Magnetic card swipe reader
Here is a way to read devices that have there own serial clock, its a 18
bit shift register that can be set from 1 to 18 bits. This diagram is for
16 bits, the bits shift through the device, you will need to OR the clock
line for the two devices using the data. You will also need to know how
many bit's you are using, as these can be cascaded for any combination of
bits needed. Second thing is knowing when the first device is done, so the
stamp can read the data.
good luck
larry
"De Meester, Michel" wrote:
> Hello Stampers,
> Has anybody ever used an OMRON Manual Swipe Magnetic Card Reader 3S4YR-HSR?
> This is a "bare" 1 channel mag stripe reader with TTL outputs.
> It has three outputs :
> -RDP (inv) read data
> -RCP (inv) read clock
> -CLS (inv) card load
> When I attach a scope on RDP and swipe a card, I can see a lot of pulses
> with an irregular pattern, the data (active low)
> When I attach a scope on RCP and swipe a card, I can see a lot of pulses
> with a regular pattern, the clock (active low)
> When I attach a scope on CLS and swipe a card, it goes low while the card is
> moving
> My idea was to use CLS to trigger a subroutine where the data is imported
> synchronised with the RCP (clock pulses)
> Using SHIFTIN for this purpose isn't possible because the CPIN (in shiftin
> dpin,cpin,mode) is used as an output and the swipe reader produces its own
> clock pulses (frequency depends on the swipe speed)
> I want to use the reader in a car alarm system where the card code is
> checked against a predefined code
> Greetz and thx in advance
> Michel De Meester
> Met vriendelijke groetjes,
> > Michel De Meester
> > Biotechnisch Onderhoud
> > Universitair Ziekenhuis Antwerpen
> > Wilrijkstraat 10
> > 2650 Edegem - B
> > tel: 03/821.3647
> > e-mail: michel.de.meester@u...
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
good luck
larry
> Hello Stampers,
> moving
> Michel De Meester
> > Michel De Meester
> > Wilrijkstraat 10
> > 2650 Edegem - B
> > tel: 03/821.3647
moving
Michel De Meester
> Michel De Meester
> Wilrijkstraat 10
> 2650 Edegem - B
> tel: 03/821.3647
card. The swipe card wear out, but ibuttons, and the reader for the ibutton
are near indestructible.
Chris
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, April 05, 2001 5:01 PM
Subject: [noparse][[/noparse]basicstamps] Magnetic card swipe reader
> Hello Stampers,
3S4YR-HSR?
is
> moving
> Michel De Meester
> > Michel De Meester
> > Wilrijkstraat 10
> > 2650 Edegem - B
> > tel: 03/821.3647
the MagTek, output a 5-bit word. Ideally you want to find one with the logic
board on it, so the card reader decodes the stripe and outputs actual
characters.
Original Message
> good luck
> larry
3S4YR-HSR?
card is
> > moving
imported
shiftin
own
