Optical Sensor Motorola H22B1
Can anyone steer me to a spec sheet or tell me how to integrate this sensor
to a stamp. I am assuming it is an infrared led and sensor arrangement and
that I will use the count command to tell how many time a perforated object
passes through. Am I on the right track?
Jeff
Jeff
information you find out about integrating an optical sensor with the
Stamp. Thanks....and if I come across anything, I'll send it your way.
Jeremiah LaCoille
> sensor
> and
> object
> Jeff
___________________________________________________________________
Get your own FREE Bolt Onebox - FREE voicemail, email, and
fax, all in one place - sign up at http://www.bolt.com
