32 Bit Math
Does any one have any examples of how to do 32 bit math on a BS2SX...
We need the following functions:
I am assuming that you would perform high order and low order
functions but the BS2 has no access to a "carry" register that I am
aware of. I greatly appreciate any suggestions that you might have.
If it helps the formula i need to implement (in C) is as follows.
n, z, y, sum, k all being 32 bit words.
while(n-->0)
z -= (y << 4 ^ y >> 5) + y ^ sum + k[noparse][[/noparse]sum>>11 & 3];
sum -= delta;
y -= (z << 4 ^ z >> 5) + z ^ sum + k[noparse][[/noparse]sum&3];
Thank you again
MH
while(n-->0)
sum -= delta;
Thank you again
MH
MH
Original Message
To: <basicstamps@egroups.com>
Sent: Thursday, September 21, 2000 12:30 PM
Subject: [noparse][[/noparse]basicstamps] 32 Bit Math
> Maybe this will help:
> http://www.emesystems.com/bs2math6.htm
> -- Tracy Allen
> Electronically Monitored Ecosystems
> >while(n-->0)
> > sum -= delta;
> >Thank you again
> >MH
-- Tracy Allen
>while(n-->0)
> sum -= delta;
>Thank you again
>MH
