Help! Anyone.
OK, Here is my problem.
I am doing an alarm system where 8 sensors are attached to the BS2. I need to test the voltage on all 8 sensors and as long as there is 0 volts on each pin, the BS2 continues to test the pins. If a sensor pin ejects, then 5 volts is read on that pin and the alarm sounds.
Do I need an A/D converter connected and which one do I use if I need one, OR IS THE STAMP JUST GOING TO SEE 5V ON A LINE AS A "1"?
THANKS
thanks. wtterrell@netzero.com
THANKS
You have answered your own question!
The stamp will see 5 volts as a 1.
No A/D needed.
Bandit
At 09:09 AM 3/28/01 -0500, you wrote:
> OK, Here is my problem. I am doing an alarm system where 8 sensors
>alarm sounds. Do I need an A/D converter connected and which one do I
>"1"? THANKS thanks. wtterrell@n...
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Try the Stamps in Class section on the Parallaxinc.com site.
·OK, Here is my problem.
THANKS
Don't forget to use·resistors on the stamp inputs.
Original Message
To: basicstamps@yahoogroups.com
Sent: Wednesday, March 28, 2001 9:29 AM
Subject: RE: [noparse][[/noparse]basicstamps] HELP! ANYONE.
PS:
You really do want 5V, and it really will help if you read the first few lessons on the Parallax web site.
Original Message
From: wtterrell [noparse][[/noparse]mailto:wtterrell@netzero.com]
Sent: Wednesday, March 28, 2001 9:31 AM
Subject: Re: [noparse][[/noparse]basicstamps] HELP! ANYONE.
how big resistors?
Original Message
PS:
