Fast (really fast, as in 1ns fast) ADC
Hi all, I am looking for a high speed, 16-bit, serial output analog to
digital converter... I am trying to measure a signal "impulse" that has a
0.7ns rise time. I do have a diode/capacitor setup to capture the peak, but
my circuit can't hold the peak for very long. I have done some digging for
such a device, and I've found 6 and 8-bit ADC's that are fast enough, but
not 16-bit or even 12-bit ones... Any ideas??
Chuck[/font]
If you're attempting to capture single-shot events of 0.7nS with any degree
of resolution, your sample rate has to be (roughly) 1/0.07nS, or about
14GHz! If the events repeat regularly, you can fake fast sampling with
techniques used for many years in sampling oscilloscopes. Home-brew
sampling circuits have been described within the last few months in the
"Ideas for Design" column in Electronic Design magazine <www.elecdesign.com>.
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
It's in the 9/18/2000 issue, and it's titled "1-GHz Sampling Osciloscope
Front End Is Easily Modified" by Hubert Houtman. The web site mentioned
below gives access to Design Idea articles as far back as March of 1997...
really understand what is happening.
Original Message
From: Mike Hardwick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uI5mP309VUEHwmLNSkhCH4uNys9zgW8An5Ndaw3eNMuJ_9Kw9t-k0kjAKD5Q2cws3zi5aYnsDeKFG5fwBOHzaA]decade@w...[/url
Sent: Monday, March 12, 2001 5:20 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Fast (really fast, as in 1ns fast) ADC
I found the Electronic Design issue date for one of the sampling circuits:
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
