NMEA read out for altitude
Can any one tel me if it is possible to read the altimeter data from the
NMEA output of a Garmin 12 XL GPS. I know the data is subject to some in
accuracy error but now that SA has been turned off I think it will do for
what I need.
Also Has any one written code to compare to GPS positions and indicate the
bearing distance time etc to the way point, better than that is there any
way of getting the direction data to a way point from the GPS?
Raj Mallik
what I need.
Raj Mallik
It is possible to read altitude from the GPS NMEA strings. However, even
with SA turned off, it can be off by 100 to 150 feet most of the time - not
to be trusted in critical applications.
Regarding waypoints, it's possible - there are great circle navigation
formulas - to calculate distance from a location to a waypoint, but it
involves complex math with arc and angle calculations. If you set a GOTO
from some GPS receivers (like the 12XL) you can read the waypoint navigation
information from a custom NMEA string - but you have to set the GOTO command
manually via keypad on the receiver.
Cheers,
Mensaje original
De: Raj Mallik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dl2OXqaD2JeYG-MjFB9UkDByREe1pGLAf1NqBa77kJI_tGkWyLW785ka3M-C5YmouXBOobOMuwyPeSrSmL6lwQ]ramallik@m...[/url
Enviado el: miercoles, 06 de diciembre de 2000 0:32
Para: basicstamps@egroups.com
Asunto: [noparse][[/noparse]basicstamps] NMEA read out for altitude
what I need.
Raj Mallik
are along a sphere.
a1, b1 and a2, b2 are the lat, lon pair...
R is the radius of the earth in the measurement that you want to use.. For
Statute miles use the folowing.
r=3963.1 ' Statute Miles
distance=Arccos(Cos(a1) * Cos(b1)*Cos(a2)*Cos(b2) +
Cos(a1)*Sin(b1)*Cos(a2)*Sin(b2) + Sin(a1)*Sin(a2))/360 * 2 * Pi * r
I do not know if there is a pack for the stamp that can handle the math but
there is the formula.
MH
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, December 05, 2000 6:32 PM
Subject: [noparse][[/noparse]basicstamps] NMEA read out for altitude
> what I need.
> Raj Mallik
programed to take 1 - 3 minutes to reaquire it the signal. If someone was
trying to design a autopilot you may have some problems especially if its
for a flying vehicle. A lot can happen in 1 - 3 minutes.
Can anyone confirm this?
Cory
Original Message
>From: Michael Hendricks [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RLfaHGPhVCKcBRX_UmE04smes8vbXSE5UEzqtrYOeHqlQy3ZsNxkMSSfMHM6dckoF5S71o4PBKcBd4dw]mjh80@b...[/url
>Sent: Thursday, December 07, 2000 9:09 AM
>To: basicstamps@egroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] NMEA read out for altitude
>To compute the distance between 2 points you need to compute them
>as if they
>are along a sphere.
>MH
Original Message
>From: "Raj Mallik" <ramallik@m...>
>> what I need.
>indicate the
>> Raj Mallik
This only happens with certain type of receivers, all the ones I have seen,
both consumer type and OEM have re-aquisition times of between 10
milliseconds to 15-20 seconds for old units.
One thing to take into account in the design of the vehicle is that the GPS
will draw some 150mA, which is quite a bit.
Cheers,
Mensaje original
De: Stratton Design Studios [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=f7ghyVjAjCf2JSAtGFfZap41edCybqmuObrZv7y5CDuR-tsBP8cXO7hhKsE1IiBuaiqCKYZ_Z2e1wkYPXuu-GfZbipH30Q]cory@s...[/url
Enviado el: jueves, 07 de diciembre de 2000 17:52
Asunto: RE: [noparse][[/noparse]basicstamps] NMEA read out for altitude
I was reading in a book that stated that if your GPS looses its signal it is
Cory
Original Message
>From: Michael Hendricks [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ccvxYulE0-vbsG-odJLg-ghUllV8Hcs1Z5aOf9wQXOgnROWNFtQPOuwHzkZ0yFuRgcD21YDua52I6f0]mjh80@b...[/url
>as if they
>are along a sphere.
>MH
Original Message
>> what I need.
>indicate the
>> Raj Mallik
purchase?
Cory
Original Message
>From: Miguel Puchol [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aqPfNSGs81PyTcYDPROd-O9M42xyPFh5XI78lqYkGk1hs297-sz-UTLj3D6zRueom_vomTtVGpk]mpuchol@w...[/url
>Sent: Thursday, December 07, 2000 10:02 AM
>Subject: RE: [noparse][[/noparse]basicstamps] NMEA read out for altitude
>Cory,
>Cheers,
>Mike
Mensaje original
>De: Stratton Design Studios [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DO5nrmosQOuLfJR149rEs-Gx6BM5V4IV05tAIi9Yp5jKCC4yJxlWdoYgnoI-x-jI31d2QgZfpzMPHWDiApmOoRupg-avS20]cory@s...[/url
>signal it is
>Thanks
>Cory
Original Message
>>From: Michael Hendricks [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dXAMZsNezBbN1MDH6W_d7nkClnecIA4KXxFpnoMrXoRfgnAlXUDXtGEdnHHDMpVuaqxbFydjpQc]mjh80@b...[/url
>>as if they
>>are along a sphere.
>the math but
>>MH
Original Message
>will do for
>>> what I need.
>>indicate the
>there any
>>> Raj Mallik
richard
Original Message
Sent: Thursday, December 07, 2000 10:51 AM
is
> Thanks
> Cory
Original Message
> >From: Michael Hendricks [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=g6zgG-6Ne3JrkpxAIHugimgO6bONHc8FxWsm061GAT5eHuiUBM9oJq5asQVYzcdz73U-923MFTW8cHE]mjh80@b...[/url
> >as if they
> >are along a sphere.
For
but
> >MH
Original Message
the
in
for
> >> what I need.
> >indicate the
any
> >> Raj Mallik
A good, light-weight integrated receiver is the Pharos iGPS (weighs 2.4oz),
takes about 150mA at 5V and has a re-aquisition time of 100ms. Take a look
at www.pharosgps.com.
Time to first fix is around 45 seconds with a good view of the sky, and
hot-start is stated as being 8 seconds.
All the best,
Mensaje original
De: Stratton Design Studios [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=c9Gpg-hhyYWUvrQXGFKOxdYacMQXRa51JeThEcDyqKJLhEibTske7S1mXQaQ7kvFL4Due2RYprR_5CuKF7NV59cpEMNA6Uo]cory@s...[/url
Enviado el: jueves, 07 de diciembre de 2000 18:09
Can you recommend a receiver to stay away from? Or one I should look at to
purchase?
Cory
Original Message
>From: Miguel Puchol [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jGsU_PQqptwF_sgZajMYwxnIsjS8x4loxLcQ4sp7zE2GzmxC8x0AkJRoIUOdHhJN3XGfLoQHqk6F]mpuchol@w...[/url
>Cory,
>Cheers,
>Mike
Mensaje original
>signal it is
>Thanks
>Cory
Original Message
>>From: Michael Hendricks [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xzdAIKma7J6gA8w1Ye_XZAZCVaLJvcvn9R7rXRUl2eIb3al1cItAoLBZmP9Pp1ZO1jqwZ8jaW28O]mjh80@b...[/url
>>as if they
>>are along a sphere.
>the math but
>>MH
Original Message
>will do for
>>> what I need.
>>indicate the
>there any
>>> Raj Mallik
