Button woes
Here's the problem:
I need one button to select a function and then, after the selection
is made, the program branches where it needs to go.
I have nested the button command in a for next loop. I have tried it
without using the button command, by looking at the state of the
input (switch) pin.
Problem is: The branching occurs to quickly.
I would like the branching to occur upon release of the button, not
before. As the loop increments (x=1, x=2, x=3...) the program
branches each time x is incremented. Not what I what I want. I want
to escape the loop and branch after release of the pusbutton.
Two questions remain:
1) Did I make any sense
2) If so, how is it done.
Rich
input (switch) pin.
Rich
top:
for var=1 to ?
if in1=1 then top
pause 10
next var
wait:
if in1=0 then wait
goto ?????
hope this helps
regards victor
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, April 11, 2001 4:14 PM
Subject: [noparse][[/noparse]basicstamps] Button woes
> Here's the problem:
> input (switch) pin.
> Thanks
> Rich
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>input (switch) pin.
Here is one way, programmatic:
but var in0 ' button on p0, active low.
waiting1:
if but=0 then waiting1 ' wait for button to be up
waiting0:
if but=1 then waiting0 ' wait for button to be down
do_it:
'this happens when button goes down.
goto waiting1
Here is another way, state machine:
new var bit ' new state of button
old var bit ' old state of button
' button on p0.. active low
old=1 ' inactive to start
waiting:
new=in0 ' logic detects 1->0 transition
if old ^ new & old then do_it
'rest of stuff in waiting loop
goto waiting:
do_it:
old=new ' update state
' rest of stuff to do
goto waiting
The formula, )old ^ new & old), uses the XOR operator between the old
and the new state to detect a transition, and then ANDs that with
the old state to narrow it down to the 1-->0 transition. The
programmatic approach is easier to understand and implement
initially, but the state machine approach lends itself more readily
to further development with more inputs and actions.
I hope that helps,
-- regards,
Tracy Allen
electronically monitored ecosystems
http://www.emesystems.com
as it would never detect the return to pushbutton up. Here is a
correction...
new=in0 ' starting state
waiting:
old=new
goto waiting:
do_it:
' stuff to do
goto waiting
-- Tracy
npressed, and when pressed, send the program to another for/next loop that
determines when the button is released, once released, run the code
required.
Chris
Original Message
Sent: Thursday, April 12, 2001 4:14 AM
> Here's the problem:
> input (switch) pin.
> Thanks
> Rich
