2 BSII Together?
Good Day All:
I have finally run out of program space in my BSII
project (A few A/D units recording data viewed via
dial-up modem). Question: I do have an additional
BSII... How do I access stored RAM bytes from another
BSII? I thought I would divide up my program and have
BSII #1 do the recording work and BSII #2 handle the
communications etc. I have studied the manuals but my
understanding is limited to say the least....!
Andy
__________________________________________________
Do You Yahoo!?
Yahoo! Photos - 35mm Quality Prints, Now Get 15 Free!
http://photos.yahoo.com/
Andy
Do You Yahoo!?
the data recorder bs2 format a data string and send it to the communications
bs2. the communications bs2 would the parse the data string and use it
accordingly.
brian
Original Message
To: <basicstamps@egroups.com>
Sent: Sunday, October 01, 2000 9:10 AM
Subject: [noparse][[/noparse]basicstamps] 2 BSII Together?
> Good Day All:
> Thanks,
> Andy
> Do You Yahoo!?
>Good Day All:
>BSII?
You don't, or not directly. Your choices are as follows:
1. Use an external EEPROM or Flash memory to store data
2. Connect the two BS-2's together to share information
In the Stamp Manual [noparse][[/noparse] www.parallaxinc.com ]
Documentation Section
Read about -
a. Serin/Serout
1. Variables and Modifiers
2. Baudmodes (including the insets) [noparse][[/noparse]I-19]
3. Parity, Timeouts and String Handling
b. Wiring the Stamp-to-Stamp interface [noparse][[/noparse]I-20]
c. Flow Control (as required)
d. Open Baud Modes (Page 320)
And that should start you out on the right foot.
The BS-2SX runs faster than the BS-2 and permit 8 x 2K program space.
One one "partition" can be active at a given time (no multi-tasking), but
variables can be shared between sections (see BS-2SX in Documentation section).
Additional "getting started" links:
Tracy Allen, EME Systems [noparse][[/noparse] www.emesys.com ] Basic Stamp Section
Prof. Peter Anderson, Morgan State U, [noparse][[/noparse] www.phanderson.com ]
Al Williams, AWC Electronics,
[noparse][[/noparse] http://www.al-williams.com/awce/asp2.htm ] Proto Board
also [noparse][[/noparse] http://www.al-williams.com/awce/car1.htm ] Carrier Board
and [noparse][[/noparse] http://www.al-williams.com/wd5gnr/stampfaq.htm ] Stamp FAQ
>Thanks,
Sure, hope that gets you started.
>Andy
regards,
Bruce Bates
>Do You Yahoo!?
dont know what type of data you are storing and how often it is updated but
each memory location in eeprom can only be written 1million times. You might
want to look at using an external serial ram chip.
MH
Original Message
Sent: Sunday, October 01, 2000 10:10 AM
> Good Day All:
> Thanks,
> Andy
> Do You Yahoo!?
Thanks to all for the information. I think I better
just get a BS2sx to keep things simpler. (I just won't
tell my wife...). I downloaded the IIsx info and it
seems even using that will involve a fair amount of
programming changes.
I'm a bit confused about the difference between the 32
Byte RAM and the Scratch Pad RAM. I can do VAR
statements in both but Scratch Pad statements can be
seen by all 8 programs? Can I just use Scratch Pad for
everything?
Andy
Do You Yahoo!?
Hi Andy,
I've posted some material on master/slave flow control between two BS2s at:
http://www.emesystems.com/BS2misc.htm#MasterSlave
Also, as Bruce pointed out, you could substitute a BS2sx for BS2. That way
you would have 8 times as much memory for your program and for data
recording. Okay, you already have a second BS2 that you could throw at the
project, but the tradeoff is that you would have to kluge the circuit,
versus purchase a BS2SX and plug it into the existing circuit. Actually,
you might be better off with a BS2e instead of a BS2sx. The BS2e has the
additional memory, but with less power supply current and more
compatability with the BS2 with respect to timing.
Not to be ignored is the possibility of writing more efficient code for the
BS2--but it is already optimized, right!!!
-- Tracy Allen
electronically monitored ecosystems
> everything?
Hi Andy,
Also look into the BS2e on the Parallax site, for lower current consuption
(if you don't need the higher speed of the BS2sx), and for more
compatability with the BS2 with regards to timing.
Both the main RAM and the scratchpad RAM in the 'sx or 'e is shared and can
be seen by all 8 banks.
The VAR statement works only for the main RAM. The main RAM is really 26
bytes, because 6 bytes of the 32 are used for the ins, outs and dirs
control of the Stamp pins. Variables in main RAM can be used in in
assignment statements like like <x=y+in1>, and as parameters in the
commands like <pulsout ppin,x>.
The 63 bytes in the scratchpad can only be accessed with put and get.
Those bytes cannot be used directly in commands without going through a
main RAM variable:
' example shows use of scratchram
status_p con 8 ' points to status byte in scratchram
status var byte ' a variable in main ram
put status_p,73 ' stores a byte in scratch
loop:
get status_p,status ' get a scratchbyte
debug bin8 status,cr ' show status
status=inH ' update status=high inputs
put status_p,status ' save it
pause 1000
goto loop
-- Tracy Allen
http://www.emesystems.com/BS2SX.htm <--- more info about the BS2SX and
BS2e
Parallax is apparently out of stock of the BSIIe which
is why I thought of the sx. My code is no way as
efficient as it should be but it is the best I can do
at this time. I work by looking at other programs and
snipping parts to make up what I need. I'm slowly
learning and the manual is starting to make more
sense!
Andy
> -- Tracy Allen
Do You Yahoo!?
