BS2-SX Load problems...
                    I keep getting "BASIC STAMP IISX DETECTED BUT NOT RESPONDING ON COM3.
CHECK POWER SUPPLY".
When I write a simple project made up of several short programs (say
0-4) it works. But when I add a more complex program to the list of
programs it has to run it gives me the message you see above.
Frustrating!
Further... when I run the more complex program by itself as program
zero, it seems to work fine.
What gives?
Ross
Frustrating!
What gives?
Ross
Assuming you are using the windows software you need to tell the
software which stamp you are using.
On the menu : File Edit Run Help
click "Edit"
Click "Preferences"
Click "Editor Operation"
Under " Stamp Mode and Ports"
"Default Stamp Mode:" Change the selection from "BS2" to "BS2SX"
Click "OK"
Now if you click the "ID" or "RUN" Buttons they should work!
David Burleson
dburlesn@v...
COM3.
(say
> Frustrating!
> What gives?
> Ross
on. Thanks for trying!
Anyone else??? The search is still on! :-)
Ross
--- In basicstamps@egroups.com, "David Burleson" <dburlesn@v...>
wrote:
> I had the exact same problem!
> click "Edit"
> Click "Preferences"
> Click "OK"
> David Burleson
> dburlesn@v...
> COM3.
> (say
of
> > Frustrating!
program
> > What gives?
> > Ross
What does your code look like?
You can override the preference setting from within your code with the
$STAMP directive.
Near the top place a comment that reads:
'{$STAMP BS2SX}
OR of it is for a project consisting of multiple files use:
'{STAMP BS2SX,file1,file2,...,file7}
Hope this works.
David
Original Message
To: <basicstamps@egroups.com>
Sent: Saturday, August 26, 2000 7:37 AM
Subject: [noparse][[/noparse]basicstamps] Re: BS2-SX Load problems...
> Thanks David but no good. I had the SX preference checked off early
> Ross
>Frustrating!
>What gives?
>Ross
Hi Ross,
Low battery? A marginal power supply could do strange things especially
with the BS2sx because of its larger power drain. Loose cable?
At what point does the run fail, that is, does it even get part way
through, or does it fail right at the beginning? The timing of the
handshaking between the stamp and stampw.exe is quite touchy. The
operating system might get in the way. Turn off any other stuff that might
check the serial port. Turn off as many TSRs as you can to streamline the
operating system.
As a workaround, set the editor preferences to send only the "current
program". Then, you should be able to run the programs one at a time into
your stamp. Does that work?
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
Been there, done that. The code for the stamp is there.
Any other ideas?
Ross
wrote:
> OK,
the
> $STAMP directive.
> '{$STAMP BS2SX}
> Hope this works.
> David
Original Message
> From: <rossfree@m...>
early
> > Ross
I am currently using a 9VAC power supply. I've used two different
supplies and gotten the same message. I have 450ma available to me.
Unless the supply is very dirty (noisy), and I have a nice fat cap to
handle that, I don't think the supply is the problem.
I suspect the operating system and handshaking as you suggest. I have
not tried loading the programs one at a time. Good suggestion. But if
the project consists of several programs, will one overwrite the
other if they are not loaded all at the same time? I still
think 'BS2'. :-)
The project I've been trying to run consists of several place holder
programs (to be filled as I progress in my project) and a fairly
large keypad program. So the first several programs are 'pop in...
yep I made it in... pop out to the next program'. I would have the
display indicate that I did in fact make it from one program to the
next, then move on. The first SX project I wrote did nothing more
than that. Program 0 - 4, each in turn, would consist of a display
instruction, then a run (the next program number) instruction.
It worked fine. Once that was done, I started filling in one of the
place holder programs with real stuff... my keypad program. It quit
working. So I ran the keypad program as a stand alone SX program.
Program 0 became the keypad program. It ran. Go figure!
I would say it's a problem that must be related to my own computer,
except that I had the same problems with an old laptop I was using as
well. The same problems!
You asked when the program would quit loading. I haven't actually
thought to watch. But it seems to stop when it hits the big one...
the keypad program. The others seem to make it through.
I will check for TSR's and also try loading the programs one at a
time... I'd still like more clarification on that one. Does it in
fact add programs to the project currently stored on the chip or does
it erase the programs there and replace it with the program you are
storing? HMMMMM???
I've got to keep going... need to finish this project! HELP!
Thanks again!!!
Ross
COM3.
(say
of
> >Frustrating!
program
> >What gives?
> >Ross
> Hi Ross,
especially
that might
streamline the
> operating system.
the "current
time into
> -- Tracy Allen
Did it ever work?
