Using VB to control BS2 pins
Hi,
I was wondering if anyone knew how to select a specific pin using the
VB comm port. I have already setup the comm port settings.
Also how would one send a value to that pin on the Basic Stamp.
Alan
Alan
that "duplicates" the Stamp functions in VB (like PULSOUT, SHIFTIN, etc.).
It uses MSCOMM to send commands (and receive responses) from the Stamp. So
you can connect a Stamp to your serial port and use this class module to
write "Basic Stamp-like" programs all in VB.
http://www.al-williams.com/awce/sbook.htm
Al Williams
AWC
* Control 8 Servos at once: http://www.al-williams.com/awce/pak8.htm
Original Message
> From: alan_correia@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ktTPLfRE4I9-cS6pQ1_kUmSesTVaey5iGJKq5CkhLPROF5u3ob6p57OppqwV8BbXTXgMAqSMwHD9o3-KpdNuSU1WAg]alan_correia@h...[/url
> Sent: Wednesday, October 11, 2000 12:05 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Using VB to control BS2 pins
> Hi,
> Thanks
> Alan
VB won't select a specific pin on the Stamp. You use the Stamps
SERIN command to do this, IE,, SERIN 0. This selects the serial
input pin of the Stamp.
When using VB or other PC software to control the serial port, data
will go out (to the Stamp) or other device on pin #3 TXD of the PC
serial port. Data coming to the PC serial port arrives on pin #2 RXD.
Here's a schematic showing how to connect the Stamp to the PC serial
port: http://www.rentron.com/pc-relay.htm Use the 22K resistor as shown
in the schematic to connect your Stamp to the PC serial port. Be sure to
connect pin #5 (signal ground) of the serial port to the Stamps circuit ground
also.
In VB you can have the form load initialize the com port settings as such:
Private Sub Form_Load()
MSComm1.Settings = "9600,N,8,1"
MSComm1.CommPort = 1
MSComm1.PortOpen = True
End Sub
The baud rate is set to 9600,N,8,1 and the port is opened for use.
To send data out the PC serial port to the Stamp:
Private Sub Command1_Click()
MSComm1.Output = Chr$(255)
End Sub
This assumes you have dropped a command button onto your form in VB.
This button will now send the value 255 to the serial port, and to the Stamp
I/O-pin you have selected using the SERIN,? command.
Be sure to use the same baud rate with the serin command, and you're
in business.
Bruce
webmaster@r...
Original Message
To: <basicstamps@egroups.com>
Sent: Wednesday, October 11, 2000 11:04 AM
| Hi,
| Thanks
| Alan
