boebot IR sensors
HI all: I see on the BoeBot, Parallax uses small IR sensors, about the size
of an LED.
Where are these small sensors sold? I cannot use the larger tincan style IR
sensor for my application.
Sincerely
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
of an LED.
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
Original Message
size
> of an LED.
IR
Just last week, I was just investigating the RS IR sensor pair that you mention
below, and I decided that it was a lot of hard work and required several chips,
soldering and lots of additional understanding. I downloaded the data sheets
for these two items and found I need several extra chips. So I've decided that
buying a Sharp IR sensor was the way to go for my needs. And I understand it a
bit better.
Since you recommend the RS hardware, I'm now wondering if I haven't missed
something by not using the Sharp's ready to go sensor.
As always,
Thanks for the help.
Dave
--- Rodent <daweasel@s...> wrote:
> Radio Shack. They sell an IR diode / photo transistor pair.
Original Message
> size
> > of an LED.
> IR
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__________________________________________________
Do You Yahoo!?
Yahoo! Auctions - buy the things you want at great prices
http://auctions.yahoo.com/
hardware for its IR system, it has a 3 lead IR receiver, about the size of
an LED.
The RS tincan style digital output reciever is fine, but to large for my
applications.
At 01:11 PM 4/18/2001 -0700, you wrote:
>Hi,
>bit better.
>As always,
>Dave
Original Message
>> size
>> > of an LED.
>> IR
>Do You Yahoo!?
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
Kerry Barlow wrote:
> I also do not understand this. The boebot does not use any extra support
> an LED.
> applications.
> >Hi,
mention
chips,
that
a
> >bit better.
> >As always,
> >Dave
Original Message
> >> size
> >> > of an LED.
> >> IR
> >Do You Yahoo!?
> Sincerely
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
connection to the base, which was not normally used, since the I/R signal
biases the base -- this is apparently not the case for the ones include with
the BOEBOT.
I checked the Robotics 1.2 Experiments 1-4 on the Parallax web site, and it
indicates the I/R receivers used with the BOEBOT do look for a 38 Khz
signal. The I/R diodes on the BOEBOT are modulated to 38 Khz with a 555
timer chip.
The tin can receivers are usually designed to receive a 38 or 40 Khz
modulated I/R signal, like you would receive from a TV remote control.
Original Message
> an LED.
> applications.
> >Hi,
mention
chips,
sheets
decided that
understand it a
> >bit better.
missed
> >As always,
> >Dave
Original Message
the
> >> size
> >> > of an LED.
style
> >> IR
> >Do You Yahoo!?
> Sincerely
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
TO-3p or TO-220 package. If you open the tin can up you will see the sensor
its made for 40khz and a op-amp I think.
> an LED.
> applications.
> >Hi,
mention
chips,
that
a
> >bit better.
> >As always,
> >Dave
Original Message
> >> size
> >> > of an LED.
> >> IR
> >Do You Yahoo!?
> Sincerely
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
have 3 leads, and a digital output. Of course the Boebot manual does not say
where these detectors come from, and I cannot find them on the parallax site
either. Possibly they come with the BoeBot kit?
At 01:23 PM 4/18/2001 -0700, you wrote:
>Isn't the tin can style modulated at 40khz, and the other sensors are not ?
>> an LED.
>> applications.
>> >Hi,
mention
chips,
sheets
decided that
understand it a
>> >bit better.
>> >As always,
>> >Dave
Original Message
>> >> size
>> >> > of an LED.
>> >> IR
>> >Do You Yahoo!?
>> Sincerely
>> Kerry
>> Admin@M...
>> Kerry Barlow
>> p.o. box 21
>> kirkwood ny
>> 13795
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
listed under LED's, not under sensors DOH
here is the part number for anyone interested.
Infrared receiver #350-00014 0.01 lbs. $1.80
At 01:30 PM 4/18/2001 -0700, you wrote:
>I do also have sensors that are modulated and look like large transistors,
>> an LED.
>> applications.
>> >Hi,
mention
chips,
sheets
decided that
understand it a
>> >bit better.
