programming problem
If input 1 goes back low immediately, I'd tie it to the Stamp's RESET
pin. The first thing your Stamp program would do is check inputs 2
and three to decide if it's running due to initial power application
or input assertion. Then set the outputs to match the input and
start a 20 second PAUSE followed by deactivating the outputs and
END, or simply END if no inputs are active. If input 1 goes low
again during or after the 20 seconds the whole process repeats.
If input 1 stays low you'll need to turn it into a pulse with some
hardware to use this approach.
This problem almost sounds like it was thought up to be solved by a
Stamp.
Steve
Stamp.
Steve
·········I'm working on a project that call for me to monitor three inputs,
the inputs are lable 1,2 and 3. Input 1 Is held high constantly until one of
the other two input go high. ·There is also three output that reflect what on
the input...... for example if input 2 goes high, output 2 must go high for
twenty seconds, unless within that time some other input is triggered and the
twenty seconds is canceled and the selected output is sent high....... My
question is how can I start a specify timing cycle and have it canceled on
demand....
thank you for your help
wendell[/font]
>the other two input go high. There is also three output that reflect what on
>demand....
Hi Wendell,
The program must be constantly running in a loop, and the time
intervals are determined by counter that decrement every time around
the loop. I don't understand the relation between input 1 and the
other two inputs, but it would go something like this. Read the
inputs. Detect a change from low to high on an input. If there is a
transition preset the counter for that channel for a 20 second
interval, and zero all other existing counters. Wait for next time
tick. Redo the loop. This kind of program is called a "state
machine". The time tick can come from the program itself using pause
commands and careful tailoring of the program code, or it can come
from an external clock generator.
-- Tracy Allen
electronically monitored ecosystems
http://www.emesystems.com/BS2fsm.htm <-- some examples of state machines
P.S. Please post messages in plain text. (I find large blue italic
lettering, distracting!)
tracy@emesystems.com writes:
of
on
the
>demand....
Hi Wendell,
the loop. ·I don't understand the relation between input 1 and the
inputs. ·Detect a change from low to high on an input. ·If there is a
interval, and zero all other existing counters. ·Wait for next time
tick. ·Redo the loop. ·This kind of program is called a "state
machine". ·The time tick can come from the program itself using pause
Hi tracy,
············Thank you for your help, keep up the good work
Wendell
[/font]
got a problem here. I'm trying to control this servo off of my bs2-
sx. Here's the problem:
The servo will move ccw and cw but i have to load the program into
the stamp everytime i want it to move.
Here's the program:input 8
input 11
again:
if in8 = 0 then cw
if in11 = 0 then ccw
goto again
cw
pulsout 7, 500
pause 20
goto cw
ccw
pulsout 7, 2500
pause 20
goto ccw
Any ideas if i'm missing a statement here? Should i write it any
other way so that i don't have to load the program everytime. Thanks
for any help.
Jon
>hey guys,
>input 11
>again:
>if in8 = 0 then cw
>goto again
>cw
>pulsout 7, 500
>pause 20
>goto cw
>ccw
>pulsout 7, 2500
>pause 20
>goto ccw
>for any help.
>Jon
>Jon -
Once you get INTO either routine (cw or ccw) you are in an infinite loop.
You need to provide from some exit mechanism - probably back to again
Bruce Bates
>hey guys,
>Here's the program:
>input 8
>input 11
>again:
>if in8 = 0 then cw
>goto again
>cw
>pulsout 7, 500
>pause 20
>goto cw
>ccw
>pulsout 7, 2500
>pause 20
>goto ccw
>for any help.
You provide no way to get out of either the CW or CCW goto loops, thus
after making either pin 8 or pin 11 active, and going to the appropriate
loop to activate the servo, you are stuck there. Rethink the logic
flow. Maybe put a means of escaping each loop inside each loop itself? In
the meantime I think you can get by with pressing reset to restart the
program instead of reloading it.
Jim H
the servo. You need to perform the loop a certain number of times, then exit
to the outer loop. Usually doing a loop 25-50 times will give the servo time
to move from one end to the other.
Original Message
> input 11
> again:
> if in8 = 0 then cw
> goto again
> cw
> pulsout 7, 500
> pause 20
> goto cw
> ccw
> pulsout 7, 2500
> pause 20
> goto ccw
>Yeah, you have an endless loop in each one of your code segments that moves
But a servo loop with a specific number of executions defeats the idea that
the servo will respond to pins 8 & 11 *when* they are activated vs X
iterations of a loop later. Bruce had the right idea with putting "goto
again" inside each loop. With that change if a given pin (8 or 11) stays
activated the motor will continue to move in that direction. It looks like
it is free to be pushed around by whatever load it is driving if neither
pin is activated. I hope that's acceptable for the application. If not,
another loop to center the servo (or whatever) could be made to be executed
when neither pin is activated. Many variations on this idea are possible.
Note that if *both* pins are activated, the servo will turn CW because the
"if in 11 = 0 then CW" line will never execute.
JimH
Original Message
> > input 11
> > again:
> > if in8 = 0 then cw
> > goto again
> > cw
> > pulsout 7, 500
> > pause 20
> > goto cw
> > ccw
> > pulsout 7, 2500
> > pause 20
> > goto ccw
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
other. If he wants to use the value of the pins to change positions on the
fly he would be best to use the pin decision to set the pulsout variable
rather than to jump to a section of code.
If I'm reading inputs from multiple pins, I OR them with a nibble or byte
variable, then check to see if the variable value is > 0. If so, I know one
of the pins is high and then I jump to another code segment and figure out
which one was pressed.
Original Message
moves
exit
time
that
like
executed
