Recommendations please :-)
Hello,
I was hoping to get recommendations on what hardware would satisfy
the needs of a beginner. I'm a complete newbie who knows nothing
about microcontrollers, and was hoping that someone could give me an
idea about where to start.
My immediate project only entails very simple control commands. The
idea is to somehow connect a microcontroller to 4 different leaf
switches, so I can close and open any of the 4 circuits in any of *14
different pre-programmed sequences*. Each sequence will have as many
as 66 total commands, and will be executed within approximately 2
minutes. I want to be able to "press a button" at anytime along a 5
hour time-line to activate any of those 14 command sequences with
timing accuracy between each individual command no worse than 1/60th
of a second(within that sequence).
The microcontroller will in effect be duplicating the exact timing of
the commands in each sequence.(Commands that I will like to manually
program into it via the four leaf switches I mentioned).
Am I asking too much?
Any advice would be greatly appreciated.
Thank you for your time
Darren Harris
Staten Island, New York.
Searcher7@m...
Darren Harris
Searcher7@m...
Darren Harris
Searcher7@m...
Hardware selection depends upon what type of loads you are switching, and
exactly what you mean in the timing you describe. Some timing requirements
may create difficulties with a Basic Stamp, they're not super-fast, and RT
requires additional hardware. If what you described means that it would be
acceptable if the sequence of switch actions occur within 16 mS of each
other in sequence, this can be done. Your 5 hour time line is not clear and
may also be a problem.
What exactly are you trying to build? Without more details or a more
specific question, you might wind up re-posting this 100 times w/o getting
the help you want...
Chris
> Hello,
> Thanks
> Darren Harris
> Searcher7@m...
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
you are switching,
and exactly what you mean in the timing you describe."
The loads are not at present an issue. After I figure
out what electronic components(microcontroller) to
get, I will have to figure out a way to interface it
to the leaf switches I mentioned. The only "input"
criteria for the microcontroller would be to accept
any of 8 possible commands it will receive when I
manually close and open any of four circuits. The more
difficult part would be the output of any of those 8
commands, since these circuits(leaf switches) have to
by physically closed in order for the PCB on the other
end to notice, I'd have to come up with a way to send
a strong enough current through the wires to fool
it.(I'm actually going to be using the 4-way joystick
controls of an arcade game).
I don't understand your question about the timing. If
I were to "open", let's say switch "B" exactly 1.2
seconds after I closed it, I want to microcontroller
to output the same(to an accuracy of no worse than
1/60th of a second) when I give it the command to do
so. Actually, the longest of the 14 sequences will be
112 different commands in about a two minute
period.(And only 1 of the 4 circuits can actually be
"closed" at one time).
"Some timing requirements may create difficulties with
a Basic Stamp, they're not super-fast, and RT requires
additional hardware."
That is why I'm trying to find out what I'd need to
accomplish what I want.(And what is "RT"?).
"If what you described means that it would be
within 16 mS of each other in sequence, this can be
done. Your 5 hour time line is not clear and may also
be a problem."
Then forget I mentioned the 5 hour time line. :-)
"What exactly are you trying to build? Without more
details or a more
100 times w/o
getting the help you want..."
I honestly don't know what I haven't covered, or how
to explain anything more clear than I already have. It
is a very simple project.
Darren Harris
Searcher7@m...
--- "Chris Loiacono (E-mail)"
<chris01@t...> wrote:
> > Darren:
> details or a more
> Chris
> > Hello,
> knows nothing
> different leaf
> will have as many
> approximately 2
> anytime along a 5
> sequences with
> worse than 1/60th
> the exact timing of
> mentioned).
> > Thanks
> > Darren Harris
> > Searcher7@m...
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/
interrupts. This implies that you will need to loop through the 4 inputs
continuously and check their state. As long as the program doesn't take more
than 16mS to loop, which is a long time- even for a stamp, you should be OK.
The 'button' instruction will help you 'debounce' your manual switches.
If the toughest loop is 112 commands in 2 minutes or less, you're talking
more than 1 second per, so it also is not too fast. More effort will go into
making it take 2 minutes, if that's what you need. Just realize that again,
while the 112 instructions are executing in their own loop, the only thing
the stamp can do is wait for the loop to execute, or be reset.
