HEX help
This might sound like a stupid question, but.
What is the hexadecimal number system?
how dose it work?
and how do i turn it to our number system?
thank you
tony
how dose it work?
thank you
tony
base 10 ...
Each hex digit has a value of 0-9 or a-f.
0-9 hex have the same value as decimal 0-9. (a-f) have a decimal equivaluent
value of 10-15.
Thus, one hex digit has a decimal value of 0-15
To convert a hex number to decimal "by hand", remember that each "column" is
16 times the value of the column to it's immeditate right.
In decimal terms, remeber the one's tens' hundreds' column? Hex has the same
idea, but it's all based on base 16...
So, we have the "one's" column then the 16's column then the 256 column....
So, lets convert a hex number like '0ABC'...
A=10 ---> * 256 = 2560
B=11 ---> * 16 = 176
C=12 ----> *1 =12
Now add it all up, 2560 + 176 + 12 = 2748
So hex ABC = 2748 decimal.
Further examination of numbering systems show that Christmas and Hallowe'en
actually occur on the same day!!! Considering the Octal (bas 8) number
system we see that OCT 31 = DEC 25 !! :-)
QED. :-)
Don Russell
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, March 26, 2001 6:15 PM
Subject: [noparse][[/noparse]basicstamps] HEX help
> how dose it work?
> thank you
> tony
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
then A-f. 0 represents 0, F represents 15. Then, like a base 10 numbering
system, you increase the leftmost digit and keep going. The decimal digit
places are (counting from right to left, as in base 10)
16^0 (or 1) = 0x00001
16^1 (or 16) = 0x00010
16^2 (or 256) = 0x00100
16^3 (or 4096) = 0x01000
16^4 (or 65536) = 0x10000
0 = 0
F = 15
10 = 16 (1 in the '16' place, 0 in the 1 place)
1f = 31
90 = 144 (9 in the '16' place, 0 in the 1 place)
C0 = 192 (12 in the '16' place)
F0 = 240 (15 in the '16' place)
FF = 255 (15 in the '16' place, 15 in the 1 place)
100 = 256 (1 in the '256' place)
400 = 1024 (4 in the '256' place)
Conversion to decimal is translating each 'digit' to its place number (0-9
are always 9, A is 10, B is 11, C is 12) and multiplying it by the value
of the place, so
F4 = F's place times 16 plus 4's place times 1 == 15*16+4 = 244
1f3E = 1 * 4096 + 15 * 256 + 3 * 16 + 1 = 7985
> how dose it work?
> thank you
> tony
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
Good tip though....
Don Russell
Original Message
Sent: Monday, March 26, 2001 6:43 PM
Subject: Re: [noparse][[/noparse]basicstamps] HEX help
> If you dont wan to have to think too hard, type the number in the windows
> scientific calculator (watch your mode ie dec oct hex bin) and then switch
> the radio button to the base desired and whammo! you just got out of doing
> the math [noparse]:)[/noparse]
Original Message
> From: "Don Russell" <drussel2@s...>
> Sent: Monday, March 26, 2001 9:26 PM
> > Hexadecimal uses a base 16 numbering system instead of the more familiar
> > base 10 ...
> equivaluent
> > value of 10-15.
"column"
> is
> same
> column....
> > C=12 ----> *1 =12
> Hallowe'en
> > QED. :-)
> > Don Russell
Original Message
> > From: <aconti@n...>
> > > how dose it work?
> > > thank you
> > > tony
familiar
> base 10 ...
equivaluent
> value of 10-15.
each "column" is
the same
column....
> C=12 ----> *1 =12
Hallowe'en
number
> QED. :-)
> Don Russell
Original Message
> From: <aconti@n...>
> To: <basicstamps@y...>
> > how dose it work?
> > thank you
> > tony
Original Message
> base 10 ...
equivaluent
> value of 10-15.
is
same
column....
