Op amp help
The project that I am working on needs to be run on battery only, and
I do not know if it is possible to get a -5 input using dc.
I want to have a +5 power supply and reference the other input to
ground.
I have heard that there are single supply op amps.I may have the
terminology wrong.
Can anyone recommend one?
Kay Clifton
ground.
terminology wrong.
Kay Clifton
you hook up the op-amp with +5 at the Vcc+ and 0v at Vcc- and you make your
ground to be +2.5v then the op-amp will see the Vcc- as a negative voltage
(with reference to ground which is actually positive 2.5v)
a[noparse][[/noparse] 1.5v (AA) | b[noparse][[/noparse] 1.5v (AA) |c
Here's a poor attempt at drawing 2 AA batteries, if you can see them...
If your reference is point 'b', then at 'a' you'll have 1.5v relative to 'b'
and at point 'c' the voltage will be -1.5v relative to 'b'. Still the
voltage between point 'a' and 'c' is 3v as you'd expect.
Remember that everything is relative.
I hope this makes sense and hasn't confused you more, I'm sure someone here
can give you a clearer explanation.
Alex
Original Message
From: Kayclifton@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0vf00W18DUc_WdWj5KjvPOSPE0p-5mKsKlfvnNyNjaGt4K9rsywpRzwyuXp_XYcNDrrFu236WZfqKDdE]Kayclifton@a...[/url
Sent: Thursday, October 05, 2000 6:26 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] OP AMP HELP
ground.
terminology wrong.
Kay Clifton
>ground.
>terminology wrong.
>Thanks
>Kay Clifton
Try Max406BCPA is a 5V chip rail-to-rail
Brian
here is the circuit I think you were referring to (from www.tekscan.com):
<TT>
Rf
Rs | |\ +9 |
-5 Vt --/\/\-o--|-\ | |
sensor | \ |
o---Vout
| -9
grnd
</TT>
The input to this circuit is the resistance Rs, which is (roughly)
inversely proportional to applied force. The circuit converts resistance to
voltage.
Vout=5*Rf/Rs
=~ constant * (applied force)
The feedback resistor Rf is chosen to scale the volts into the range of
force you want to measure. The output from the op-amp feeds an A/D
converter. If the minimum resistance (which occurs at maximum pressure)
happens to be 1kohm, and if you want 5 volts to go to your A/D at that
point, then you would choose Rf=1kohm.
Here is a single supply version of the circuit:
<TT>
Rf
Rs | |\ +5 |
;--/\/\-o--|-\ | |
o---Vout
| Vr----|+/|
o
o
grnd Vss
grnd
</TT>
The reference voltage can come from a voltage divider or from a reference.
My personal favorate is the LM10, a single supply op-amp that has a
built-in reference, and that can swing all the way to the rails (0 volts to
+5 volts) at the output.
Vout = Vr*(Rf/Rs+1)
Say you do use an LM10--then Vr=0.2 volts, and choose Rf=24kohm to achieve
Vout=5 volts at Rs=1000ohms. In your software calculate
(applied force) = constant * (Vout-Vr)
Or let's say you use a CA3130 op amp (which also can swing to the rails at
the output--you need that!), and a simple voltage divider to give Vr=1.0
volts. Then choose Rf=4000 ohms to give a full scale output of 5 volts
when the input Rs=1000 ohms.
Maybe you don't need the op-amp though. FSRs are not precision circuit
elements.
To use RCtime instead of the op-amp/ADC, here is a circuit:
<TT>
Rsensor 220
+5 Vdd ---/\/\----o---/\/\----P0 on BS2
=== 0.22uf Cf
| film
Vss
</TT>
The RCtime value is proportional to Rs. Capacitor Cf sets the scale factor.
Trc var word
loop:
rctime 0,0,Trc
low 0
debug dec Trc,tab,dec 65535/Trc,cr
pause 200
goto loop
This should give a reading of about Trc=30 when Rsensor=1000ohms.
65535/Trc inverts to give a result proportional to applied force.
(applied force)=~ constant/Trc
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
other flavor).
Rich
>Reply-To: basicstamps@egroups.com
>Date: Thu, 05 Oct 2000 22:25:54 -0000
>ground.
>terminology wrong.
>Thanks
>Kay Clifton
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
This is a tricky question with a lot of things you have to consider.
A "normal" op amp can't go right to either supply rail. So if you run an op
amp at -5 and 5 V, your output might range from -4.8V to 4.8V. The more
current you take from the output, the lower the voltage range is. So if
those numbers are at 10mA, at 50mA, it might drop to, say, +/- 4.7V.
