HVAC application
Has anybody used the Basic Stamp for multi-zone residential heating/air
conditioning applications?
I would like to try this, but could use some pointers on the basic
multi-zone control algorithms. If anybody knows offhand, or can forward me a
URL, I would appreciate it greatly. One floor on my house is either freezing
or frying, requiring a trip up into the attic to manipulate damper to try to
adjust.
Rob Weinstock
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
adjust.
Rob Weinstock
>adjust.
Check out the Industrial Applications download at STAMPSINCLASS.COM. There
is a nice temperature control tutorial that you shouls be able to adapt to your
project.
Carl
>your
>project.
Thanks, I'll check those out. Does anybody know a good source for motorized
dampers? The ideal ones would have to have limit switches, overcurrent
trips, etc. Home Depot had absolutely no idea what I was talking about when
I said I wanted multi-zone HVAC in the house.
Rob Weinstock
110V but they could move any damper I ever came across.
Dan Sherman WB7N
dsherman@s...
Original Message
From: Rob Weinstock [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OmZ6tVF29GyVSD4jHUorNDGgsnhagHT8V5focKMcysf8T3I7G7akStjaMds1Rm25o7shNP-N_xk2MeaCVg]weinstro@h...[/url
Sent: Monday, January 29, 2001 2:32 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] HVAC application
>your
>project.
Rob Weinstock
We carry a pretty complete line of electronic actuators.
4-20, 0-10, no serical as yet. end switches, feedback pots, etc.
Typically we sell to Honeywell, or commercial and industrial
contractors. Residential units are rare as one rarely does a
spliting of a heater on a house. It can be done.
McMaster Carr will also offer similar units. Expect some sticker
shock as a heavey duct unit can cost betwen $100-200.
Dave
--- In basicstamps@y..., dsherman@s... wrote:
> Honeywell used to make some nice ones, quite large and a priced the
same.
> Dan Sherman WB7N
> dsherman@s...
Original Message
> From: Rob Weinstock [noparse][[/noparse]mailto:weinstro@h...]
> To: basicstamps@y...
adapt to
> >your
> >project.
motorized
overcurrent
about when
> Thanks,
> Rob Weinstock
found out is that extreemly few residental projects use duct
dampers. They run $100-$200 per unit depending on your accessories.
You are in the territory of commercial/industrial automation controls
contracts, and way above your home heating contractors. What you are
asking is simple, but can cost some $$$.
I'll send you some data sheets from the units we carry. Typically a
small acutator will move a 48" x 48" damper. Like I said, commerical
products.
they can receive a voltage to open/voltage to close, no voltage,
stop, or your typical 4-20mADC or 0-5/0-10VDC, no serial as yet.
Options include end switches, feed back pot's, etc.
The quality is what you expect for the money.
You probably can find similar units at McMaster Carr. This type of
thing is way beyound the home depot crowd. But then again, so are
Stamps!
Dave
same.
> Dan Sherman WB7N
> dsherman@s...
Original Message
adapt to
> >your
> >project.
motorized
overcurrent
about when
> Thanks,
> Rob Weinstock
Try grainger.com
Carl
ducts at $90 to $140.
Original Message
From: carl@g... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cyVUpvFxP07g9_Hxe-D-uoZiuh-hbLDr8md1jvZooY_dIv52H-VtTwPaGmgzPvR1ipqb]carl@g...[/url
Sent: Monday, January 29, 2001 4:18 PM
Try grainger.com
Carl
>products.
That would be great. I believe I need dampers in the 12" to 24" range.
Rob
heard that some contractors use tiny gear motors to open and close
the small dampers.
If you have never tried controlling room temperature, it's simple,
open the damper, wait about 20 minutes, check the temperature, if
it's warm, close the damper, if it's not warm yet.... Space/room
temperature control is very sloppy. don't expect tight or fast
control. If you data logged you space now, you'll find a 2° F change
before any control action (heater ON or heater OFF)
This morning I remembered TEMP-A-TROL. They sell multi zone
controlls , dampers, actuators, etc to anybody. And in the sizes you
are looking for. Better prices than I could get you.
a dealer??
http://www.controlsdepot.com/trolatemp.html
home page of Temp-A-trol
http://www.trolatemp.com/
--- In basicstamps@y..., "Witherspoon, Michael J"
<michael.j.witherspoon@i...> wrote:
> Try http:\\www.smarthome.com search for "damper". They have for 6"
to 16"
Original Message
> From: carl@g... [noparse][[/noparse]mailto:carl@g...]
motorized
overcurrent
about when
> Try grainger.com
> Carl
I don't know what kind of furnace you have, but restricting the airflow may
cause problems - burned out elements, cracked heat exchanger, fire, CO
poisining, etc. Also, your insurance company may have opinions regarding
this modification. Good luck.
John
>From: "Rob Weinstock" <weinstro@h...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] HVAC application
>Date: Sun, 28 Jan 2001 18:31:08
>a
>freezing
>to
>adjust.
>Regards,
>Rob Weinstock
> I think I saw some at Smarthome.com. I have no idea about the quality.
> may cause problems - burned out elements, cracked heat exchanger, fire, CO
> poisining, etc. Also, your insurance company may have opinions regarding this
> John
Smarthome also has a unit(non controlled) that opens under excess
pressure.