> C=12 ----> *1 =12
Hallowe'en
> QED. :-)
> Don Russell
Original Message
> From: <aconti@n...>
> > how dose it work?
> > thank you
> > tony
the point of balancingmy checkbook when I wrote a check for $38, deducting
it from my current of 190. and got...
190
- 38
158
oops, you KNOW you're working too many hours when that happens. lol ;-)
Seriously though, give me an example of exactly what you want to do... I
thought my description (below) did show how to convert hex to decimal....
Don Russell
Original Message
Sent: Monday, March 26, 2001 6:38 PM
Subject: [noparse][[/noparse]basicstamps] Re: HEX help
> ok, i under stand how to get to hex, but how do i get to our numbers?
> familiar
> > base 10 ...
> equivaluent
> > value of 10-15.
> each "column" is
> the same
> column....
> > C=12 ----> *1 =12
> Hallowe'en
> number
> > QED. :-)
> > Don Russell
Original Message
> > From: <aconti@n...>
> > > how dose it work?
> > > thank you
> > > tony
tony
> *our* numbers? ;-) But these ARE our numbers... I use hex
everyday.... to
deducting
> 190
> - 38
> 158
lol ;-)
do... I
decimal....
> Don Russell
Original Message
> From: <aconti@n...>
numbers?
> > familiar
> > > base 10 ...
> > equivaluent
> > > value of 10-15.
> > each "column" is
has
> > the same
> > column....
> > > C=12 ----> *1 =12
> > Hallowe'en
> > number
> > > QED. :-)
> > > Don Russell
Original Message
> > > From: <aconti@n...>
> > > > how dose it work?
> > > > thank you
> > > > tony
going back to the basic of the ones column and the 16's column....
there is 1 in the 16's column: 1* 16 = 16
there is 15 in the 1's column: 15* 1 = 15
Add up the two ... 16 + 15 = 31
x1F = 31 decimal
Don Russell
Original Message
Sent: Monday, March 26, 2001 7:26 PM
> don, how about 1F.
> tony
> everyday.... to
> deducting
> > 190
> > - 38
> > 158
> lol ;-)
> do... I
> decimal....
> > Don Russell
Original Message
> > From: <aconti@n...>
> numbers?
> > > familiar
> > > > base 10 ...
> > > equivaluent
> > > > value of 10-15.
> > > each "column" is
> has
> > > the same
> > > column....
> > > > C=12 ----> *1 =12
> > > Hallowe'en
> > > number
> > > > QED. :-)
> > > > Don Russell
Original Message
> > > > From: <aconti@n...>
> > > > > how dose it work?
> > > > > thank you
> > > > > tony
thank you
> OK, 1F hex....
> x1F = 31 decimal
> Don Russell
Original Message
> From: <aconti@n...>
> > don, how about 1F.
> > tony
> > everyday.... to
> > deducting
> > > 190
> > > - 38
> > > 158
> > lol ;-)
> > do... I
> > decimal....
> > > Don Russell
Original Message
> > > From: <aconti@n...>
> > numbers?
more
> > > > familiar
> > > > > base 10 ...
decimal
> > > > equivaluent
> > > > > value of 10-15.
> > > > each "column" is
Hex
> > has
> > > > the same
the 256
> > > > column....
> > > > > C=12 ----> *1 =12
Christmas and
> > > > Hallowe'en
(bas 8)
> > > > number
> > > > > QED. :-)
> > > > > Don Russell
Original Message
> > > > > From: <aconti@n...>
> > > > > > how dose it work?
> > > > > > thank you
> > > > > > tony
and just for the sake of completeness... when the leftmost hex digit has the
highorder bit on (8 or higher) I usually put a 0 infront of it all to
emphasize the number is positive.
So in your example of A4F hex... that may be a negative number depending on
context... 0A4F is never negative....