If I were you, I'd read the manual and 'stamps in class' downloads at
www.parallaxinc.com
CL
Original Message
> From: Darren Harris [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=anHd1JeNiA_zh2b4Vpqne8Ivd0rDc0D18cPa5IWKHwQO6zEIEGLkfKu0w9_7Q35XtFyZHzdOyCwtUfY]searcher731@y...[/url
> Sent: Thursday, April 12, 2001 11:58 AM
> To: basicstamps@yahoogroups.com
> Subject: RE: [noparse][[/noparse]basicstamps] Recommendations please :-)
> "Hardware selection depends upon what type of loads
> you are switching,
> be a problem."
> details or a more
> 100 times w/o
> Thanks
> Darren Harris
> Searcher7@m...
> > > Darren:
> > details or a more
> > Chris
> > > Hello,
> > knows nothing
> > different leaf
> > will have as many
> > approximately 2
> > anytime along a 5
> > sequences with
> > worse than 1/60th
> > the exact timing of
> > mentioned).
> > > Thanks
> > > Darren Harris
> > > Searcher7@m...
> Do You Yahoo!?
that there are no
continuously and check their state."
Providing I understand you correctly, is this a manual
process or will the Basic Stamp do this?
"As long as the program doesn't take more than 16mS to
should be OK."
"The 'button' instruction will help you 'debounce'
your manual switches."
This is all Greek to me.
"If the toughest loop is 112 commands in 2 minutes or
less, you're talking more than 1 second per, so it
also is not too fast. More effort will go into making
it take 2 minutes, if that's what you need."
It is not the length of time. I just said that a
sequence may take about 2 minutes.
"Just realize that again, while the 112 instructions
are executing in their own loop, the only thing the
reset."
I assume that this means that it will follow the
sequence I initiate to it's end, or I can manually
reset, and start it(or another sequence) over?
"If I were you, I'd read the manual and 'stamps in
class' downloads at www.parallaxinc.com"
I don't understand much of what you said, but I will
check out the manual you mentioned.
Nevertheless, here is just one more clarification of
the basics of what I'm attempting...
***Years ago there was a multiplayer "family" game
advertised on T.V. It entailed a device that would
flash lights in a certain sequence. The player would
then have to remember and duplicate that sequence by
pressing the corresponding lighted buttons. The
farther you got into the game the longer the sequence
of lights you had to duplicate.(The more difficult it
became).
Now if you can imagine the computer in the human's
place, and vice-versa, you will understand bacically
what I'm attempting to accomplish. I will be using a
4-way joystick to "input" 14 separate sequences
containing many "on" and "off" commands to all 4
connections.(As I said, each sequence will last a
maximum of about 2 minutes, and have a total of 112
commands). Now, when I press one of 14 buttons, it is
the microcontroller that will have to duplicate the
corresponding sequence to within 1/60th of a
second(between each and every command in that
sequence). So for example, if I'm using it on a game
like Pacman, the microcontroller will be able to
"repeat" any of my patterns, because I would allow it
"read" and remember my joystick movements. It will
then "output" any of the 14 programmed patterns when I
press the corresponding button.
Darren Harris
Searcher7@m...
> The Basic Stamp 2 will do this as long as you
> realize that there are no
> be reset.
> class' downloads at
> www.parallaxinc.com
> CL
Original Message
> > From: Darren Harris [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=f1OWD_l6vjw49Z_5ekrQEx7WjDwH5vH3aKFVccyCY0FZ1YVBgYeFSPcYXSmtjMYFGuFxHL0gu1lDr_qN5A]searcher731@y...[/url
> loads
> > you are switching,
> describe."
> figure
> it
> accept
> more
> 8
> to
> other
> send
> joystick
> If
> microcontroller
> do
> be
> be
> with
> requires
> to
> be
> also
> > be a problem."
> more
> > details or a more
> this
> > 100 times w/o
> how
> have. It
> > Thanks
> > Darren Harris
> > Searcher7@m...
> > > > Darren:
> loads
> describe.
> they're
> described
> occur
> more
> > > details or a more
> this
> > > Chris
> > > > Hello,
> who
> > > knows nothing
> to 4
> > > different leaf
> sequence
> > > will have as many
> within
> > > approximately 2
> at
> > > anytime along a 5
> command
> > > sequences with
> command no
> > > worse than 1/60th
=== message truncated ===
Do You Yahoo!?
