serial communications through ir leds?
Talking with my son a few days ago we were discussing about
having two stamps talk through ir leds. The idea is to make
two bots that alternate playing a game of tag. One bot
emits an ir signature/frequency while listening, the other
bot listens for the signature/frequency and when its close
enough to the first bot it transmits 'TAG' or sometime. Then
the two bots switch roles.
I know the BS2 has SERIN and SEROUT commands, would these
command work for this scenario or would something else
be better?
be better?
examples of IR communication.
Tim
[noparse][[/noparse]Denver, CO]
> be better?
> Mike
You can use with a circuit shown in BASIC Stamp 1 application note 11
(www.parallaxinc.com Downloads page). Make sure to keep your transmission
rate slow (1200 bps or less). You can also use the IR LED and IR detector
used on the Boe-Bot.
Andy
E-Mail...........alindsay@p...
Parallax, Inc. home page....................www.parallaxinc.com
BASIC Stamp Educational Resources...........www.stampsinclass.com
SX Microcontroller University Resources.....www.sxtech.com
Original Message
From: Mike Eggleston [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7PeqaBrR8rhgUNw5qU2zxBb4Ti6sdV4-OATGwUuXJ-_3ZZeFzsIOH38fgrFV8Bclrbp0At0in8X2LfM]mikee@m...[/url
Sent: Thursday, March 08, 2001 9:03 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] serial communications through ir leds?
be better?
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
noted in the url below, There is going to be a lot of waiting for these bots to
communicate with each other. Assuming the bots are rolling around, they won't
have time to wait on the serial communications.
What your plan?
Dave
--- Tim Goldstein <timg@k...> wrote:
> Take a look at the Rentron website ( http://www.rentron.com ) they have many
> Tim
> > be better?
> > Mike
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/
> Would a second stamp be required for each of these bots. Looking at the code
to
> What your plan?
> Dave
> > Tim
> > > be better?
> > > Mike
I'm still forming a plan on how to do this. I was thinking of timing
the main loop through all motors and sensors and then putting a serin
with a short timeout. The one bot would xmit repeatedly until the
tagged bot sent out an 'ok' or something.
Your project is going to take some work. The idea is to parse the
communication during the pause time between two or three servo pulses. Here
are a few ideas that might help.
You have plenty of time, namely 20 ms between each servo pulse. The code
will take some work though. I'm assuming you want to broadcast three
different messages, "Tag, you're it.", "Rats, you got me; OK, I'm it", and
"Reply confirmed"
Assign "Tag, you're it." the value %10101010.
Assign "Rats, you got me." the value %11001100
Assign "Reply confirmed." the value %11111111
After delivering each servo pulse, "not-it-Bot" should not be broadcasting
infrared. By checking to see if IR is detected, it can know if the "it-Bot"
is in the proximity.
If it-Bot is proximate, not-it-Bot should listen for a serin signal with a
timeout of about 10 ms. If it gets something other than all 0s, it knows
that it may have been tagged. Analysis of the byte might confirm, or it
might just suggest. The byte might have been captured mid-stream, in which
case, it might be something like %0001010. That's a definite "tag", so
check for objects, deliver one more servo pulse, then broadcast "Rats, you
got me." in between the next 4 pulses along with checking for the confirm
byte (anything better than %00000111) means the other bot is confirming.
A not definite tag might be %00000001. In this case, not-it-Bot will have
to check again after delivering its next servo pulse.
Andy
Original Message
From: david cousins [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2waRzcWNdj8mdIc39BIgCY3_-1AAYvrZRW46nFedQ2DcFYhwTN-p0VRcoMOiETanESoUSPvcsQwJcfS7]cuz_hsv@y...[/url
Sent: Friday, March 09, 2001 6:03 AM
Subject: RE: [noparse][[/noparse]basicstamps] serial communications through ir leds?
code
to
won't
What your plan?
Dave
many
> Tim
> > be better?
> > Mike
Do You Yahoo!?
