BS and LEDS
Hi,
I would like to drive some leds from my BS2 from Christmas.
How many leds (typical red ones) can a Basic Stamp 2 drive?
I suppose this is a small number. What can I do to extand this number?
(I don't need a BS output for each led, several leds can be turned on/off at the
same time)
Nicolas
same time)
Nicolas
assumming 10 mA per LED. Be sure to use an external 330 Ohm resistor
or use a 5V LED which provides an internal series limiting resistor.
This could be simply expanded by adding an octal driver such as the
ULN2803 which is about a $1.00. This would allow you to sink current
for 20 or more LEDs for each Stamp IO.
Peter H. Anderson, http://www.phanderson.com
Homebrew BS2, BS2 Starter Packages
--- In basicstamps@egroups.com, "Nicolas Fournel"
<Nicolas.Fournel@f...> wrote:
> Hi,
number?
on/off at the same time)
> Thanks,
> Nicolas
LEDs while only requiring 3 pins
Ian Bobbitt
When an error occures:
A novice user blames himself,
a normal user blames the computer,
a power user sighs and gets another cup of coffee.
KB9VEX
ICQ: 14106680
It said requires windows 95 or better, so I installed Linux.
On Wed, 15 Nov 2000, Nicolas Fournel wrote:
> Hi,
the same time)
> Thanks,
> Nicolas
> My thought would be that each output can handle a max of two LEDs
> assumming 10 mA per LED. Be sure to use an external 330 Ohm resistor or
The specs are (sink/source)25/20mA per pin max, but 50/40mA total per
I/O port. So (on seperate pins)5 LEDs at 10mA or 2 at 20mA etc.
Date: Thu, 16 Nov 2000 06:40:41 -0000
Don't forget you'll need lots more current for all the LEDs so
you'll need a power supply which will handle the number of LEDs
times current per LED if in parallel or higher voltage with
LEDs in series.... and add up all the branch currents.... don't
try to let the STAMP regulator handle all the current if you've
got a lot of lamps.... With various on/off schemes it may be
hard to predict peak currents but if you have the LED power
isolated from the STAMP power likely nothing more serious than
dimming will happen - or the power supply regulator overheat
or its fuse blow...
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
I don't know if this will be of any help or not, but Radio Shack has low
current (2mA)
diffused LED's. I purchased several for a project, so I wouldn't have to
worry about damaging my stamp. Of course there are other ways to use regular
LEDs, but I was looking for the easy way. I know that they come in Red and
Green (perfect for Christmas). They were relatively inexpensive, I think
about 27 or 29 cents each. I put a 1600 ohm resistor in line with them.
I'm not sure if they are listed in the regular catalog, but they were listed
in a catalog they had in the store, I guess it was a catalog aimed more at
commercial accounts, but anyone can order from it.
The Part number is TA-9006107 (Red). I don't have the number for the Green
ones in front of me now, but if you need any more info, let me know.
Happy Holidays
Kay
>>Hi,
>>current (2mA) diffused LED's.
FYI, the part numbers are:
Green -- p/n 276-303
Red -- p/n 276-310
> >>Hi,
> >>low current (2mA) diffused LED's.
> Red -- p/n 276-310
I wonder if these are Quality Technologies units like I used to get
from Digi-Key(they had yellow also). I used them in an r/c battery
monitor. They were a second source of an HP LED.
Mike DeMetz sect. Michiana R/C Choppers
miked@t...
http://sites.netscape.net/mdemetz