So basically you want to 'Record' the movement of the joystick for later playback.· In order to do this, you will have to have two 'modes', a record mode and a playback mode. This would have to be switchable via a switch, or maybe a pushbutton that would initiate a 'record' sequence.· Then you will also need a way of choosing which sequence you want to play back, and this could be as simple as a number of pushbutton switches.
You would have two sections to the program that ran on the stamp.
The first would be the recorder and it would be initiated by the record button.· You would then move the joystick around and the stamp would scan the joystick switches on the joystick as quickly as it could and store the state of the switches into some sort of a storage device. This portion contains a potential problem, because each sample will have to be stored for later playback and you could potentially have a large amount of storage required.· If you are sampling at 1/60 of a second, you will have 4 bits of data for every 1/60 of a second which comes out to 30 bytes per second or 1.8K per minute. That means that each 2 minute sequence will require 1.8K of storage.· This will exceed the internal storage ability of the stamp and will require an external storage device.· There may also be problems storing this data fast enough to get it saved and then be ready to scan the joystick switches again within the 1/60 of a second time frame.· The record process could be terminated by pressing one of the buttons that are used for playback. Once this button press was complete the sequence could be assigned to that button for playback.
The playback portion would wait for a button press and when a button was pressed, it would retrieve the data from the external storage device and configure it's pins for outputs.· It would then run through a loop and every 1/60 of a second it would retrieve and 'playback' the stored sample for that time period.
Basically what you are trying to make is a 4 bit digital recorder.·
Someone mentioned 'debouncing'. This refers to the fact that a switch doesn't make a clean on/off transistion.· It arcs and springs and makes dozens of contacts for each press of the switch.· The stamp is fast enough that it can detect these millisecond long contacts.· One switch press could be detected as 10 or 20 or more presses because of this effect.· I wouldn't worry about this though. What you are trying to do is record the actual movement of the switches on the joystick. The video game that you are playing back into expects the signals to be noisy and will be able to handle it.
Your main problems are going to be timing and storage.· Getting the playback to happen at the same speed as the recording will be difficult.· You will have to do some research and find out how long each instruction takes and make sure that your playback and record loops have the EXACT same execution times.
Interupts were also mentioned.· What this means is that there are two methods of letting a microcontroller know that something has happened that needs it's attention.· With the basic stamp the only way that really exists is for the stamp to be in a loop (a section of code that executes over and over) and just keep looking at an input over and over again until it gets pressed and then it knows it needs to do something.· Other Microcontrollers support interupts which are a special input to the microcontroller that will 'interupt' what the processor is doing and FORCE it to execute a section of code when the input happens.· This way the processor doesn't have to worry about whether or not any inputs have been pressed until it is interupted and then has to deal with it.· This is not an option on the stamp.
--Scott
Original Message
From: Darren Harris [noparse]/noparse][url=mailto:searcher731@yahoo.com]mailto:searcher731@yahoo.com[/url
Sent: Thursday, April 12, 2001 10:18 AM
"The Basic Stamp 2 will do this as long as you realize
that there are no
should be OK."
reset."
became).
Darren Harris
Searcher7@mail.con2.com
> be reset.
> class' downloads at
> www.parallaxinc.com
> CL
Original Message
> loads
> > you are switching,
> describe."
> figure
> it
> accept
> more
> 8
> to
> other
> send
> joystick
> If
> microcontroller
> do
> be
> be
> with
> requires
> to
> be
> also
> > be a problem."
> more
> > details or a more
> this
> > 100 times w/o
> how
> have. It
> > Thanks
> > Darren Harris
> > > > Darren:
> loads
> describe.
> they're
> described
> occur
> more
> > > details or a more
> this
> > > Chris
> > > > Hello,
> who
> > > knows nothing
> to 4
> > > different leaf
> sequence
> > > will have as many
> within
> > > approximately 2
> at
> > > anytime along a 5
> command
> > > sequences with
> command no
> > > worse than 1/60th
Do You Yahoo!?
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Am I right in thinking that you want to 'record' up to 14 different 'tracks'
each track at most 2 minutes long with a max of 112 moves of the joystick.
([noparse][[/noparse]UP 1.2s] - [noparse][[/noparse]DOWN 0.2] - [noparse][[/noparse]LEFT 1.4s] = 3 moves).
Then when it's done you would like to select which of the 14 tracks you want
to 'play back' and press the 'play button'.
