Clock & Temp w/X10
I have pet reptiles and there is a day light and night light - each
is on for twelve hours. They are X10 controlled (via appliance
module). The problem is as the house gets warmer or cooler the
lights are preset. So, I want to sample the temperature, then if it
is too hot, send an Xout to turn the light off or on (if it's too
cool). Since the stamp doesn't have a real time clock should I just
use a counter for twelve hours to know which light to toggle on and
off?
Scott Edwards' book discusses using an LM34 with a ADC 0831 for the
temp side, then it has a 74xxxx series for the counter. Or should I
use a real time clock?
Any other thoughts or recommendations?
off?
OK. For the LM34 through the ADC 0831, I had to apply DSP ( Digital Signal
Processing) in the software to average the temp as it jump around too much
due to circuit variations. Otherwise it was accurate.
I am not able to make a accurate statement on the clock, as the crystal I
bought from Radio Shack.com was clearly marked a 32768 hz was actually
3276800 hz. This caused me all kinds of grief. I must of had a bad batch,
as I bought 3 crystals. Two were wrong freq, and one was dead. When I
figured out my problem, I had to do a work around by using a second 74HCT4060
to bring down the pulse rate. If you do the math, you will find that by
using a second divider, the numbers don't fit evenly into a time cycle of 1
second. Therefore, my circuit lost about 10 sec a day. But the rate of loss
was consistence, and I think with the proper parts it would keep very good
time. In intend to repeat clock part of this experment one day with the
correct parts.
In conclusion, I think the circuit will do what you want and the clock will
keep good time. Also look at the next chapter about using a DS1620 for
keeping temperature. Both will work, the DS1620 seem to be more stable and
doesn't need DSP. But you will need to convert from Centigrade to Fahrenheit
As a side note, I was using a BS2 and had to convert the program from BS1 to
BS2.
Bruce Snowden
> off?
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
plan to use it for clock as you stated. You will need to plan some sort of
continuious power source. Any power interuption or reset, will set the clock
back to 0.
Bruce Snowden
> off?
www.phanderson.com
Adolph Stumpf
astumpf@q...
________________________________________________
> off?
I may also try the temp probe from Parallax with the DS1620 (in their
earthmeasurement lab chapter 3) for the temp sensor. The crystal and
timing issues are something I have to consider....as well as a
constant power source to keep the timer from being reset.
Thanks again - it helped a lot.
--- In basicstamps@y..., bsnowde@a... wrote:
> I built the circuit you are referring to in Scott Edward's book.
It worked
Digital Signal
too much
crystal I
actually
bad batch,
When I
74HCT4060
that by
cycle of 1
rate of loss
very good
with the
> correct parts.
clock will
for
stable and
Fahrenheit
from BS1 to
> BS2.
> Bruce Snowden
each
it
just
and
> > off?
the
should I
64K EEPROM and an I2C bus in a small 0.8" by 0.3" SIPP package. You
could have an accurate timebase and be able to store the
temperature/time in the EEPROM. Let me know if you're interested.
--Jeff
--www.High-TechGarage.com
it
just
> off?
I
bill hart hellkat909@y...
--- bs2web@y... wrote:
> I have just completed a prototype design which has a
> Real time clock,
> SIPP package. You
> the
> you're interested.
> --Jeff
> night light - each
> (via appliance
> or cooler the
> it
> on (if it's too
> clock should I
> just
> to toggle on and
> > off?
> ADC 0831 for the
> counter. Or should
> I
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/?.refer=text
of the EEPROMs so they won't be complete until Wednesday (4/4/01).
There are actually two flavors--64k and 128k EEPROM. Since these are
prototypes, I'll offer the 64k for $10.00 and the 128k for $13.00.
Shipping will be whatever the post office charges (I think Priority
mail is $2.99). Contact me offline for more details: jwallace@high-
techgarage.com.
Thanks for the interest!!
--- In basicstamps@y..., william hart <hellkat909@y...> wrote:
> jeff-im sure the heck interested-send me info
> > Real time clock,
> > SIPP package. You
> > the
> > you're interested.
> > --Jeff
> > night light - each
> > (via appliance
> > or cooler the
> > it
> > on (if it's too
> > clock should I
> > just
> > to toggle on and
> > > off?
> > ADC 0831 for the
> > counter. Or should
> > I
> Do You Yahoo!?
Original Message
> From: bs2web@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IIiw8oOsj83fdA3v1XPojur3Coc4ZF6OvIgO3L94pQw6HCnrj6yhaiE4T94HQu_tiwgSDGJNhA]bs2web@y...[/url
> Sent: Friday, March 30, 2001 9:47 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Re: Clock & Temp w/X10
> I have a very small quantity (8) of this design. UPS lost my shipment
> techgarage.com.
> > > Real time clock,
> > > SIPP package. You
> > > the
> > > you're interested.
> > > --Jeff
> > > night light - each
> > > (via appliance
> > > or cooler the
> > > it
> > > on (if it's too
> > > clock should I
> > > just
> > > to toggle on and
> > > > off?
> > > ADC 0831 for the
> > > counter. Or should
> > > I
> > Do You Yahoo!?
you don't order the top-of-the-line service, you're package isn't
that important, I guess. Are you a small biz owner? Drop me a line
(or anyone else): jwallace@h....
--- In basicstamps@y..., "Chris Loiacono" <chris@a...> wrote:
> Ahhh...the joys of small business....
Original Message
> > From: bs2web@y... [noparse][[/noparse]mailto:bs2web@y...]
> > To: basicstamps@y...
shipment
(4/4/01).
are
$13.00.
Priority
jwallace@high-
> > techgarage.com.
> > > > Real time clock,
> > > > SIPP package. You
> > > > the
> > > > you're interested.
> > > > --Jeff
> > > > night light - each
> > > > (via appliance
> > > > or cooler the
> > > > it
> > > > on (if it's too
> > > > clock should I
> > > > just
> > > > to toggle on and
> > > > > off?
> > > > ADC 0831 for the
> > > > counter. Or should
> > > > I
> > > Do You Yahoo!?
the light bulb, adjust the current or distance of the fan to suit the
animal?
richard
> > > > night light - each
> > > > (via appliance
> > > > or cooler the
> > > > it
> > > > on (if it's too
> > > > clock should I
> > > > just
> > > > to toggle on and
> > > > > off?
> > > > ADC 0831 for the
> > > > counter. Or should
> > > > I
> > > Do You Yahoo!?
