Help- simple task, but need help.
HELP.....
What is the best way to have the Stamp 2 to control a few (4 relays,
3
LED's and three Servos) external components. I already have the
servos working without any problem. With the relays and LEDS, I need
either a driver circuit or something since I do not want to burn out
the basic stamp.
Donald Brunner
3
the basic stamp.
Donald Brunner
Lincoln J. Worsham
liworsha@g...
Neuro Engineering Laboratory
NASA Ames Research Center MS 269-1
Moffett Field CA 94035-1000
Phone 650-604-0461
Fax 650-604-3594
http://www.arc.nasa.gov/computing.html
writes:
> Use an ULN2003 to drive the relays. Darlington circuit, 8 outputs, 500ma
Actually, it's the ULN2803 that has eight Darlington circuits.
Sid
Newzed@a...
forget to use a diode across the relay to snub the falling magnetic field
which will induce a voltage every time the relay is de-energised. I have
also had great luck with FETs as drivers such as ZVN4206AV and VN10LP
Good Luck,
Gary
g.shearer@v...
Free Electron Laser Research Center
Vanderbilt University
Nashville, Tennessee
Original Message
To: <basicstamps@egroups.com>
Sent: Sunday, September 17, 2000 7:59 PM
Subject: [noparse][[/noparse]basicstamps] Help- simple task, but need help.
> HELP.....
> 3
> the basic stamp.
> Thanks
> Donald Brunner