Is this what you like to do?
Is the 'record' joystick the same as the 'playpack' joystick?
If so, you could use relays, transistors, optocouplers etc connected to
the STAMP pins across the switches to simulate 'real' closures of
the contacts.
Is the joystick 5V....?
What will be the longest time that you would hold the stick in any given
direction?
If this is way off please excuse me!
Regards and good luck!
/Henrik Olsson. Sweden.
Original Message
> be a problem."
> details or a more
> 100 times w/o
> Thanks
> Darren Harris
> Searcher7@m...
be so complicated. If I had the tools, I'd actually be
able to accomplish this with a timer based(mechanical)
mechanism. Anyway...
"There may also be problems storing this data fast
time frame."
Throughout any sequence, two instructions wouldn't
occur within about 1/10th of a second anyway.
"Your main problems are going to be timing and
storage. Getting the playback to happen at the same
speed as the recording will be difficult. You will
record loops have the EXACT same execution times."
Since input would be manual, I don't know how that is
possible. But if the microcontroller can read my
manual inputs of a particular sequence, then why
wouldn't it be able to just duplicate all individual
commands in that sequence as outputs(with that 1/60th
of a second accuracy I mentioned)?
And if storage is an issue, then is there a way to use
my PC(hard drive)?
So I'm assuming that a Basic Stamp 2 is what I would
need for my project? Is there any thing else?
Darren Harris
Searcher7@m...
> playback. In order to do this, you will have to
> sequence. Then you will
> switches.
> on the stamp.
> button. You would then move the joystick around and
> required. If you are sampling at 1/60 of a second,
> storage. This will exceed the internal storage
> will require an external storage device. There may
> frame. The record process
> that are used for
> configure it's pins for outputs. It would then run
> time period.
> digital recorder.
> fact that a switch
> doesn't make a clean on/off transistion. It arcs
> this effect. I wouldn't
> game that you are
> it.
> difficult. You will
> times.
> Interupts were also mentioned. What this means is
> that there are two
> needs it's attention. With the basic stamp the only
> code when the input happens. This way the processor
> then has to deal with it. This is not an option on
> the stamp.
> --Scott
Original Message
> From: Darren Harris [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wN1VhxNTPYwCu5t3ZhF5DAGmKjcpaysEQLUpFmYgFtiTuWmIjhYSaFzU3jE7HB19fL5iv6T_0HBMEy9cCwc2zw]searcher731@y...[/url
> realize
> that there are no
> manual
> to
> should be OK."
> or
> making
> reset."
> sequence
> it
> became).
> is
> it
Do You Yahoo!?
program area. You could compress the storage by "run length encoding". So
you'd say (not real stamp code):
scancount=0
eeaddress=0
laststate=-1
loop:
state=getstate ' 0=up, 1=up/right, 2=up, or whatever... never -1
if state<>laststate then writeit
scancount=scancount+1
goto loop
writeit:
if laststate=-1 then skipwrite
write laststate, scancount (to EEPROM)
eeaddress=eeaddress+1
skipwrite:
scancount=1
laststate=state
goto loop
Of course, you need to know when to stop too. This would wind up writing to
EEPROM a code and a number of "scans" that that code was in force. Playback
would be similar.
Just a thought.
Al Williams
AWC
*Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
Original Message
> From: Darren Harris [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jd3oELYKBkLyE03pEpfPOnzdb17uPh0E6gtfGbnBq4w_XmoX1IMAbsGm07_69FR5DQiqXFDyb3xnWdM7UQ]searcher731@y...[/url
> Sent: Thursday, April 12, 2001 1:59 PM
> It's amazing how apparently simple things turn out to
> time frame."
> my PC(hard drive)?
> Thanks
> Darren Harris
> Searcher7@m...
> > switches.
> > on the stamp.
> > that are used for
> > time period.
> > digital recorder.
> > fact that a switch
> > game that you are
> > it.
> > difficult. You will
> > times.
> > that there are two
> > the stamp.
> > --Scott
Original Message
> > realize
> > that there are no
> > manual
> > to
> > should be OK."
> > or
> > making
> > reset."
> > sequence
> > it
> > became).
> > is
> > it
> Do You Yahoo!?
This is just an idea to conserve memory...
