Current Limiting Resisitor for LED / Optocoupler
I am in need of some assistance in determining the
correct series resistor value to use for driving an
LED or an Optocoupler.
For an LED, I am assuming from all my reading that a
330ohm resistor in series is sufficient. But, if I
refer this back to calculations, I have a problem. If
I know the forward voltage and current of the LED, how
do I calculate the current limiting resistor value?
Appreciate any advice,
Jack
__________________________________________________
Do You Yahoo!?
Yahoo! Photos - 35mm Quality Prints, Now Get 15 Free!
http://photos.yahoo.com/
Jack
Do You Yahoo!?
jscasserra@y... writes:
Subtract the forward voltage (Vled) from five, then divide by the forward
current (iled).
R = (5 - Vled) / iled
exactly the correct current limiting resistor for your needs.
Gary
www.microcontrollertricks.cjb.net
Original Message
To: <basicstamps@egroups.com>
Sent: Sunday, October 08, 2000 9:31 PM
Subject: [noparse][[/noparse]basicstamps] Current Limiting Resisitor for LED / Optocoupler
> Jack
> Do You Yahoo!?
In addition to the other suggestions, you might want to read:
http://www.al-williams.com/wd5gnr/basiccir.htm
This page covers dropping resistors, voltage dividers, Thevinin equivalents,
and power transfer theorem in a practical way.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: Jack Scasserra [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5L2W1ycjLbXBfFcxzjblbpXJaFoZPXpJcpg6XJfhVB_znG4icv_hXmBUTb7mlvL7P9zQV5wa3v7EizbJkLzl]jscasserra@y...[/url
> To: basicstamps@egroups.com
> Jack
> Do You Yahoo!?
As I see it, wouldn't it be simply:
+5 o
(Ground)
source Rlim LED
Assume, for example, that the LED should be limited to 10 mA. Then
Rlim = 5/0.010 = 500 ohms.
Steve
Steve Roberts: sroberts@s...
sroberts@s... writes:
> +5 o
(Ground)
> source Rlim LED
There is an error here -- you need to subtract the LED's forward voltage from
the supply. Many LEDs have a forward voltage of 1.2 volts. If this were the
case, the correct value would be:
Rlim = 3.8 / 0.01 = 380 ohms
A 330 ohm resistor would give you 11.5 mA and a 470 ohm would give you 8 mA.
Both are "standard" (5%) resistor values.