>> >As always,
>> >Dave
Original Message
>> >> size
>> >> > of an LED.
>> >> IR
>> >Do You Yahoo!?
>> Sincerely
>> Kerry
>> Admin@M...
>> Kerry Barlow
>> p.o. box 21
>> kirkwood ny
>> 13795
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
Original Message
> WAY HAY, success. I found the IR receiver sold on the parallax site, it
was
and they are $2.40 each, not $1.80
I am glad money grows on trees [noparse]:)[/noparse]
At 03:45 PM 4/18/2001 -0500, you wrote:
>Sounds like Parallax needs to hire us for support.
Original Message
>was
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
We sell both shrink wrapped IR LEDs and IR detectors (equivalent to the
Panasonic PNA 4602) on our www.parallaxinc.com Products page. Follow the
Optoelectronics link near the bottom of the Products page.
Clarification regarding modulation. If you are sending a square wave out
the IR LEDs, 40 kHz is center frequency for the detectors we sell. If you
are using the "freqout trick" documented in chapter 6 of Robotics! v1.3 or
v1.4 for a vague form of distance detection, you can get a rough idea of the
distance of an object using the values supplied in the text. Attempting to
fine tune for higher distance resolution or for use outside this educational
application is not recommended.
Another thing about modulation, make sure the square wave is close to 50%
duty cycle. Deviating too far from 50% causes the IR detector output to get
stuck sending an active-low IR detected signal.
Andy
E-Mail...........alindsay@p...
Parallax, Inc. home page....................www.parallaxinc.com
BASIC Stamp Educational Resources...........www.stampsinclass.com
SX Microcontroller University Resources.....www.sxtech.com
Original Message
From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=V2s252pmg4sbp7ELSbINqUJK2xWjsjrRlzd0M4sPdoYgopJY5DCR1i4BXFcZ9fty7dTRkFFl1-kFAA]admin@m...[/url
Sent: Wednesday, April 18, 2001 12:25 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] boebot IR sensors
of an LED.
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
inaccurate price on the webpages. They are going to charge me the posted web
price, and will update the pages to reflect the new price. I consider this
decent of parallax.
-Kerry
At 02:05 PM 4/18/2001 -0700, you wrote:
>Kerry,
>Andy
Original Message
>From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0xEmFXPd1PyiIuKqTRQJF3BY2Wml-NDh-UAFW8Hl7RouOe2pQfjPCBEqXuqrFm13O27oez-0ftzvGuI3]admin@m...[/url
>of an LED.
>Sincerely
>Kerry
>Admin@M...
>Kerry Barlow
>p.o. box 21
>kirkwood ny
>13795
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
On a parallel path, I forwarded the nominal vs. actual price e-mail to our
webmaster.
Andy
Original Message
From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1rS8dpVDy-lvSrx5xJVAWb3wTFPeIc50A7UevM_KoHpZIB57HaqPrdg7lM8ioni2Frt3yBOCfPDE]admin@m...[/url
Sent: Wednesday, April 18, 2001 2:36 PM
Subject: RE: [noparse][[/noparse]basicstamps] boebot IR sensors
Andy: Thank you for your response. I also wrote to Sales, regarding the
decent of parallax.
-Kerry
>Kerry,
the
educational
get
>Andy
Original Message
>of an LED.
>Sincerely
>Kerry
>Admin@M...
>Kerry Barlow
>p.o. box 21
>kirkwood ny
>13795
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
daweasel@swbell.net writes:
> of an LED.
IR
The IR diodes are off-the-shelf (you can get them from Radio Shack). ·The
receivers are made by Panasonic (PNA4602) and are available from Parallax and
other sources.
[/font]
Original Message
From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ejkdSfrd-ELsee4JtKYtCZxAzYVlHoVpiV7wOcudVZnJjcuMf5dh_QNDkCF3GmAdYavRK5jzKg]admin@m...[/url
Sent: Wednesday, April 18, 2001 2:25 PM
size
of an LED.
IR
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