Read all 4 inputs at once as a single "NIBBLE"
(forget the button command)
Instead, read the NEW NIBBLE compared to the PREVIOUS NIBBLE
(for debounce, read the NEW NIBBLE a couple of times)
If the NEW NIBBLE is DIFFERENT than the PREVIOUS NIBBLE, then
log the 'time' and NIBBLE information.
(The 'time' variable could be an incremental variable inside the
compare loop between NEW NIBBLE and PREVIOUS NIBBLE it need not
be $TIME as in HH:MM:SS .... Example: Initialize 'time' to
Zero before entering the compare loop... Once inside the
compare loop if NEW NIBBLE equals PREVIOUS NIBBLE then increment
the 'time' variable. Use this value to determine a relative
amount of time the Joystick remained in one position.)
For multiple "tracks" you can segment the memory by a certain
offset, and just index it upon playback.
Beau Schwabe IC Mask Designer
National Semiconductor Network Products Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
'tracks'
joystick.
([noparse][[/noparse]UP 1.2s] - [noparse][[/noparse]DOWN 0.2] - [noparse][[/noparse]LEFT 1.4s] = 3 moves)."
yes. But the return from left, right, up, and down are important also.
"Then when it's done you would like to select which of the 14 tracks
you want
to 'play back' and press the 'play button'.Is this what you like to
do?"
Exactly.
"Is the 'record' joystick the same as the 'playpack' joystick?"
Actually, I have to find a way to interface the microcontroller to
the 4 leaf switches that the joystick touches to open and close those
circuits.
"If so, you could use relays, transistors, optocouplers etc connected
to
closures of
the contacts."
Huh? Remember, I'm a newbie. :-)
"Is the joystick 5V....?"
Yes.
"What will be the longest time that you would hold the stick in any
given
direction?"
About 7 seconds.
"If this is way off please excuse me!"
Actually, you seem to have a handle on what I'm attempting. I would
have given even more details as to why I need to do this, but it
would have been somewhat off topic.
Thanks.
Darren Harris
Searcher7@m...
--- In basicstamps@y..., "Henrik Olsson" <henrik-olsson@t...> wrote:
> Darren,
'tracks'
joystick.
you want
connected to
closures of
> the contacts.
given
> direction?
Original Message
> > be a problem."
> > details or a more
> > 100 times w/o
> > Thanks
> > Darren Harris
> > Searcher7@m...
I guess I understood you right.
You would need some sort of interface between the joystick and STAMP. If the
joystick's switches is connected to +5V only you could connect the switches
direct to the STAMP pins - for the recordmode, that is. For the playbackmode
you can use transistors conected across the switches in the joystick and
drive the base or gate of the transistor from another STAMP pin.
If it's not 5V on the joystick it gets a little more complicated but it sure
can be done. Is it 5V or 12V or maby 230VAC?
On the software side Scott gave you a couple of good ideas but like he says
the storagespace is the problem. Maby you can use an external EEPROM or RAM
connected to the STAMP.
Or you could just the skip the STAMP and connect the four switches to
LPT-port on your PC and record days and weeks of sequences.
Good luck!
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, April 12, 2001 8:58 PM
> time frame."
> my PC(hard drive)?
> Thanks
> Darren Harris
> Searcher7@m...
to be covered in a manual that would come along with the BS2P(which I
assume is the Basic Stamp 2?).
It seems as though I'm going to have to do a lot of studying to
figure out how these things work.(But I'll save these messages for
reference).
Darren Harris
Searcher7@m...
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> I'd think about using a BS2P and storing the recordings in the
unused
encoding". So
> scancount=0
> eeaddress=0
> laststate=-1
> loop:
> goto loop
> writeit:
> skipwrite:
> scancount=1
> laststate=state
> goto loop
writing to
Playback
> would be similar.
> Just a thought.
> Al Williams
> AWC
Original Message
> > From: Darren Harris [noparse][[/noparse]mailto:searcher731@y...]
> > To: basicstamps@y...
> > time frame."
> > my PC(hard drive)?
> > Thanks
> > Darren Harris
> > Searcher7@m...
> > > switches.
> > > on the stamp.
> > > that are used for
> > > time period.
> > > digital recorder.
> > > fact that a switch
> > > game that you are
> > > it.
> > > difficult. You will
> > > times.
> > > that there are two
> > > the stamp.
> > > --Scott
Original Message
> > > realize
> > > that there are no
> > > manual
> > > to
> > > should be OK."
