Identify Failure
Phil-
I don't have an 'e' so I may be way wrong in the following. I
suspect you're using stampw.exe and have your preferences set to some
Stamp model other than the BS2e.
Here's why this might explain things. If memory serves, the
{$STAMP...} directive overrides the model selected under
Preferences in the Edit drop-down menu. So you may have "BS2" or
"BS2SX" or whatever selected as your preferred, default Stamp model,
but still program a BS2e successfully because of the directive.
Now consider that you don't need any program loaded in the editor in
order to use the identify command. That tells me the editor is not
looking at the source code (including the {$STAMP...} directive) to
determine what flavor of Stamp to look for. If your preferences are
set for something other than a BS2e, and there is a BS2e at the end
of your programming cable, the identify command will probably always
fail. In other words, if the editor is looking for a BS2SX with the
identify command, but there's a BS2e connected, you get the
"...detected but not responding...".
I do know that the identify command causes a truncated programming
sequence...the programming preamble is sent and things stop just
short of actually sending tokens. That's why you see what you
called a soft reset.
At the nitty gritty level, successfully programming your Stamp
entails successfully sending the identify sequence which is then
followed by eeprom data and tokens and stuff. So if you can program
your Stamp, the identify command works. Why it's not working all by
itself may be explained by the above. I hope that helps.
Steve
Steve
I have been working with Parallax technical support to try and understand
why my BS2E fails the Identify command. I am able to load and execute
programs without any problems, but the Identify command returns with the
error:
BasicStamp II Detected but not responding on COM1!
Check power supply
Executing the Identify command causes my program to begin execution. It
apparently causes a soft reset.
So far they have had me make sure that that my programs contain the
'{$STAMP BS2E} command and verify the that it is not a wiring problem.
So I am turning to the group for possibly some better answers:
1) If I am able to download and execute (including using the debug command
which utilizes COM1) how would a wiring problem effect only the Identify
command?
2) What is the Identify command doing different than the Run command?
(besides the obvious of compiling, loading and executing a program)
And the real question:
3) Why do I care if Identify fails? What is its use and what will I miss if
I fail to debug the problem?
Thanks for your thoughts and advice,
Phil
PS I saw in a previous thread that a couple of other people have also
experienced this problem and one solution was to exchange the Basic Stamp.
====== My evironment ==========
* WIN98 SE
* AMD K6-350
* 196Meg Ram
* stampw v 1.1
* BS2E (home built bread board)
Vin = 7.5v, using BasicStamp regulator for 5v generation
* Modem on COM3.
Removed from STAMP configuration. Only COM1 & COM2 are available.
and still no show. I apologize in advance if this is a duplication to some.
All,
error:
Check power supply
command?
Phil
====== My environment ==========
* WIN98 SE
* AMD K6-350
* 196Meg Ram
* stampw v 1.1
* Modem on COM3.
>error:
> Check power supply
If that is the message you are getting, it indicates to me that your
setting under preferences/editor operation is "BS2" rather than
"BS2e".
The Identify command is based on the setting under
preferences/editor operation, and has nothing to do with the type of
program you have in the top window nor with the '{$STAMP BS2E}
directive in that program.
>command?
unlikely
It sends the same stuff as the programming (RUN) preamble, except
that it aborts without sending any data. The preamble is an exchange
of information between the stamp and the PC, that identifies the type
of stamp. As you observed, it does a soft reset of the stamp. If
you are interested, you can find technical details of the exchange at:
http://www.emesystems.com/BS2clone.htm
You might expect the PC actually to identify the type of stamp
connected, if any, and to tell you what it is.
Unfortunately, that is not the way it is implemented in stampw.exe.
If your stamp is in fact connected, but it does not match the device
selected under preferences/editor operation, then it only gives you
the dreaded message
BasicStamp II_ Detected but not responding on COM_!
Check power supply
Which of course might not have anything to do with the power supply.
You might just have a BS2e connected instead of the BS2.
Parallax is aware of this shortcoming, and I think it is a great
source of confusion.
It is possible to identify the stamp, as Steve Parkis did in the
Stache firmware. The Stache is able to respond appropriately for the
type of stamp connected, which is what allows it to store up programs
simultaneously for different kinds of stamps.
I hope that helps. Of course, the problem could be something
completely unrelated.
-- regards,
Tracy Allen
electronically monitored ecosystems
>Phil
>* WIN98 SE
>* AMD K6-350
>* 196Meg Ram
>* stampw v 1.1
>* Modem on COM3.
BINGO! You hit the problem straight on the head. In my configuration I
had the default setting to BS2 instead of BS2E. It now replies that it :
"Found BS2p1.-IC (firmware v)."
Not sure what the BS2p1 is but the program seems happy now.
Also because of you explanation I now understand why I was able to execute
programs but not "Identify". The program forced the proper ID but the
Identify program relies on the default setting in the editor.
I still do not understand what purpose the Identify function performs.
The only advantage I can see is that it appears to read back the firmware
revision level.
Thanks for your help.
Phil
Original Message
To: Phil Keller <phil@p...>; <basicstamps@yahoogroups.com>
Sent: Tuesday, April 10, 2001 11:04 PM
Subject: Re: [noparse][[/noparse]basicstamps] Identify Failure
> Phil-
> Regards,
> Steve
That was exactly my problem. I had the BS2 selected as the default
instead of the BS2E It now responds with:
Your explanation, along with Steve's, was right on the money and I now
understand both what I did wrong, and why it failed the way it did. I
really appreciate the time that you took to both explain the cause and
the effect of the mis-configuration.
Thanks for your efforts,
Phil
> >error:
> > Check power supply
> "BS2e".
> >command?
> unlikely
> the dreaded message
> Check power supply
> -- regards,
> Tracy Allen
> >Phil
> >* WIN98 SE
> >* AMD K6-350
> >* 196Meg Ram
> >* stampw v 1.1
> >* Modem on COM3.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
