6
month = 11
year = 01
old value = 0111062412
new value
min = 04
hour = 23
day = 8
month = 11
year = 01
new value = 0111082304
year month\day hour\min
new date 01 1108 2304
last saved date 01 1106 2412
________________________________________________________________________________\
_
subtract 00 0002 -108
so what would be the next step
"L .Gaminde" wrote:
> Im using a DS1302 RTC I have a program that does a number of things, I have
> statements.
> saved minutes,
> hours then
> month
> old value
> min = 12
> hour = 24
> day = 6
> month = 11
> year = 01
> new value
> min = 04
> hour = 23
> day = 8
> month = 11
> year = 01
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
minutes between 1 and 59 minutes, you could ignore all the other pieces of
the date-time and focus on the minutes byte only. For example,
if oldMM > newMM
then diffMM = newMM + 60 - oldMM
else diffMM = newMM - oldMM
endif
if diffMM > intervalMM
then do function
endif
Basically, the pseudocode checks if the minutes register experienced a
wrap-around since the last time check, and calculates the difference between
the old time and time new time.
This technique requires that the interval AND the checks for the interval
expiring be less than 60 minutes long. Also note that the resolution of
this method will never be less than 1 minute.
Daniel McGlothin
Original Message
From: L .Gaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8I9iqvI_cNICroJrOlS4XCET1Mz2uAaWH3TFQ-5uPmxGUuEPbAxfy83rVQv4QtYxsKNW9QFZPdm-KHC5EnDP]lgaminde@t...[/url
Sent: Thursday, April 19, 2001 2:42 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Checking time
maybe something like this Is this a good way of thinking or not
_____
have
> statements.
> saved minutes,
> hours then
> month
> old value
> min = 12
> hour = 24
> day = 6
> month = 11
> year = 01
> new value
> min = 04
> hour = 23
> day = 8
> month = 11
> year = 01
the next time could be the next day or one month from the last sense, not
likely but possible, Im trying to think of the worst case. Now I could do
this for all the values start with year,month,day,hour,min. If I would do
it like I had it laid out in year, month\day, and hour\min, I would take
the 0002 value and multiply by 24 for hours times 100 plus the 2304
hours\minutes then subtract the 2412 hours \ minutes of the last saved date
Im really not sure if im on tract here of If im going to see some major
screw up later in the coding. like below to keep carry over the month to
days I will need to know the number of days in each month, am I making this
harder than it really is ????
something like this
last saved time 24:59 12-31-01
new time read 01:01 01-01-02
"D. Daniel McGlothin" wrote:
> Assuming that you need to do the function on a regular interval of any
> if oldMM > newMM
> endif
> then do function
> endif
> Regards,
> Daniel McGlothin
Original Message
> From: L .Gaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-sI39hgDS0hd5GrDakRpSF_Y_3MmBb4S9bl89_4creAw6EMLwheRKceoaLRho8Znc2-9fCopOlw73OkKNw]lgaminde@t...[/url
> _____
> have
> > statements.
> > saved minutes,
> > hours then
> > month
> > old value
> > min = 12
> > hour = 24
> > day = 6
> > month = 11
> > year = 01
> > new value
> > min = 04
> > hour = 23
> > day = 8
> > month = 11
> > year = 01
>statements.
Hi Larry,
I like to make a conversion to Julian date/time in the subroutine
that reads the real time clock. That gives a single monotonically
increasing number to deal with in the rest of the program. The
action at intervals is then simply a question of divisibility.
if timenumber//interval=0 then its_time_now
In data loggers, I am using intervals that can range from 1 minute to
6 hours, so I use the code:
julian1 = hour*60+minute
where hour is from 0 to 23 and minute is from 0-59, so Julian goes
from 0 to 1439, from midnight to 11:59pm (Be sure to use standard
values in the calculation, not bcd coded values.) Then you have a
choice of a lot of intervals that divide 1440 evenly:
1,2,3,4,5,6,10,15,20,,30,60,120,180,240,360 minutes and some others.
Then:
if julian10//30=0 then do30minutestuff
If you need seconds, you can get down to 2 second intervals, and
still fit it into one 16 bit word. (43200 2-second intervals in a
day) 10 minute intervals will carry you for a year in one 16 bit
word. (52560 10 minute intervals in a leap year).
A BASIC Stamp formula for day of year (0 to 364 or 365) given YY
(year) MM (month) and DD (day) is:
JD=MM-1*30+(MM/9+MM/2)-(MM max 3/3*(YY//4 max 1 +1))+ DD
For explanation see,
http://www.emesys.com/BS2math4.htm#JulianDate
Then to resolve to 10 minute intervals, take the above JD value and
roll in the time:
julian10 = (JD * 144) + (hour*6) + (minute/10)
This julian10 value should be updated every time the program reads
the clock, and it has a new value for every 10 minutes in the current
year.
If you need to set an alarm for a specific time in the future, run
the future date/time through the above formula to get one number,
then check for equality.
if alarm=julian10 then doAlarm
I hope that helps,
-- best regards
Thomas Tracy Allen PhD
electronically monitored ecosystems
http://www.emesystems.com
mailto:tracy@e...
will look this all over for a few days ( few meaning anything from 10 to
300 Julian days ) and probably have some more questions.
thanks again
Larry Gaminde
> >statements.
> Hi Larry,
> Then:
> roll in the time:
> year.
> I hope that helps,
> -- best regards
> mailto:tracy@e...
