Oxygen Analyzer
Hey there everybody:
I am interested in building an online analyzer to continuously monitor the
amount of oxygen in an exhaust pipe. Therefore I am looking at high
temperatures and pressures would be near atmospheric. I have the power
source, ADC, and stamp. All I need now is a sensor that can be inserted into
the side of the pipe and I suspect that it would then have to traverse the
entire diameter through the center of the pipe.
Anybody know where I can get a cheap sensor that would put out either a
proportional voltage or current to the amount of oxygen? I know you can
monitor oxygen content with items such as magnetic fields and zirconium
crystals but these arrangements tend to be bulky, complex and pricey.
Any help would be appreciated.
Thanks and regards,
Gerry Shand
gwshand@c...
res@c...
Thanks and regards,
Gerry Shand
gwshand@c...
res@c...
> Thanks and regards,
> Gerry Shand
> gwshand@c...
> res@c...
I did this for our race car. I used a 4 wire ( Dodge supplied ) o2 sensor. Weld
a bung into the exhaust, hopefully within a foot or so to the port. The sensors
must be above 300f to read correctly and although the 4 wire variety are self
heating, mounted far down the pipe will yield readings that are not as accurate
as could be. The sensors are set to output .5v at a 14.7:1 air/fuel ratio. Get
away from the 14:7:1 ratio either way and the sensor will max out. It's range
is from 0v ( leaner than 14.7:1 ) to 1.0v ( richer than 14.7:1 ) For
performance engines, a reading of around .800 to .900 are usually the norm for
NA engines.
Hope this helps. If more info is needed, feel free to ask.
Dale Harwood
that, but they have some interesting characteristics you need to be aware
of.
Rob Weinstock
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
pretty much work the same. There's the solution. FWIW, this device is also
available commercially from speed suppliers.
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, January 23, 2001 11:26 AM
Subject: [noparse][[/noparse]basicstamps] Oxygen Analyzer
into
> Thanks and regards,
> Gerry Shand
> gwshand@c...
> res@c...
has one, and they are stardized, since the ECU's diagnostic systems are
standardized too.
Although, the stock oxygen sensors are not the most accurate sensors, since
on most cars, they don't need to be. If you are putting a turbo in your
engine, or something where precise air/fuel readings are needed, then I
would suggest an aftermarket sensor. Off hand, I forget the name of the
manufacturer. If you want to know though, just email me and I'll look it
up.
To test your design without taking our your oxygen sensor and toying with
it, an auto parts store might have one, but the best bet would be your car
dealer's parts department. They would have the specific one that fits your
car.
Ken
Original Message
From: "Shand, Gerry W., Celanese/CA" <gwshand@c...>
into
> Thanks and regards,
> Gerry Shand
> gwshand@c...
> res@c...
Per automotive O2 sensors - The garden variety sensor is
a very high-Z bang-bang device which tells you which side
of stoichiometric you are on, rich or lean.
So-called wide-range sensors found on late model Hondas
supposedly have a range of 11:1 to 20:1, at the expense
of a somewhat complex interface. This stuff was pricey
last time I looked, but that was a while ago.
Bob Blick has an O2 sensor page on his site, somewhere.
regards, Jack