> > > or
> > > making
> > > reset."
> > > sequence
> > > it
> > > became).
> > > is
> > > it
> > Do You Yahoo!?
Read all 4 inputs at once as a single "NIBBLE"(forget
the button command)
NIBBLE
NIBBLE, then
log the 'time' and NIBBLE information."
1)But the same "NIBBLE" will not occur on consecutive
commands.
2)No two commands will occur within about 1/10th of a
second of each other.
3)It's really 8 commands, since the release is just as
important.
"(The 'time' variable could be an incremental variable
inside the
it need not
inside the
then increment
relative
position.)"
If I understand you correctly, time would start at
zero as of the "PREVIOUS NIBBLE". If timing accuracy
will not suffer it would be the obvious way to go. BIG
QUESTION: Is it too unreasonable to expect that the
accuracy between the very first and very last
commands(over a span of about 2 minutes) will be
within that 1/60th of a second window?
"For multiple "tracks" you can segment the memory by a
certain
offset, and just index it upon playback."
I assume something simple like 1, 2, 3, 4, 5, 6, 7,
and 8?
If I sound naive, it's because I know nothing about
electronics.(I'm a amateur(mechanical) inventor).
Thanks.
Darren Harris
Searcher7@m...
> PREVIOUS NIBBLE
> times)
> NIBBLE, then
> variable inside the
> NIBBLE it need not
> inside the
> then increment
> a relative
> position.)
> a certain
> Division
> Norcross, GA 30071
Do You Yahoo!?
Original Message
OK!
The 'safest' way to simulate switch-closures is to use an opto-coupler. It
concists of a LED and a transistor in one DIP-package (or SMD for that
matter).
It works like this: When you drive current thru the LED the transistor will
conduct and current can flow from the collector to the emitter - quite
simple! The only connection is by light so there's _allmost_ no way that the
STAMP can be hurt if any thing goes wrong in 'the other end'.
The first thing you need to do is findout if the signals going from the
switches to 'whatever' is at 0V when you don't do anything with the stick
and at 5V when you push up for example.
If that is the case you would connect the COLLECTOR on the optocoupler (pin5
on MOST (not all) 6-pin optocouplers) to the one side of the switch that
allways is at 5V and the EMITTER on the optocoupler (pin6) to the 'other'
side of the switch.
Now, if you ground the cathode of the LED in the optocoupler (often pin 2)
and connect a 330ohm resistor between the anode (pin1) and a STAMP pin you
can 'simulate' a 1 second switch closure by for example:
High 4 'Put 5V on I/O 4 on the STAMP, making the LED in the
optoc. light up.
Pause 1000 'Wait 1000mS
Low 4 'Remove the 5V on I/O 4, making the LED go off.
Look up some optocoupler like TIL111, CNY17 H11A1, etc or the PC847 - four
in one. You'll see what I meen.
There are many other ways to do it, this is just one. Maby you don't really
need the optocoupler at all scince it's a 5V system, but it protects the
stamp.
Did it make it any clearer for you or did I just made more complicated for
you?
If you want I can draw a simple schematic and send to you off-list.
Sorry I can't help you much on the software side :-( I'm going to think
about it though.
Let us know how it goes.
> Yes.
> given
> direction?"
> About 7 seconds.
> Thanks.
> Darren Harris
four switches to
sequences."
For real? I heard this mentioned before, but have no
idea how to go about getting it done. Is it
easier/more accurate/cheaper than the Stamp idea(for
this beginner)?
Are there any simular projects out there that I can't
study and adapt for my purposes?
Darren Harris
Searcher7@m...
--- Henrik Olsson <henrik-olsson@t...> wrote:
> Darren,
> in the joystick and
> another STAMP pin.
> four switches to
> sequences.
> Good luck!
Original Message
> From: "Darren Harris" <searcher731@y...>
> to
> actually be
> based(mechanical)
> the
> second
> > time frame."
> same
> will
> each
> and
> is
> individual
> 1/60th
> use
> > my PC(hard drive)?
> would
> > Thanks
> > Darren Harris
> > Searcher7@m...
Do You Yahoo!?
>commands.
In the time the BS2 or PIC can "read" the four switches,
YES, it could...
SLOW for a PIC... questionable for a BS2
>important.
YES!, the NIBBLE recording method I mention would ONLY
record a "change" in any of the switch positions. Thus
a switch close or a switch open would be recorded.
