Satellite communications via RS232 connecti on
RE: [noparse][[/noparse]basicstamps] Re: Satellite communications via RS232 connection
This technology sure sound very interesting. How does this work and where does one use this communication to the satellite.
Please shower your light on to this dumb brains of mine [noparse];)[/noparse]
nagi
Original Message
From: gsynergy@pacbell.net [noparse]/noparse][url=mailto:gsynergy@pacbell.net]mailto:gsynergy@pacbell.net[/url
Sent: Saturday, October 07, 2000 1:44 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Satellite communications via RS232 connection
--- In basicstamps@egroups.com, jonwms@a... wrote:
> In a message dated 10/7/00 1:23:57 PM Central Daylight Time,
> gsynergy@p... writes:
> > Hello Everybody,
> >· I would like to use a BS2 and the serial connection on a Board
of
> >· Education to send preprogrammed messages and commands via a
satellite
> >· modem.· The modem uses RS422 (DB25 connector) so I purchased a
RS232 -
> >·· RS422 port powered converter (B&B Electronics part # 422LP9TBN
> >· www.bb-elec.com).
> >· I have successfully sent the following commands via PC
HyperTerminal:
> >· <enter>
> >· echo off <enter>
> >· send gps fix <enter>
> >· I can monitor the fix arriving at the ground station via telnet.
> >· I have also successfully programmed the following into the BS2
and
> >· observed its execution via HyperTerminal.
> >· 'Send text via sat terminal test
> >· loop:
> >·· if in4=1 then xmit· 'in4 is keypad - transmit command when
> >· PIN is entered
> >·· goto loop
> >· xmit:
> >·· serout 16,16468,1000,[noparse][[/noparse]13,"echo off",13,"send gps fix",13]
> >·· pause 5000 'Allow keypad to reset
> >·· goto loop
> >· The problem is when I connect the BS2 to the Sat Modem the fix
is not
> >· transmitted.
> >· Thank you for your assistance.
> >· Regards,
> >· Bob Landsfield
> Check the specs on your satellite modem.· You may need to add
pacing to the
> SEROUT command.· You never notice this when using Hyperterminal,
since humans
> -- no matter how fast they can type -- can't send characters to a
modem as
> fast as the Stamp can.
> -- Jon Williams
> -- Dallas, TX
Jon:
I searched the modem's API and have not found the spec you
mentioned however, I did include a 1000 milliseconds in the orginal
code.
Do you think there should be more time?
Thanks for your assistance.
Bob Landsfield
nagi
Original Message
> > Hello Everybody,
of
satellite
RS232 -
> >· www.bb-elec.com).
HyperTerminal:
> >· <enter>
> >· echo off <enter>
and
> >· loop:
> >· PIN is entered
> >·· goto loop
> >· xmit:
> >·· goto loop
is not
> >· transmitted.
> >· Regards,
> >· Bob Landsfield
pacing to the
since humans
modem as
> -- Jon Williams
> -- Dallas, TX
Jon:
code.
Bob Landsfield
where
> nagi
Nagi
The technology is based on using an M-Sat, which is a geosynchronous
satellite that yields coverage for North America, Central America,
the Caribbean, and part of South America. The system is capable of
transmitting and receiving "packet-switched data" (i.e. text based
messages.) This is the system used by major trucking companies to
track their trucks and send text messages to the drivers.
Bob Landsfield
You mentioned about using a modem to send / receive these messages. Can you please give me more details on that ?
My car has a GPS receiver that I had installed a year ago. It works great!! But, I want to be able add something in my car so that, people at home can trace where I'm on the roads. Seems like this technology will allow me to do that. How do I go abt?
Please advise.
thanks a lot in advance
nagi
Original Message
Sent: Saturday, October 07, 2000 5:02 PM
on
where
> nagi
Nagi
the Caribbean, and part of South America.· The system is capable of
messages.)· This is the system used by major trucking companies to
Bob Landsfield
service that was legal to use for this purpose, there is no reason it would
have to be on the ham bands. But, it is probably illegal to use it on, say,
27MHz CB (in the US). Not sure about Class E (the UHF business band)?
In particular look at http://www.findu.com/
Al Williams
AWC
* Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
Original Message
From: nags [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iokv3DD3-9MsLHUOIEXh9v7bKPMXG3Lg3s_gM9h65gU-4zE7wxzAG_9YjXMH7wM5jFQlrP1RrMl-jL3m]nags@c...[/url
Sent: Sunday, October 08, 2000 10:21 AM
To: 'basicstamps@egroups.com'
Subject: RE: [noparse][[/noparse]basicstamps] Re: Satellite communications via RS232 connecti
on
Please advise.
nagi
Original Message
From: gsynergy@p... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aPdDtfraA8annvKw2aO8rUDfiXf-kCVFPrcxgFe_C-OcsQgQQt2b7E6FF0Owjg3Hqs7qvOpvXHXQEyMs]gsynergy@p...[/url
on
where
> nagi
Nagi
Bob Landsfield
software for laptops to do this... I'm sure it could be done with a basic
stamp...
David Tomaschik, KF4MDV
kf4mdv@a...
http://www.cosmicsys.com
Original Message
> From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mfi7Bl6reNFG0wFntTJkWViXYjDvoPrp9J-F0jDMYibS-1RgqdaPvsl8SE-zshG73RFhIdWAiOsL]alw@a...[/url
> Sent: Sunday, October 08, 2000 11:20 AM
> connecti on
> Hams do this all the time. Look up APRS on the Web. If you had a radio
> reason it would
> use it on, say,
> Regards,
> Al Williams
> AWC
Original Message
> From: nags [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HYgJ1KJfow_zXQQjHYbQodQPkgCBrOU8hwAXRb5dBeTrrZGTuslAE2pkPNdSnwYsbdWEfrjQ_QUI]nags@c...[/url
> RS232 connecti
> on
> messages. Can you
> works great!!
> people at home can
> allow me to do
> Please advise.
> nagi
Original Message
> From: gsynergy@p... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dwUS9ouDg6b1n0gwLqX9QesRM-7E1yWIZBcwvXb-caAwIu1sr4ET30WWko7YCktyFBBVA5mTOOIY3Qd_IikR]gsynergy@p...[/url
> on
> where
> > nagi
> Nagi
> Regards,
> Bob Landsfield
Thanks Al and Bob
nagi
Original Message
From: Al Williams [noparse]/noparse][url=mailto:alw@al-williams.com]mailto:alw@al-williams.com[/url
Sent: Sunday, October 08, 2000 10:20 AM
connecti on
Al Williams
AWC
Original Message
From: nags [noparse]/noparse][url=mailto:nags@crosscity.com]mailto:nags@crosscity.com[/url
on
Please advise.
nagi
Original Message
on
where
> nagi
Nagi
Bob Landsfield