Have you isolated the com port? instead of Com3 try Com1 or Com2
Preferably one that doesn't share an IRQ with another device.Like a modem
What is your power supply?
If a battery, is it low?
What operating system.
I normally use Windows 2000 Professional, or 2000 Advanced Server.
Neither work with my stamp software.
I have to reboot to Windows 98 to program my stamp.
Good Luck,
David B.
Original Message
Sent: Saturday, August 26, 2000 9:36 PM
> Thanks for the reply David...
> Any other ideas?
> Ross
> wrote:
> > OK,
> the
> > $STAMP directive.
> > '{$STAMP BS2SX}
> > Hope this works.
> > David
Original Message
> early
> > > Ross
>think 'BS2'. :-)
Hi again Ross,
As you know, each BS2SX project consists of up to 8 programs, specified by
the $STAMP directive at the head of the the file0.bsx program:
'{$STAMP BS2SX, file1, file2,...,file7}
Each of those programs nameed in the directive is uniquely associated with
one of the program banks in the 'SX. You can elect to run one program at a
time, by choosing the "current" option on the editor operation tab. When
you have a current program in front on the screen, and RUN it, then only
that program is loaded into the corresponding bank in the BS2SX. None of
the other banks are affected.
For example, if you elect to run only program number 2, then only that
program is sent. It replaces the current contents of program bank number 2.
Banks 0, 1, and 3 to 7 are not changed. You can step one by one through
the programs that are part of a project and run them individually. The
effect is the same as if you had RUN them all at once under the "all"
option. (BTW, in the DOS software (STAMP2SX.EXE), the bank-at-a-time method
is the only option and has to be done manually.)
There is also a "modified" option that RUNs only those programs that have
been modified since your last run. The "modified" option has no way of
knowing what is already programmed into the BS2SX chip, so when you first
load an existing project into the STAMP2W.EXE environment, the "modified"
option will send _all_ the programs when you first RUN one of them.
When you RUN a multi-bank project, the program action for each bank is
quite independent of the others. From the PC-->BS2SX point of view, the
RUN consists of independent banks. The PC resets the BS2SX before
transmitting the data, and the programming header includes the number of
the bank that is being targeted by the current RUN. The action is the
same, whether you are running one program of a project under the "current"
option, or several programs of a project under the "all" or "modified"
options.
The programming protocol requires handshake data to bounce back from the
BS2SX very fast, and that is where some operating systems get tripped up.
If the outgoing and incoming characters go onto some kind of OS queue, and
are not serviced in time, then you will see that awful ""BASIC STAMP IISX
DETECTED BUT NOT RESPONDING ON COMn". At least that is my theory. I have
been lobbying Parallax to relax that timing. It is now about 18
milliseconds to timeout, but it seems to me there would be a lot less
problems with bloated OS's if it were relaxed to 80 or 100 milliseconds.
Then I think I could even run it on my Mac under softwindows, which buffers
the serial data on a 50 millisecond clock.
I hope that clarifies a little how the BS2SX options work. I do not know
how it relates to what you are seeing, but the timing is tight. It sounds
like you might be close, so have a go at those TSRs and serial port setups.
-- Tracy Allen
It works! I have been able to run each program individually with
STAMPWIN. Thankyou!
I just got this in from STAMPTECH. I haven't tried it but it fits the
profile I'm working in.
Thanks again Tracy and all who have tried to help!!!
Ross
see below...
Hello (from stamp tech),
One way to solve this problem might be to put a debug command in the
first
program. What happens is, that when you put a debug command in 3rd
program, it runs the programs and stops when it comes to the debug
command
and the stamp says where is the rest of the program while its trying
to
open the debug window. So to get around this you need to put in a
debug
statement in the first program, then the whole program will run. If
you
have any more questions please feel free to e-mail us.
At 12:31 PM 8/26/00 -0400, you wrote:
>Hey folks,
>Frustrating!
>What gives?
>os: win98 AMD K6 500
>Stampw_v1_096.exe
>I have set the program preferences to SX , default com port to AUTO
and
>download mode to ALL.
>A copy of the program (that won't load) is attached (2 files). The
program
>is incomplete but tokenizes ok and should work.
>Help please! Thank you.
>Ross
> >I have
if
> >think 'BS2'. :-)
> Hi again Ross,
specified by
associated with
program at a
tab. When
only
None of
that
number 2.
through
The
the "all"
time method
that have
way of
first
the "modified"
them.
is
view, the
number of
the
the "current"
or "modified"
> options.
from the
tripped up.
queue, and
STAMP IISX
I have
less
milliseconds.
buffers
not know
sounds
setups.
> -- Tracy Allen