That's because the first bit of a hex number is often used as a sign
value.... this is why a two byte signed field can't have a value exceeding
32767 decimal, because as soon as you go past that you get into the negative
number range. 32768 = 8000x
Don Russell
Original Message
Sent: Monday, March 26, 2001 7:35 PM
> OHHH, Ok, now i see. so A4F=2639.
> thank you
> > OK, 1F hex....
> > x1F = 31 decimal
> > Don Russell
Original Message
> > From: <aconti@n...>
> > > don, how about 1F.
> > > tony
> > > everyday.... to
> > > deducting
> > > > 190
> > > > - 38
> > > > 158
> > > lol ;-)
> > > do... I
> > > decimal....
> > > > Don Russell
Original Message
> > > > From: <aconti@n...>
> > > numbers?
> more
> > > > > familiar
> > > > > > base 10 ...
> decimal
> > > > > equivaluent
> > > > > > value of 10-15.
> > > > > each "column" is
> Hex
> > > has
> > > > > the same
> the 256
> > > > > column....
> > > > > > C=12 ----> *1 =12
> Christmas and
> > > > > Hallowe'en
> (bas 8)
> > > > > number
> > > > > > QED. :-)
> > > > > > Don Russell
Original Message
> > > > > > From: <aconti@n...>
> > > > > > > how dose it work?
> > > > > > > thank you
> > > > > > > tony
max val?
that is way bigger than 32767, and it is not a neg. number.
tony
> yup yup yup... you got it...
digit has the
to
depending on
exceeding
negative
> Don Russell
Original Message
> From: <aconti@n...>
> > thank you
> > > OK, 1F hex....
column....
> > > x1F = 31 decimal
> > > Don Russell
Original Message
> > > From: <aconti@n...>
> > > > don, how about 1F.
> > > > tony
> > > > everyday.... to
$38,
> > > > deducting
> > > > > 190
> > > > > - 38
> > > > > 158
happens.
> > > > lol ;-)
want to
> > > > do... I
to
> > > > decimal....
> > > > > Don Russell
Original Message
> > > > > From: <aconti@n...>
our
> > > > numbers?
the
> > more
> > > > > > familiar
> > > > > > > base 10 ...
> > decimal
> > > > > > equivaluent
> > > > > > > value of 10-15.
that
> > > > > > each "column" is
right.
column?
> > Hex
> > > > has
> > > > > > the same
> > the 256
> > > > > > column....
> > > > > > > C=12 ----> *1 =12
> > Christmas and
> > > > > > Hallowe'en
> > (bas 8)
> > > > > > number
> > > > > > > QED. :-)
> > > > > > > Don Russell
Original Message
> > > > > > > From: <aconti@n...>
> > > > > > > > how dose it work?
> > > > > > > > thank you
> > > > > > > > tony
shouldn't have brought it up) :-)
So, yes the 2 byte field can hold a decimal value from 0 to 65535.
The range is actually the same, a two byte field may have 65536 different
values.... x0001 x0002 ... xffff
HOW those values are interpretted is a matter of convention and context.
Think of the ol' numberline from high school math.... put a mark at any
point, and another mark on any other point exactly 65535 units "away"....
now think of that area between the marks as a "slide" on the number
scale.... you can represent the decimal numbers 0-65535, or -1 to 65534,
or -2 to 65533 etc.... but usually when a number is "signed" the range of
+/- number is pretty much equal.
I haven't done enough with the BS chips to know if they do signed arithmetic
or not....
Consider a 1 byte value.... x'30'
What is x'30'.... answer: It depends (context ALWAYS matters)
it's decimal 48 (3 * 16)
it's a character zero if it's being displayed on an ascii device
Don Russell
Original Message
Sent: Monday, March 26, 2001 7:56 PM
> then why dose the BS programming manual (V2.0c) have FFFF=65535 as a
> max val?
> tony
> digit has the
> to
> depending on
> exceeding
> negative
> > Don Russell
Original Message
> > From: <aconti@n...>
> > > thank you
> > > > OK, 1F hex....
> column....