Now, the problem is, you want a single supply. But is that practical? That
depends on what you are doing. They do make single-supply op-amps. These are
especially designed to go to at least one rail (usually the - rail). So if
you supply ground (0V) and 5V, the output could range from 0 to 4.8V (for
example). What does that mean? Well suppose you are buffering a DAC or PWM
output. The output only goes from 0 to 5V anyway. So you'll never need that
negative output swing. If you know your output would always range from 1V to
4V, you might not even need a special op amp at all.
However, what happens if you are using the op amp as an audio amplifier with
a capacitor coupling the input? Well, then you are in trouble because the
input is going to have + and - components and you are going to throw away
half of them (horrible distortion). So for that sort of thing, you have to
have an op amp that can go + or - or a way to bias the input so that it is
never negative (and you don't invert the signal).
So if you need that, the question becomes, "How do I get a negative
voltage?" There are a few common ways of doing this:
1) Use 2 9V batteries. Ground the center. Use the 9V to power your 5V
regulator and use +/- 9V on the op amp.
2) Use a dc to dc converter module to convert some voltage you already have
to -5V. Power Trends has some switching regulators that take +5 and
deliver -12 (with the magnetics built in). I haven't used them, but we use
the 38V to 5V regulator module in a product and other than being
unnecessarily large, it works OK. Maxim and others make chips for this, but
they require external inductors (that I know of). The Power Trends part is a
module like the Stamp -- not a true IC.
The simplest DC to DC converter is just an oscillator of some sort (555, RC
and an inverter, etc.), and a capacitive charge pump switched with diodes
(see
http://ourworld.compuserve.com/homepages/Bill_Bowden/page10.htm#5volts.gif).
You can also use a transformer/rectifier scheme. Look up DC to DC converter
on the Web. Switching regulators can do it by manipulating charge/magnetic
field. Maxim and others make "voltage inverters" that have all you need
except the capacitors.
3) An ugly trick I have used before works if you have low power requirements
on the op-amp. First make sure the op amp's inputs and outputs are DC
isolated (capacitor coupling on all in and out). This isn't uncommon anyway.
Then take a 9V battery and build a voltage divider (50%). Ground the center
of the voltage divider. Now the battery terminals are at 4.5V and -4.5V
(just don't ground the battery ground -- it isn't ground, it's -4.5V. The
downside is that the divider draws power, and the load will "upset" the 50%.
Still, I have used this to make a small circuit run off a single 9V battery
with no extra DC to DC converters, etc. The whole thing was just a fraction
bigger than a 9V battery by itself -- two jacks, two capacitors, the op amp,
two resistors for power, and a few parts in the feedback loop. This is
somewhat less ugly if you use more parts (see
http://www.sound.au.com/project43.htm who describes it better than I can).
If you need more power (grunt, grunt) look at
http://www.aaroncake.net/circuits/vinvertr2.htm -- a novel use of an LM386.
As usual, I've gone on too long. However, the point is:
a) You can get single supply op amps, but they are not always appropriate
for what you want to do.
b) If they are not, generating negative voltage is not all that scary after
all.
Hope that is helpful.
Al Williams
AWC
*Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: Kayclifton@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NNL5ahXdH9fxQks0ZHn2vz07uRQ3BRLMmuztEGqdNSi4xXSpvaQCjJD7HvjlxDWP3ASjbZYIt8iI3nSLzw]Kayclifton@a...[/url
> Sent: Thursday, October 05, 2000 5:26 PM
> ground.
> terminology wrong.
> Thanks
> Kay Clifton
Although certain op amps are optimized for single-supply operation, there's
really no distinction between "single-supply" and "dual-supply" op amps.
Notice that the op amp has no "ground" terminal. All it knows about is the
(+) and (-) supply voltages, and how the inputs compare to the supply
voltages.
Now for the practical comment. In addition to Tracy's and Al's suggestions,
another approach is to use an ICL7662 CMOS "Voltage Converter". This is an
8-pin DIP part which (among other things) gives you the negative of
whatever input voltage you supply. Digikey has p/n TC7662ACPA for $2.25.
Mouser has p/n 570-ICL7662CPA for $1.92. You provide two 10uF tantalum caps
and input your +5V, and you get -5V out. Hope this helps.
Steve
Steve Roberts: sroberts@s...
There are a number of inexpensive (less than a dollar) CMOS opamps that may
work. I also have a great circuit that costs about a dollar or two in basic
parts to generate a negative voltage to drive CMOS opamps.
If interested in details, e-mail your regular mailing address, and we can
send you a schematic that may work for you. Also, please include the total
current requirements of the supply and the maximum allowable current drain
from the battery.
Chuck Page
Technology Electronics, Ltd.
Original Message
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Thursday, October 05, 2000 6:26 PM
>ground.
>terminology wrong.
>Thanks
>Kay Clifton
