serial output counters
Stampers,
I'm looking for a 16 bit up counter with a serial output. I'm going to
attach a 1 mSec time base to the input of this timer.
I will have in input to an RS latch looking at my "event", take the output
of the latch to an input of the stamp and have the stamp read and reset the
timer. I will divide a constant of 60,000 by the sampled number and send it
out to one line of my front panel 4X20 display as " XXX Gizmos Per Minute".
Sound like a tachometer? It is what HP used to call an EPUT meter or EVENT
PER UNIT TIME (some of you older guys are scratching your heads and saying
"Oh, yeah. I remember those old things.") The time base can be varied by
changing the 60,000 mSec to what ever unit you chose or by changing the 1
mSec to 10, 100, 1000 etc.
If the counter isn't available, I'll just try to force a BS1 into a tight
timing loop and brute force it, but it seems that the external timer is a
better solution. [noparse][[/noparse]please, don't tell me that I could use an AM-9513A, I
don't even want to think about that solution]
thanks,
_________________________________
Mike Walsh
walsh@i...
thanks,
Mike Walsh
walsh@i...
The PAK-VII samples each input at an interval (adjustable from 5uS up). It
maintains a count of rising edges, falling edges, and also the length of the
last + pulse and - pulse.
So you might be able to use the internal time base, but as long as you are
sampling at twice your input frequency (or faster) you could use the edge
counters to get the number you want.
Al Williams
AWC
*8 channels of pulse input: http://www.al-williams.com/awce/pak7.htm
Original Message
> From: MIKE WALSH [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yhI7jJEyU47cwYncj_QjIdGLIQhJxDuIpm3blHwqYlJ4FHC3l_tT5aJYIBa3rijemq0hYh3OdGrAxFI]walsh@c...[/url
> Sent: Thursday, April 05, 2001 4:47 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] serial output counters
> Stampers,
> the output
> reset the
> and send it
> Per Minute".
> or EVENT
> and saying
> thanks,
> Mike
> Mike Walsh
> walsh@i...
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I had looked at your I/O coprocessors, thinking that I would use pBasic
statements. I never even thought about the Pulse Input Processors. I'll
look at it tonight!
thanks,
At 05:00 PM 4/5/2001 -0500, you wrote:
>The PAK-VII can do what you want on 8 channels at once, I think.
Mike Walsh
walsh@i...
I have also been keeping an eye out for a serial counter for some time. you
may want to take a look at at the Philips PCF8583 I2C real time clock. It
has a mode which can be set that lets you use it as a counter instead of a
clock. It should be easy to interface with the new stamp chips, or possibly
you could fake it in software
fwiw,
Steve
At 02:46 PM 04/05/2001 -0700, you wrote:
>Stampers,
>thanks,
>Mike
>Mike Walsh
>walsh@i...
16-bit, 256 hz with a timer built in...I've used them for all sorts of
things..
It's a 8- Pin PIC and 4 MHZ resonator.....
www.panderson.com
Good luck
Stewart McCallum
Sydney, Au
Thanks. I'll take a look at the Philips part. Does anyone know where to get
Philips parts in small quantities?
At 03:10 PM 4/7/2001 -0500, you wrote:
>Hi Mike,
>fwiw,
>Steve
Mike Walsh
walsh@i...
I appreciate the help, but that's not quite Mr Anderson's address.
At 10:09 AM 4/8/2001 +1000, you wrote:
>Peter Anderson Also has a serial counter availalbe on his site...It'
>things..
>www.panderson.com
>Good luck
>Stewart McCallum
>Sydney, Au
Mike Walsh
walsh@i...
