Joystick control for robot
I have a program that reads joystick data and would like to use this
data to control a simple robot. The robot could be liked to the
computer with a radio but that is not crucial at this point.
I called parallax customer support and asked them if the serial port
of the basic stamp II was used exclusively for downloanding the
programs or if could be used to send interactive commands to the
basic stamp. I was told that the only use for the serial port was
downloading the program. Is this true?
I would apreciate any advice I could get on this subject.
Augusto Opdenbosch
Augusto Opdenbosch
the BASIC Stamp using the Pot command to control your
robot using RF remote control with a joystick at:
http://www.rentron.com/ruf-bot.htm
Bruce
webmaster@r...
Original Message
To: <basicstamps@egroups.com>
Sent: Friday, September 29, 2000 1:42 PM
Subject: [noparse][[/noparse]basicstamps] Joystick control for robot
| Thanks,
| Augusto Opdenbosch
Check out http://members.tripod.com/~divelec/joystick_program.html
and http://members.tripod.com/~divelec/joystick_schematic.html
>Thanks,
>Augusto Opdenbosch
you can remove the jumper then use the stamps serial port as an extra
serial, then replace the jumper for programming. Just connect SIN and SOUT
to TX and RX respectively.
Original Message
From: opdenbosch@m... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eEOPJ9r1Q7Td7W9x7KjkAQevjn0J6cFNtSrODVlk_6rraRbHBJZlOdj5UB9ZlPBwaJMNn7LUAp-rEjEaPgA]opdenbosch@m...[/url
Sent: Friday, September 29, 2000 12:42 PM
To: basicstamps@egroups.com
Augusto Opdenbosch
Thank you for replying so quickly. I took a look at your link and saw your
joystick-robot project. Most impressive!
I would like to know if there is a big implementation difference if the
joystick is connected to the computer instead of being directly connected to
the transmitter. I would like the instructions for motion to come from a
computer because eventually they will not be joystick-generated but
web-generated.
Is it possible to connect a transmitter to the computer's serial port so the
commands coming from the computer could be then transmitted to the robot?
If this is true, what kind of electronic parts do I need to purchase?
Also, can all these components be purchased from Parallax Inc?
-Augusto
Original Message
From: Bruce [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nHN-RP_PHTKZiTOFr_tYi_jfXqFz094cWQtdi3e5iGzwqQfVOL1P7jGJnJqM0zJCqjq5rJoULU-LEw]breyno2@r...[/url
Sent: Friday, September 29, 2000 3:56 PM
Subject: Re: [noparse][[/noparse]basicstamps] Joystick control for robot
We have a project that could be easily adapted for use with
Bruce
webmaster@r...
Original Message
| Thanks,
| Augusto Opdenbosch
opdenbosch@m... writes:
> I was told that the only use for the serial port was downloading the
program.
> Is this true?
You can use the programming port for general serial communications. In SERIN
and SEROUT, the pin number is 16. Be aware that the Stamp will echo
everything sent to it, so you may have to filter this with your software
(it's not hard to do -- see Jan Axelson's book, "Serial Port Complete").
-- Jon Williams
-- Dallas, TX
Thanks, but full credit for this project goes to Rob Arnold.
The TWS/RWS RF modules we have are easy to control using
asynchronous serial methods. The Stamp serout command
can directly control the transmitter (TWS-434). The serin command
can extract data from the receiver (RWS-434).
| web-generated.
If you use the joystick attached to your PC, you'll need to figure out a way
to send this joystick data to the Stamp, or to the transmiter module. It can
be done in many ways, but depends on the capabilities of your program that
reads the joystick.
Yes. You can, but you'll need to use a max232 to convert the RS-232 voltages
to TTL level.
Pretty much all you'll need is the transmitter/receiver, and max232 if you plan
to
directly control the transmitter without the Stamp interface. I would use the
Stamp to grab serial data from the PC, and then control the transmitter.
Parallax has some excellent RF modules that will work for your application.
They sell for about $148.00 per pair (transmitter/receiver) + shipping. Ours
sell
for $13.00 per pair + shipping, and work very much the same.
I'll be posting a project soon that shows how to interface the TWS transmitter
to the PC serial port for wireless control of the Scott Edwards Mini SSC II
serial
servo controllers.
If you need help with your project, email me directly at the address below.
Bruce
webmaster@r...
| Thanks,
| -Augusto
Original Message
| From: Bruce [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lIFmBLYIyaCJ-CdBf_e85nYWSMJc6SWwrg957T1lmlPluYCiRZhJeWmKyGlKZ1NflbLTLXq4Zw]breyno2@r...[/url
| Regards,
| Bruce
| webmaster@r...
Original Message
| | Thanks,
| | Augusto Opdenbosch
for a schematic and program that allows radio & joystick control with a
standard RC receiver and a BS2.
Carl
Original Message
> From: <opdenbosch@m...>
> | Thanks,
> | Augusto Opdenbosch
these for anything, you can interface the stamp to a serial port using the
I/O pins which you have available and some code.
Hope it helps,
Alex
Original Message
From: opdenbosch@m... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uLB73-6lLpOX-4PYN83zTFaZVzB-atRiFdFT8NXhbdWFnB7a3pkdShlV6Ho6omTcMBL0TmWdG_I0Zh08ZMa1QOw]opdenbosch@m...[/url
Sent: Friday, September 29, 2000 3:42 PM
Augusto Opdenbosch
I am much interested in your web page and the info it may have on it,
however; the page is all scrambled when it comes up in my browser.
Would you be so kind to send along a text file of the code you present and
the images of the schematics?
Thanks in advance.
James
Original Message
From: Carl A. Kollar [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hNEIFTQKaLC2oa2Uhl-XtEek7n5yWNiaQNc_444l53kDvlOf0k2-7o-Momv3xiRtTT1M6435FhWPbctPZQ]carlk3jml@b...[/url
Sent: Friday, September 29, 2000 8:07 PM
Check out my site at http://members.tripod.com/~divelec/r3rcjs01.html
Carl
Original Message
> | Thanks,
> | Augusto Opdenbosch
I'm sorry you're having problems reading that page. I just checked it out
and it looks OK to me. I'll check further. Meanwhile, if you click on the
"download" icon near the bottom of the page, you can download a zip file
with all the info. That should be good. Let me know offlist how you make
out. If you still have problems, we'll get a good copy to you one way or
the other.
I can fax it to you if possible. (BTW, I'd be interested in knowing what
browser you're using- It might give me a clue as to what is going on)
Carl
Diverse Electronic Services
Original Message
Sent: Saturday, September 30, 2000 11:42 AM
Subject: RE: [noparse][[/noparse]basicstamps] Joystick control for robot
> Hello Carl;
> Thanks in advance.
> James
Original Message
> From: Carl A. Kollar [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_3y7aaTT3lTIYQVdqExkDvjVpjSbHi2JyyVDzLrz0WCJFvL2IGPxf3uN0ZR89SbinM01IPZU2c0iVav-8Psg]carlk3jml@b...[/url
> Carl
Original Message
> > | Thanks,
> > | Augusto Opdenbosch
the other.
Carl
Original Message
> Hello Carl;
> Thanks in advance.
> James
Original Message
> From: Carl A. Kollar [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wMXvLcA-QYV6FtufXEMI19zZ3n4eXr4jAbrhdEMSDcoXP_YYCD5VwJAuIgXDcQ9hC-zYHTrsRsPXXeh8QGnWsA]carlk3jml@b...[/url
> Carl
Original Message
> > | Thanks,
> > | Augusto Opdenbosch