> > > > x1F = 31 decimal
> > > > Don Russell
Original Message
> > > > From: <aconti@n...>
> > > > > don, how about 1F.
> > > > > tony
> > > > > everyday.... to
> $38,
> > > > > deducting
> > > > > > 190
> > > > > > - 38
> > > > > > 158
> happens.
> > > > > lol ;-)
> want to
> > > > > do... I
> to
> > > > > decimal....
> > > > > > Don Russell
Original Message
> > > > > > From: <aconti@n...>
> our
> > > > > numbers?
> the
> > > more
> > > > > > > familiar
> > > > > > > > base 10 ...
> > > decimal
> > > > > > > equivaluent
> > > > > > > > value of 10-15.
> that
> > > > > > > each "column" is
> right.
> column?
> > > Hex
> > > > > has
> > > > > > > the same
> > > the 256
> > > > > > > column....
> > > > > > > > C=12 ----> *1 =12
> > > Christmas and
> > > > > > > Hallowe'en
> > > (bas 8)
> > > > > > > number
> > > > > > > > QED. :-)
> > > > > > > > Don Russell
Original Message
> > > > > > > > From: <aconti@n...>
> > > > > > > > > how dose it work?
> > > > > > > > > thank you
> > > > > > > > > tony
FFFF + 0001 = 0000 (overflow)
FFFF + 0009 = 0008 (overflow)
FFFF + FFFF = FFFE (-2)
To get the negative number, first write down the unsigned magnitude. Then
invert all the bits and add 1.
So thinking about bytes:
-1 = 00000001 (invert) 11111110 (add 1) 11111111 = FF
-100 = 01100100 (invert) 10011011 (add 1) 10011100 = 9C
etc.
reverse the steps to find the value, so:
FE => 11111110 (subtract 1) 11111101 (invert) 00000010 = 02
Al Williams
AWC
* NEW: PAK-II now computes polynomials!
http://www.al-williams.com/awce/pak1.htm#poly
Original Message
> From: Don Russell [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SaKC9n0cjkf9gFjYQYbsSWnYW7yJKUJWy3uQZopJ04T_SI3nKplLVKRnQ_FUaNRUMBHT7wkGgnRXKkv3ugk]drussel2@s...[/url
> Sent: Monday, March 26, 2001 10:09 PM
> To: basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Re: HEX help
> ah... because they don't interpret the high order bit as a sign.... (I
> arithmetic
> or not....
> Don Russell
Original Message
> From: <aconti@n...>
> > max val?
> > tony
> > digit has the
> > to
> > depending on
> > exceeding
> > negative
> > > Don Russell
Original Message
> > > From: <aconti@n...>
> > > > thank you
> > > > > OK, 1F hex....
> > column....
> > > > > x1F = 31 decimal
> > > > > Don Russell
Original Message
> > > > > From: <aconti@n...>
> > > > > > don, how about 1F.
> > > > > > tony
> > > > > > everyday.... to
> > $38,
> > > > > > deducting
> > > > > > > 190
> > > > > > > - 38
> > > > > > > 158
> > happens.
> > > > > > lol ;-)
> > want to
> > > > > > do... I
> > to
> > > > > > decimal....
> > > > > > > Don Russell
Original Message
> > > > > > > From: <aconti@n...>
> > our
> > > > > > numbers?
> > the
> > > > more
> > > > > > > > familiar
> > > > > > > > > base 10 ...
> > > > decimal
> > > > > > > > equivaluent
> > > > > > > > > value of 10-15.
> > that
> > > > > > > > each "column" is
> > right.
> > column?
> > > > Hex
> > > > > > has
> > > > > > > > the same
> > > > the 256
> > > > > > > > column....
> > > > > > > > > C=12 ----> *1 =12
> > > > Christmas and
> > > > > > > > Hallowe'en
> > > > (bas 8)
> > > > > > > > number
> > > > > > > > > QED. :-)
> > > > > > > > > Don Russell
Original Message
> > > > > > > > > From: <aconti@n...>
> > > > > > > > > > how dose it work?