(either). Besides this isn't really the place to disscus non STAMP-things.
The hardware side would be axactly the same for a PC as for a STAMP.
Do you know VB at all?
You could set up a timer that reads the LPT-port once every 1/10th seconds,
put the value in file. And then read the file back one line every 1/10th
second (or whaever) and write it back to the LPT-port. But like I said,
don't ask me axactly how to do it.
> "Or you could just the skip the STAMP and connect the
> four switches to
> sequences."
> this beginner)?
> Thanks
> Darren Harris
> Searcher7@m...
> > Darren,
> > in the joystick and
> > another STAMP pin.
> > four switches to
> > sequences.
> > Good luck!
Original Message
> > to
> > actually be
> > based(mechanical)
> > the
> > second
> > > time frame."
> > same
> > will
> > each
> > and
> > is
> > individual
> > 1/60th
> > use
> > > my PC(hard drive)?
> > would
> > > Thanks
> > > Darren Harris
> > > Searcher7@m...
> Do You Yahoo!?
someone qualified to do this. :-)
I have a mind like a computer.(Not a good thing). If
every detail is not explained to me perfectly, in a
step-by-step manner, I'd get stuck on the smallest
things.
So I don't know how much good a diagram would do in
view of the fact that those electronic terms you used
are alien to me.
I really need a book to study.(One with project
examples(and pictures)). :-)
Thanks.
Darren Harris
Searcher7@m...
Original Message
> OK!
> matter).
> the emitter - quite
> other end'.
> side of the switch.
> example:
> optoc. light up.
> the LED go off.
> but it protects the
> stamp.
> you?
> to you off-list.
> I'm going to think
> about it though.
> > Yes.
> the stick in any
> > given
> > direction?"
> > About 7 seconds.
> attempting. I would
> do this, but it
> > Thanks.
> > Darren Harris
Do You Yahoo!?
consecutive>commands.
"In the time the BS2 or PIC can "read" the four
switches,YES, it could..."
Actually, since the input is completely manual, I know
that my joystick movements cannot occur that close
together, and never in the same direction twice in a
row(unless you are somehow talking about "open" and
"Close" on the same pin being considered the same
command).
"> In the time the BS2 or PIC can "read" the four
> switches,
> YES, it could..."
If it takes that long, then the stamp would be useless
to me.
Darren Harris
Searcher7@m...
> >"This is just an idea to conserve memory...
> consecutive
> >commands.
> switches,
> YES, it could...
> a
> as
> >important.
> ONLY
> Thus
> Division
> Norcross, GA 30071
Do You Yahoo!?
anyway.
Darren Harris
Searcher7@m...
> Well, I guess it could be done i QBASIC or VB but
> I'm not very good at those
> as for a STAMP.
> the
> > four switches to
> > sequences."
> no
> idea(for
> > this beginner)?
> can't
> > Thanks
> > Darren Harris
> > Searcher7@m...
> > > Darren,
> the
> that
> switches
> > > in the joystick and
> > > another STAMP pin.
> more
> good
> use an
> the
> > > four switches to
> > > sequences.
> > > Good luck!
Original Message
> please
> out
> > > to
> > > actually be
> > > based(mechanical)
> fast
> scan
> > > the
> > > second
> > > > time frame."
> wouldn't
> the
> > > same
> > > will
> > > each
> playback
> > > and
> times."
> that
> > > is
> my
> why
> > > individual
> > > 1/60th
> way to
> > > use
> > > > my PC(hard drive)?
> > > would
> > > > Thanks
> > > > Darren Harris
> > > > Searcher7@m...
> > Do You Yahoo!?
Do You Yahoo!?
One word....
DEBOUNCE
> >"This is just an idea to conserve memory...>
>command).
> > switches,
> > YES, it could..."
>to me.
to program the microcontroller not to accept the same
command for the next second or so. Or I can just
program it not to accept the same command again until
one of the other 6 out of 8 commands were given
first.(The 7th command I left out would of course be
the release for the initial command).
Thanks.
Darren Harris
Searcher7@m...
> At 01:27 PM 4/12/01 -0700, you wrote:
> One word....
> DEBOUNCE
> know
> a
> >command).
> > > switches,
> > > YES, it could..."
> useless
> >to me.
> Division
> Norcross, GA 30071
Do You Yahoo!?