> > > > > > > > > > thank you
> > > > > > > > > > tony
So the original ranges are correct...
Don Russell
Original Message
Sent: Monday, March 26, 2001 9:28 PM
> I hate when these conversations get confusing, especially when there is
> someone new trying to learn it, but I'm gunna' say it anyways... if there
> are 65535 possibilities you can represent 0 to 65534 (because 0 counts as
a
> possibility), or -1 to 65533 etc...
> That's all I have to say. (sorry to bring it up [noparse]:)[/noparse]
> Jim
different
"away"....
of
> arithmetic
> > or not....
> > Don Russell
are 65535 possibilities you can represent 0 to 65534 (because 0 counts as a
Jim
arithmetic
> or not....
> Don Russell
snake with the other guy after I get "dumb college kid" tattooed across my
chest...lol
> laughing... :-) yup... actually there are 65536 posibilities....
0-65535....
> Don Russell
Original Message
> From: "Jim Szymczak" <szymczak@c...>
there
as
> a
> > Jim
> different
context.
any
> "away"....
65534,
> of
> > arithmetic
> > > or not....
> > > Don Russell
>thank you
No one ementioned how cleanly hex is represented in binary and
vice versa.
A4F = 1010 0100 1111 (without the spaces)
Carl
scientific mode.) Have conversions for Decimal, Binary, and Hex. It is
sometimes easiest to use a calculator and change the base units until you
have a good feel for the base you are working in. Just my $0.02 worth.
MH
Original Message
Sent: Tuesday, March 27, 2001 5:36 AM
> >thank you
> vice versa.
> Carl
but the original question asked HOW does the numbering system work.... So,
as with anything, more than just "enter this, press that" was in order. :-)
Don Russell
Original Message
Sent: Tuesday, March 27, 2001 2:39 AM
> Most calculators (including the calculator included with windows, use
> MH
Original Message
> From: <carl@g...>
> > >thank you
> > vice versa.
> > Carl
and negative numbers, signed and unsigned. A signed number gets 0xffff
represented as -1, an unsigned one as 65535.
> or not....
> Don Russell
Original Message
> From: <aconti@n...>
> > max val?
> > tony
> > digit has the
> > to
> > depending on
> > exceeding
> > negative
> > > Don Russell
Original Message
> > > From: <aconti@n...>
> > > > thank you
> > > > > OK, 1F hex....
> > column....
> > > > > x1F = 31 decimal
> > > > > Don Russell
Original Message
> > > > > From: <aconti@n...>
> > > > > > don, how about 1F.
> > > > > > tony
> > > > > > everyday.... to
> > $38,
> > > > > > deducting
> > > > > > > 190
> > > > > > > - 38
> > > > > > > 158
> > happens.
> > > > > > lol ;-)
> > want to
> > > > > > do... I
> > to
> > > > > > decimal....
> > > > > > > Don Russell
Original Message
> > > > > > > From: <aconti@n...>
> > our
> > > > > > numbers?
> > the
> > > > more
> > > > > > > > familiar
> > > > > > > > > base 10 ...
> > > > decimal
> > > > > > > > equivaluent
> > > > > > > > > value of 10-15.
> > that
> > > > > > > > each "column" is
> > right.
> > column?
> > > > Hex
> > > > > > has
> > > > > > > > the same
> > > > the 256
> > > > > > > > column....
> > > > > > > > > C=12 ----> *1 =12
> > > > Christmas and
> > > > > > > > Hallowe'en
> > > > (bas 8)
> > > > > > > > number
> > > > > > > > > QED. :-)
> > > > > > > > > Don Russell
Original Message
> > > > > > > > > From: <aconti@n...>
> > > > > > > > > > how dose it work?
> > > > > > > > > > thank you
> > > > > > > > > > tony
